How to mount a tire the easy way.
Roger Lee
PostPosted: Thu Feb 17, 2011 2:42 pm    Post subject: How to mount a tire the easy way. Reply with quote
Hi All,
Here is the easy way to mount a tire on the wheel. You will use a lot less choice words and do it in 1/4th the time.
I have been doing it this way for the last several years and the nice people at Matco made a nice picture for everyone.
Enjoy
How to mount a tire the easy way.pdf
Mounting a tire made easy
 Filename:  How to mount a tire the easy way.pdf
 Filesize:  422.11 KB
 Downloaded:  530 Time(s)
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
thesupe(at)hotmail.com
PostPosted: Thu Feb 17, 2011 7:42 pm    Post subject: How to mount a tire the easy way. Reply with quote
Good one Roger, so simple but yet so effective.  Of course now though I have to buy one more clamp! LOL  Take care,  Jim Chuk
PS  keep those tips comming!  Thanks!
> Subject: How to mount a tire the easy way.
Date: Thu, 17 Feb 2011 14:42:45 -0800
To: rotaxengines-list(at)matronics.com
--> RotaxEngines-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com>
Hi All,
Enjoy
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=331367#331367
http://forums.matronics.com//files/how_to_mount_a_tire_the_easy_way_924= Archive Search & Download, 7-Day Browse, Chat, FAQ,
&g= --> http://www.matronics.com/Navigator?RotaxEngines-List
&gt======
Thom Riddle
PostPosted: Fri Feb 18, 2011 4:48 am    Post subject: Re: How to mount a tire the easy way. Reply with quote
That is clever.
I have had tires so difficult to remove from the rim half that my 280 lb mechanic partner standing on the tire could not break the bead. So we built a tool using pieces of 5/8" plywood with a circular hole just larger than the wheel rim diameter plus a piece of all-thread, plus clamp bars and nuts to squeeze the tire off the rim. Works well but this seems a bit simpler.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
williamtsullivan(at)ATT.N
PostPosted: Fri Feb 18, 2011 4:58 am    Post subject: How to mount a tire the easy way. Reply with quote
Don't forget to lube the tire and rim with a bit of soapy water, for on or off.
      Bill Sullivan
      Windsor Locks, Ct.
      Kolb FS 447
--- On Fri, 2/18/11, Thom Riddle <riddletr(at)gmail.com> wrote:
That is clever.
I have had tires so difficult to remove from the rim half that my 280 lb mechanic partner standing on the tire could not break the bead. So we built a tool using pieces of 5/8" plywood with a circular hole just larger than the wheel rim diameter plus a piece of all-thread, plus clamp bars and nuts to squeeze the tire off the rim. Works well but this seems a bp; --> http://www.matronics.com/Navigator?RotaxEngines-; - MATRONICS WEB FORUMS -http://www.matronics.c===================
blackmore(at)platinum.ca
PostPosted: Fri Feb 18, 2011 6:10 am    Post subject: How to mount a tire the easy way. Reply with quote
gpabruce(at)gmail.com
PostPosted: Fri Feb 18, 2011 10:34 am    Post subject: How to mount a tire the easy way. Reply with quote
Separating a tire from the rim on small aircraft:
As a Vintage A&P and having changed out many tires and my preferred method was relatively simple and effective. I used two large heavy bladed and blunt screw drivers, not your watch repair screwdrivers, more like heavy equipment type screw drivers . . .the bigger and dumber the better . . . Then I would squat and put my knees on both sides of the "deflated" tire. A little soapy water is always good too. Then I would just work my way around the tire a little at a time, pushing in the screwdrivers in and prying a little each time. It was more Neanderthal than NASA but it works.
On Fri, Feb 18, 2011 at 4:11 AM, FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)> wrote:
[quote]Roger:
INTERESTING....
I have never had a problem mounting a tire to a wheel...
Where I have problems is separating the tire from the wheel.  Especially if it has been on for a long time.
I guess I could use the clamps, if I had clamps.  Wink
Andy tricks if one does not have clamps?
Yea, Yea, I know - -  Buy clamps.  Wink
What I have used successfully (but not what I would suspect is the easiest method) is just a 2 ft long 2x4 across the tire and stand on it.
Any other suggestions?
Barry
ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
KeysFox
PostPosted: Sat Feb 19, 2011 12:11 pm    Post subject: How to mount a tire the easy way. Reply with quote
I gave up trying to demount two really old tires on roughly 1991 vintage
Kitfox (Douglas) wheels and resorted to cutting a section of the tire down
to the wheel rim then cutting thru the metal wires in the bead of the tire
with a carbide bur in a dremel tool.
The wires in the bead made a serious "pop" as I cut thru the last one.
Being a retired dentist this seemed prettly easy to do without damaging
the aluminum wheel but it ruined the carbide bur.
BJ
Kitfox IV N143K
PA 39 N626NR
That is clever.
simpler.
Thom Riddle
Buffalo, NY (9G0)
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
Don't accept your dog's admiration as conclusive evidence that you are
wonderful.”
—Ann Landers
http://forums.matronics.com/viewtopic.php?p=331397#331397
B Jones
N154K
443-480-1023
pchristensen10(at)austin.
PostPosted: Sat Feb 19, 2011 12:35 pm    Post subject: How to mount a tire the easy way. Reply with quote
Here's how I dismounted some difficult tires. I removed the wheel and
tire from the plane. Then I took them to a tire shop. That was so easy.
(I just can't help being a smart ass.)
Pete
Leander Tx
Kitfox III, 912,
BJ
Kitfox IV N143K
PA 39 N626NR
> That is clever.
> simpler.
> Thom Riddle
> Buffalo, NY (9G0)
> Jabiru 2200A #1574
> wonderful.”Â
> —Ann Landers
