4rcsimmons(at)comcast.net Guest
Posted: Fri Feb 18, 2011 12:55 pm Post subject: Zenith601-List Digest: 1 Msgs - 02/17/11 |
Hey Tim,
I have the same issue. I had to cut the neck out.
What is the suggested sealing material to use on the threads once you go back together.
- Rich
On Feb 18, 2011, at 1:58 AM, Zenith601-List Digest Server <zenith601-list(at)matronics.com> wrote:
| Quote: | *
Today's complete Zenith601-List Digest can also be found in either of the
of the Zenith601-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-02-17&Archive=Zenith601
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 11-02-17&Archive=Zenith601
Zenith601-List Digest Archive
Total Messages Posted Thu 02/17/11: 1
Today's Message Index:
1. 07:51 AM - The "Big Tap" (Tim Juhl)
Time: 07:51:34 AM PST US
Subject: The "Big Tap"
I just received the loan of the "Big Tap" from Zenith to clean up the threads in
my tank filler opening after I had to cut the filler neck out to remove the
tank during wing modification.
I appreciate Zenith making it available but I thought I would share with those
of you who might be in a similar situation a little advice that could save you
some cost in shipping it back and insurance.
The kit Zenith sends contains a lot more than you probably need or want. In addition
to the tap, they send a big drill and chamfer which you wouldn't need unless
you can't get your filler neck to fit flush to the wing. I think that would
only be a problem if you had an early production tank or were doing your own
tank welding. If your old filler neck fit, the new one will too.
I've attached a pix of what is in the kit. If you just need to clean up the threads
like I do, you might just want the thread cleaner and the tap.
Good luck!
______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Tearing wings apart for modification
http://forums.matronics.com/viewtopic.php?p=331340#331340
http://forums.matronics.com//files/big_tap_208.jpg
