No click when pushing PTT
Goto page 1, 2  Next
N777TY
PostPosted: Sun Feb 13, 2011 8:32 pm    Post subject: No click when pushing PTT Reply with quote
Just trying to start the troubleshooting of a strange issue I have in my plane. When I push PTT button while COM2 is selected, I don't get that click at the beginning of transmission... The radio transmits just fine.. just doesn't give that click. COM1 works fine. Both are using same PTT button and are wired into the PSE 8000 audio panel. (COM1 is Garmin 530W and COM2 is Garmin 430W)
Since the radio works fine it's a somewhat lower priority issue, but it does cause a problem when flying at night... I cannot turn on the runway lights with the second radio because the click isn't there...
Tried swapping antenna leads but that didn't help... haven't tried anything else yet.. looking for some ideas.. Thanks!
RV-7A
N777TY
PostPosted: Mon Feb 14, 2011 12:15 pm    Post subject: No click when pushing PTT Reply with quote
Are you expecting to get an audible click from the
radio itself? I think the use of electro-mechanical
relays common to transceivers for 50 years have
been replaced with all solid state switching. If
the radio is working, it's probably performing as
advertised.
N777TY
PostPosted: Mon Feb 14, 2011 5:02 pm    Post subject: Re: No click when pushing PTT Reply with quote
Yes, I'm expecting a click.. Considering that the other one which is same technology (ie, not a case of old vs. new) I'd think the expectation is reasonable Smile Don't remember last time I ran into this situation in any plane ... so what I'm experiencing on COM2 is not typical.. Looking for ideas what to look at..
RV-7A
N777TY
PostPosted: Mon Feb 14, 2011 5:17 pm    Post subject: No click when pushing PTT Reply with quote
Maybe I missed something . . . is the radio
misbehaving in any other way that being
free of audible noises when you hit the
PTT button?
Bob McC
PostPosted: Mon Feb 14, 2011 5:41 pm    Post subject: No click when pushing PTT Reply with quote
Bob;
I think you might have missed the part where he said that his com 2 radio
will not activate pilot controlled lighting whereas his com 1 will. He is
associating the "missing click" with the inability to activate the lighting
systems. Other than this one item it operates "normally"
Bob McC
[quote] --
Bob McC
Falco #908
(just starting)
N777TY
PostPosted: Mon Feb 14, 2011 6:58 pm    Post subject: Re: No click when pushing PTT Reply with quote
Yes, the radio works fine otherwise (as in, it transmits fine). COM1 produces the click (hence I can turn on the runway lights). COM2 doesn't do that. It's not audible, and consequently lights don't come on..
I can hear the click on COM1 (and as a result, lights can be turned on, for example)..
RV-7A
N777TY
ceengland(at)bellsouth.ne
PostPosted: Mon Feb 14, 2011 7:39 pm    Post subject: No click when pushing PTT Reply with quote
RV-7A
N777TY
I would expect the light control radio to trigger on just the carrier,
but for troubleshooting purposes you might try synthesizing a click
verbally while holding the xmit button for each trigger, & see if the
light control radio would respond to that, assuming that it really needs
to see audio on the carrier.
I'd also ask the control radio's mfgr about whether it just listens for
carrier or not.
PostPosted: Tue Feb 15, 2011 6:03 am    Post subject: No click when pushing PTT Reply with quote
on, for example)..
When you say 'transmits fine' do I presume that
you can communicate with some distant facility?
If on the ground, can you talk to say a distant
aircraft and the pilot reports strong signal on
either radio?
Suggest you get a rough reading on power output.
You can do this with the most rudimentary of
SWR meters if you don't have access to a real
wattmeter. Use the meter to check the #1 system
and set the device for a full scale, forward
reading on #1 then move it to #2 without changing
the calibration.
Talking to another airplane in the hangar or
to a local hand held might appear to be just
fine when in fact, transmitted power output is
a tiny fraction of what it should be.
Float Flyr
PostPosted: Tue Feb 15, 2011 6:08 am    Post subject: No click when pushing PTT Reply with quote
I would expect the first thing to do is to verify your radio is not
transmitting... If you have another radio close by you can test the
transmitter is operating. An old trick we used to do with taxicabs years
ago was to have someone hold a fluorescent tube (tube only completely
unplugged) close to the transmitting antenna and key the mic. If the tube
lights up the transmitter is active. Of course you can also see if you are
putting out any power by inserting an SWR meter in the antenna feed line.
In this case where you are only looking for the presence of power the
cheapest of SWR meters will suffice.
As Bob said, gone are the days when there were mechanical relays happily
chattering open and closed with every transmission.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Tue Feb 15, 2011 6:10 am    Post subject: No click when pushing PTT Reply with quote
carrier, but for troubleshooting purposes you might try synthesizing
a click verbally while holding the xmit button for each trigger, &
see if the light control radio would respond to that, assuming that
it really needs to see audio on the carrier.
for carrier or not.
If the lighting control system needs audio, it would
be a published feature. Some of the early lighting
control systems were jury-rigged onto the facility's
unicom radio. It was a circuit that needed to see
a sweeping frequency tone that pilots were expected
to generate by whistling.
I haven't seen one of those in service in 30 years.
They're all carrier operated now and generally have
their own dedicated receiver.
I would certainly resolve the power output question
first.
PostPosted: Tue Feb 15, 2011 6:52 am    Post subject: No click when pushing PTT Reply with quote
At 08:06 AM 2/15/2011, you wrote:
--> AeroElectric-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca>
Yeah, that was the primary reason for keeping the
little NE-2 or NE-51, neon bulbs around.
[img]cid:.0[/img]
They were handy for 'sniffing' strong RF either
within a transmitter or out on the antenna. Since
then transmitters have morphed to low-voltage, high-
current architectures. The lamps won't sniff within the
circuitry but will still light up when held in close
proximity to the tip of a 1/4-wave antenna.
Haven't tried it but I suspect it will still be
limited to getting excited at 5 watts or more.
One is looking for an RF field on the order of
75 volts or more to capacitively excite these
lamps into visible activity.
The very first transmitter I built
http://tinyurl.com/4hwa2da
had an NE-2 permanently attached to the hot side
of the tank coil and could be used to tune the
transmitter. Can anyone spot a risk-issue in
this as-published diagram?
 Filesize:  5.47 KB
 Viewed:  21945 Time(s)
etienne.phillips(at)gmail
PostPosted: Tue Feb 15, 2011 7:11 am    Post subject: No click when pushing PTT Reply with quote
I'll have a stab at it - when the switch is open, the chassis sits at line voltage?
On 15 February 2011 16:49, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]    this as-published diagram?
Bob McC
PostPosted: Tue Feb 15, 2011 7:51 am    Post subject: No click when pushing PTT Reply with quote
#1 The chassis is directly connected to the line.
#2 the switch is in what is hopefully the ground side of the line.
#3 It's probably old enough that the line plug is not polarized and the chassis may be attached to the "hot" side of the line.
More than one person has been electrocuted with such a layout.
Bob McC
Date: Tue, 15 Feb 2011 08:49:32 -0600
Subject: RE: AeroElectric-List: Re: No click when pushing PTT
[img]cid:.0[/img]
 Filesize:  5.47 KB
 Viewed:  21940 Time(s)
Bob McC
Falco #908
(just starting)
PostPosted: Tue Feb 15, 2011 8:19 am    Post subject: No click when pushing PTT Reply with quote
Yup . . . you're tied for first place.
at line voltage?
Right on! I'd built a number of transformer-less
circuits where injudicious wiring and positioning
of switches could put a chassis at above ground
potentials.
Since all ham gear was expected to be well
grounded for reasons of antenna performance,
it made sense to use the SAME ground as the
power return for the device. Make the line-cord
a one-wire lead that was switched. If the
gizmo didn't power up, reverse the plug. But
in no case was the properly grounded system at
risk for presenting a shock hazard.
So called AC/DC radios popular at the time
were always housed in a wood or plastic case.
Quite often, the line-connected 'ground' within
the appliance was floating from the chassis.
When launching a line-powered, transformer-less
DIY project, it was good to understand such
things.
Good eye!
Float Flyr
PostPosted: Tue Feb 15, 2011 12:19 pm    Post subject: No click when pushing PTT Reply with quote
I’ll take a stab at it.
The crystal and the heater for the tube are both powered by 115VAC.
Considering the potential instability in both the voltage coming from the wall and possible changes in the frequency of the AC current it may be a bit edgy.
Noel
Now give us the real reason. Please!
Noel
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: February 15, 2011 11:20 AM
Subject: RE: Re: No click when pushing PTT
 Filesize:  5.47 KB
 Viewed:  21932 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Tue Feb 15, 2011 12:40 pm    Post subject: No click when pushing PTT Reply with quote
Certainly a short across the 1 muff cap could cause that.
Noel
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Etienne Phillips
Sent: February 15, 2011 11:35 AM
Subject: Re: Re: No click when pushing PTT
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Tue Feb 15, 2011 1:01 pm    Post subject: No click when pushing PTT Reply with quote
Many years ago I had a radio/Amplifier which the chassis could be hot if it was plugged in that way you would get a terrible AC hum from the speakers... I always put it down to the shielding on the tubes being hot. Yes I did get several good roots from that thing until I realized that turning the plug around removed the AC hum.
Noel
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob McCallum
Sent: February 15, 2011 11:46 AM
Bob McC
 Filesize:  5.47 KB
 Viewed:  21925 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
N777TY
PostPosted: Tue Feb 15, 2011 8:32 pm    Post subject: Re: No click when pushing PTT Reply with quote
Y'all lost me there Smile
Anyways, back to square one. The radio works just fine... it's been installed for a little over 2 years and never had issues communicating with anyone (even distant facilities). I acquired the plane last summer and this click was never there.. so I can only assume it was like this from day one.. but have no way of confirming this.
For clarification -- this is a certified plane that's been flying for a long time.. not a homebuilt sitting in my garage.. This radio allows me perfectly normal "5 by 5" communication with anyone on frequency.. there have never been any issues with clarity nor strength of normal voice transmission.. It just doesn't click... that's all.
RV-7A
N777TY
deej(at)deej.net
PostPosted: Wed Feb 16, 2011 7:48 am    Post subject: No click when pushing PTT Reply with quote
I've been trying to figure out what this "click" is that you indicate
happens on COM1. I don't remember ever getting a click on the radios
I've used. Even new solid state handhelds will trigger the runway
lighting, and they (or at least mine) doesn't make any noise at all when
pressing the transmit button, and I do not remember an audible click
being heard on a receiving radio when transmitting on the handheld.
I have no real data to back this statement up, but my gut tells me that
the "click" or lack of is simply a red herring and has nothing to do
with being able to activate the runway lights.
Just a passing thought, have you tried to activate the runway lights
with this radio at a different airport? Just wondering if there might
be something a bit off with the receiver at your local airport that
might be causing the issue.
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Please use Netiquette Guidelines http://tools.ietf.org/html/rfc1855
Kindly TRIM your email replies and post AFTER the relevant text
Goto page 1, 2  Next
Page 1 of 2
