Plastic gas tank grommets, etc
cristalclear13
PostPosted: Mon Feb 14, 2011 1:20 pm    Post subject: Plastic gas tank grommets, etc Reply with quote
While putting in my new battery I had to take out my gas tanks since my battery is at the back of the cage. I cleaned out the plastic gas tanks but then noticed that the metal fuel thing-a-ma-jig where the gas comes out is really rusted.
I see that jbm industries sells the grommet but who sells the metal thing-a-ma-jig that the grommet goes around?
Next question...how to get it out and back in? There is no way I can reach through the opening of the gas tank to work on it (too small and too far of a reach)...does it just pull out with force through the hole and then force it back in with the new grommet and metal thing-a-ma-jig (yes you can correct me to what it is actually called).
Thanks!
 Filesize:  335.46 KB
 Viewed:  4547 Time(s)
 Filesize:  134.7 KB
 Filesize:  30.56 KB
Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009
rickofudall
PostPosted: Mon Feb 14, 2011 1:50 pm    Post subject: Plastic gas tank grommets, etc Reply with quote
Cristal, This is probably what you have.http://www.aircraftspruce.com/catalog/appages/ffelbow.php
[/url]A PITA to remove, especially with the tank in place, more so if the grommet has age hardened. Basically it's an Armstrong removal. Support the area around the grommet as you pull the barbed fitting out so you don't damage the tank. Twisting as you pull helps. Coat the new fitting with some lithium grease when installing.
Rick Girard
On Mon, Feb 14, 2011 at 3:20 PM, cristalclear13 <cristalclearwaters(at)gmail.com (
cristalclearwaters(at)gmail.com)> wrote:
--> Kolb-List message posted by: "cristalclear13" <cristalclearwaters(at)gmail.com (cristalclearwaters(at)gmail.com)>
Thanks!
Cristal Waters
Kolb Mark II Twinstar Rotax 503 DCSI  Sept 2007
[url=http://forums.matronics.com/viewtopic.php?p=331061#331061]http://forums.matronics.com/viewtopic.php?p=331061#331061
http://forums.matronics.com//files/plastic_gas_tank_grommet_3_211.jpg
http://forums.matronics.com//files/plastic_gas_tank_grommet_2_130.jpg
http://forums.matronics.com//files/plastic_gas_tank_grommet_1_207.jpg
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
sspence801(at)sbcglobal.n
PostPosted: Mon Feb 14, 2011 1:51 pm    Post subject: Plastic gas tank grommets, etc Reply with quote
Just pull it out, when you get it out you will be able to clearly see how the elbow presses the grommet out to seal the fitting.
Steve Spence
Mk3X-tra
Auburn Hills, MI
From: cristalclear13 <cristalclearwaters(at)gmail.com>
Sent: Mon, February 14, 2011 4:20:37 PM
Subject: Plastic gas tank grommets, etc
Thanks!
Cristal Waters
cristalclear13
PostPosted: Mon Feb 14, 2011 2:21 pm    Post subject: Re: Plastic gas tank grommets, etc Reply with quote
Thank you Rick and Steve. If I don't have the strength to do it, I'll find someone who does! Smile
Cristal Waters
neilsenrm(at)gmail.com
PostPosted: Mon Feb 14, 2011 2:26 pm    Post subject: Plastic gas tank grommets, etc Reply with quote
Cristal
That thing-a-jig is called a in tank elbow in the Lockwood catalog. Grab the elbow with a pair of pliers and twist it while pulling and it will come out. I recommend you get replacements that have the finger strainer and a shut off valve. Be sure to lube the elbow before installing the new elbow in the bushing
Also my ELT remote doesn't have a battery that I know of. I think it is powered by the main unit that my remote is wired to.
Rick Neilsen
Redrive VW Powered MKIIIC
On Mon, Feb 14, 2011 at 4:20 PM, cristalclear13 <cristalclearwaters(at)gmail.com (cristalclearwaters(at)gmail.com)> wrote:
[quote]--> Kolb-List message posted by: "cristalclear13" <cristalclearwaters(at)gmail.com (cristalclearwaters(at)gmail.com)>
Thanks!
Cristal Waters
ption,
www.matronics.com/Navigator?Kolb-List" target="_blank">http://www.matronics.com/Navigator?Kolb-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
