Gascolator
Goto page Previous  1, 2, 3, 4  Next
Lynn Matteson
PostPosted: Mon Feb 14, 2011 6:51 am    Post subject: Gascolator Reply with quote
As low as it can go, and the sump drain is poised just above the
bottom fabric. I reinforced the fabric with a plastic floor flange of
the appropriate size. My fuel line (3/8" automotive 30R7) runs under
the seat, and forward through the middle of the plane.
Lynn Matteson
Jabiru 2200, #2062
Sensenich 62"x 55.5 Wood
Prince prop (64 x 30, P-tip) is here, but not installed yet
Rotec TBI-40 injection (sleeved to 35mm)
Status: flying...1081 hrs (since 3-27-2006)
On Feb 14, 2011, at 7:19 AM, WurlyBird wrote:
<james.t.trizzino(at)us.army.mil>
Noel, I have that same header tank on my III and am not a huge fan
of it either. I have mentioned in earlier posts that I am going to
re-do the fuel system in my Fox once I get home and that is one of
the things I am going to change. I am just now remembering that I
did not put that on the list of things that I JUST ordered from the
McBeans, I wonder if I can get to them before they ship.
To those that have the header behind the seat and use this as the
lowest point in the system; How low do you have it on the seat?
For those of you that use this tank as the "gascolator", how do you
get your sample, do you have it close to the floor so you can get a
fuel sample from under the aircraft or do you have to reach behind
the seat and risk a spill in the tail? Do you then run the fuel
lines under the doors? I think this may be how I would like to set
mine up. Sump through the bottom fabric and fuel under the door, I
already have a gascolator on the firewall so I may just leave that
one. Ponder, ponder, ponder.
James
Kitfox 3 / 582 / 70&quot; IVO 2 blade GA
50 hrs on the Fox in between deployments,
now she lies in wait
Re
Lynn
Kitfox IV-Jabiru 2200
N369LM
Float Flyr
PostPosted: Mon Feb 14, 2011 7:36 am    Post subject: Gascolator Reply with quote
I had a closer look at my header tank the other day and the outlet is on the
bottom of the tank. However the bottom of the tank is flat so a little
moisture could lurk in it... not enough to flood my gascolator though. The
beauty of my system is the regardless of whether my plane is sitting on
three wheels, tail low or up on its floats my gascolator is always the
physical lowest part of my fuel system.
I was thinking about all the guys who told me they like being able to see
the fuel run through their clear cartridges in the cabin. Well a drip loop
of clear tube will do the same thing.... better than that a glass
gascolator in the lines from the wing tanks to the header will be even
better because it would give you the option of another clean out if you do
happen to see any gunk coming down the line. A gascolator also doesn't have
a any paper which can expand with water and block fuel flow. It is true
that if you are using ethanol contaminated fuel your paper filters should
never get water wet except in the case of a phase separation which will stop
any engine... filters or not.
I really don't want to get started on the evils of ethanol again. Suffice
it to say I'd like to see everyone lay it on the powers to be whether or not
they want to fly, drive or boat on that fuel. Remember it's the squeaky
wheel that gets the grease.
I've flown in and worked on several kinds of Cessna, Piper, Lake, De
Havilland and homebuilt aircraft and none of them ever had a paper filter
near the fuel system. I don't think I would feel nearly so confident in my
plane with a filter that could quickly block the flow of fuel. The
gascolator however will screen anything that could affect the engine without
the same blockage issues.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Guy Buchanan
PostPosted: Mon Feb 14, 2011 9:49 am    Post subject: Gascolator Reply with quote
On 2/14/2011 4:19 AM, WurlyBird wrote:
To those that have the header behind the seat and use this as the lowest point in the system; How low do you have it on the seat?
The bottom of the plastic tank is 2" above the fabric. My header tank is
behind the passenger seat bulkhead, not in front as Kitfox designed it,
and as close to the right side of the fuselage as the level fitting will
allow. (My fuel level indicator is in the side.) Having it behind made
it easier to run lines.
For those of you that use this tank as the "gascolator", how do you get your sample, do you have it close to the floor so you can get a fuel sample from under the aircraft or do you have to reach behind the seat and risk a spill in the tail?
The quick-drain pierces the fabric just as it does in the wing tanks. I
have a 2" aluminum tube extension from the tank to the drain.
Do you then run the fuel lines under the doors?
Single 3/8" aluminum fuel line runs around the passenger seat to the
right and then back to centerline. Don't know why I did it that way,
except to make it easy to mount and service the mondo automotive fuel
filter I use. It was also pretty crowded around the flap and elevator
control rods and bungees. (Yes, I still use bungees.) If you don't use
bungees I'd run the fuel right up the middle.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 592-C / Warp 3cs / 500 hrs. and grounded
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
ronlee
PostPosted: Tue Feb 15, 2011 10:14 am    Post subject: Re: Gascolator Reply with quote
My experience with outboard boat engines has proved that a leak before the fuel pump will cause an engine stoppage in short order. If you are pulling fuel from a tank on the bottom of a boat a very small leak in the line will suck in air and the engine will starve for fuel. Believe me the leak does not have to be very big either. Anything that will cause a slight vacuum on the suction side of your fuel pump is a prescription for engine stoppage should any leak develop. I agree we fly experimental and can do anything we wish. Some techniques though are better followed that have a proven track record.....
Ron Lee
Tucson, Arizona
Tommy Walker
PostPosted: Tue Feb 15, 2011 1:25 pm    Post subject: Re: Gascolator Reply with quote
Ronlee
I agree with you. All car manufacturers, as far as I know, have moved the fuel pump to the gas tank now. I believe it is because it is better to push fuel than it is to suck it. Remember when the fuel pump was driven by an engine mounted mechanical pump?
There was an excellent topic on this in the Matronics Zenith list several years ago. One of the things mentioned to prove this was, take two straws, place one in a glass of water and the other outside the glass. Put both straws in your mouth and suck.... Guess which one has the least amount of friction? So, it seems that pushing, instead of sucking, is the best method for moving fuel through a line. I don't have the exact quote on this example, but I could probably find it if anyone is interested.
Tommy Walker
N25A - Anniston, AL
Float Flyr
PostPosted: Tue Feb 15, 2011 3:39 pm    Post subject: Gascolator Reply with quote
Having the pump in the tank to push the fuel is a great idea but there is
another reason. The gas is also a great cooling device for the pump. That
means the pumps last longer and works more efficiently.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
I forgot to say that some of those pumps attain 60 psi pressure on the line
to feed EFI systems and they have no filters between them and the gas...
only a screen to keep the lumps out. As an added feature the pumps usually
are integrated with the tank float for the fuel gauge. I've yet to hear of
a tank exploding because of the pump.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
WurlyBird
PostPosted: Sun Mar 20, 2011 6:17 pm    Post subject: Re: Gascolator Reply with quote
I have been working on the new header tank, among other things, and I have a couple more questions about it.
First it seems that all components used for my fuel system is 1/4" so I am going to replace the two in barbs with 1/4". Is there something wrong with this? Hope not.
I am also looking at the blue elbow which leads to the engine from the header. I am familiar with compression fittings but I can not figure this one out. What size tubing goes into this nipple? None of the tubing I have seems to fit and it is 1/4" aluminum. Also, I can not for the life of me find the 'nut' needed to complete the compression fitting. I have searched on Aircraft Spruce for over an hour and gone through the builders manual and can not find the name of this part.
Someone please help.
James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl.
Guy Buchanan
PostPosted: Sun Mar 20, 2011 8:20 pm    Post subject: Gascolator Reply with quote
I used 3/8 for my feed lines to minimize losses.
I hope someone else can figure out what you're asking, because without
pictures I can't. If nobody else replies shoot some pictures or
reference some manual pages / pictures and I'll try to help.
Guy Buchanan
Ramona, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
lcfitt(at)sbcglobal.net
PostPosted: Sun Mar 20, 2011 8:48 pm    Post subject: Gascolator Reply with quote
James,
If you are looking at the typical factory fitting, it is for 5/16 tubing and
the parts you are looking for are as follows:
AN818-5D "Nut"
An819-5D "Sleeve
You will need one of each for each connection. don't forget that you will
need them at the fuel valve as well as the termination of the aluminum line
at the firewall. My system includes the compression fitting at the header
tank, two at the fuel pump, two at the fuel valve and one that runs to a
hose barb just forward of the firewall. I just finished my new project
system and am well aware of the frustration finding parts - lots of bushings
to change pipe thread diameters etc. Also keep in mind that aircraft
compression fittings use a different angle of the flair than the typical
hardware type - as I understand it, the typical AN fitting we use has a 45°
flair and the hardware store fitting flair is 37°.
If your fitting happens to be for 1/4" tubing, then the suffix would be 4D
on both. On the Model IVs the wing tank to header tank tubing was typically
5/16", however I know of guys that have changed to 1/4" throughout the
system and have flown hard with no fuel flow issues. If you are running the
582, you might think about 5/16 as the fuel consumption is a bit higher than
the 912.
Lowell
From: "WurlyBird" <james.t.trizzino(at)us.army.mil>
Sent: Sunday, March 20, 2011 7:17 PM
Subject: Re: Gascolator
James
http://forums.matronics.com/viewtopic.php?p=334557#334557
WurlyBird
PostPosted: Mon Mar 21, 2011 3:03 am    Post subject: Re: Gascolator Reply with quote
Unfortunately the builders manual for the 3 does not go into great detail with the fuel system, which is probably why the guy that built mine had it so oddly set up. I am running a 582 and the current fuel set up runs strictly 1/4" and I have had no issues. It is not until I got this header tank that it was brought to my attention that this wasn't normal. The way my fuel system is now it is 1/4" aluminum tubing under the seat and into the fire wall, but any where there needs to be flex or a fitting there is a section of rubber fuel tubing. Hopefully I can get this sorted out with out too much trouble. thanks for the help, and here is a picture of the fitting I am talking about.
 Filesize:  36.85 KB
 Viewed:  14219 Time(s)
James
helili(at)chahtatushka.ne
PostPosted: Mon Mar 21, 2011 3:53 am    Post subject: Gascolator Reply with quote
I think this is probably what he's talking about:
http://www.aircraftspruce.com/menus/ha/an.html
John Hart
KF IV
Wilburton, OK
Lynn Matteson
PostPosted: Mon Mar 21, 2011 4:44 am    Post subject: Gascolator Reply with quote
Aviation fittings are 37°, and hardware store stuff is 45°, Lowell.
Lynn Matteson
Jabiru 2200, #2062
Status: flying...1089 hrs (since 3-27-2006)
Temp. grounded...building new intake manifold.
On Mar 21, 2011, at 12:45 AM, Lowell Fitt wrote:
<lcfitt(at)sbcglobal.net>
James,
(snip)
(snip)
Lowell
Lynn
N369LM
Pat Reilly
PostPosted: Mon Mar 21, 2011 7:22 am    Post subject: Gascolator Reply with quote
Wurleybird, I have a mod 3 582 with 1/4" plastic lines to plastic header tank behind seat and aluminum line from header to valve under the panel, and hose connecting aluminum tube to valve and from valve through firewall. The only problem I encountered was getting fittings in that plastic header to seal up. I tried everything with no success until someone on this site recommended Dow 730 sold by Aircraft Spruce. It sealed up on 1st try with no sign of a leak. The only draw back and reason why I tried everything else 1st is the damn stuff is $100 for a 3 oz tube. I used about $2 worth on the fittings and still have the tube in the refrigerator a year latter. Wife hasn't complained about that use of the refrigerator once. She was much more upset the day she called me after she found a skunk in the freezer compartment that I was intending to skin out for a hat for the grandkids. Since I do all the cooking why would she be in the freezer anyway? She asked, "Is there a dead animal in our freezer?" I replied, "Sure there are alot of dead animals, pigs, cows, chickens and fish too. Why do you ask?" "No, I mean with black hair still on it". The conversation went downhill from there. But, alls well that ends well. We are still married. Although come to think of it she is my 2nd wife. Had to divorce the 1st one. It was all her fault. She absolutely refused to get along with my girl friend.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Mon, Mar 21, 2011 at 6:03 AM, WurlyBird <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)> wrote:
--> Kitfox-List message posted by: "WurlyBird" <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)>
James
http://forums.matronics.com/viewtopic.php?p=334568#334568
http://forums.matronics.com//fil
y Browse, Chat, FAQ,
="http://www.matronics.com/Navigator?Kitfox-List" target="_blank">http:=====
http://forums.mle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
PostPosted: Mon Mar 21, 2011 7:34 am    Post subject: Gascolator Reply with quote
Lynn,
I stand corrected. The point I was trying to make is that the Ace Hardware
flairing tool, is not the one to use for AN Fittings.
My bad.
Lowell
Sent: Monday, March 21, 2011 5:42 AM
Subject: Re: Re: Gascolator
Lynn Matteson
Jabiru 2200, #2062
> James,
(snip)
> - as I understand it, the typical AN fitting we use has a 45° flair and
(snip)
> Lowell
Pat Reilly
PostPosted: Mon Mar 21, 2011 7:36 am    Post subject: Gascolator Reply with quote
Wurlybird, I saw that fitting in your other post. I believe it was a flare fitting. I don't kow what size aluminum tubing you need. And, off the top of my head, I don't know what size mine uses. I have a similar fitting out of my header tank with aluminum tubing.  1/4" rubber fuel hose is a very tight fit over the aluminum tubing. Guess that would be 1/4" aluminum tubing.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Sun, Mar 20, 2011 at 9:17 PM, WurlyBird <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)> wrote:
James
http://forums.matronics.com/viewtopic.php?p=334557#334========================
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Pat Reilly
Wurleybird, Those AN flare fittings are available from most streetrod or race car parts suppliers also, Summit Racing, Jegs, etc.
Pat reilly
Mod 3 582 Rebuilt
Rockford, IL
On Mon, Mar 21, 2011 at 6:50 AM, John W. Hart <helili(at)chahtatushka.net (helili(at)chahtatushka.net)> wrote:
[quote]--> Kitfox-List message posted by: "John W. Hart" <helili(at)chahtatushka.net (helili(at)chahtatushka.net)>
John Hart
KF IV
Wilburton, OK
Tom Jones
PostPosted: Mon Mar 21, 2011 7:58 am    Post subject: Re: Gascolator Reply with quote
I sense a little confusion on the aluminum fuel line size. Hard line tubing is measured as Outside Diameter (OD). I suspect the aluminum tubing here is 5/16" OD so fittings would be sized as such. The early kitfox kits I am familiar with came with 5/16 OD aluminum tubing fuel line.
James, if you change any fittings be sure to check their inside diameter. Some have a tiny...about 1/8"...ID, especially 1/4 inch fittings.
The only way to be sure if fuel flow is sufficient is to do a flow rate test at the fuel pump level. Do two. One in level attitude and one with nose high.
Tom Jones
Classic IV
Ellensburg, WA
Pat Reilly
PostPosted: Mon Mar 21, 2011 8:35 am    Post subject: Gascolator Reply with quote
Tom, Thanks for the clarification. I can force 1/4" rubber fuel line on the aluminum tubing from the header. It is definitely a "force fit" though, 5/16" OD tubing would make sense.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Mon, Mar 21, 2011 at 10:58 AM, Tom Jones <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)> wrote:
--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)>
I sence a little confusion on the aluminum fuel line size.  Hard line is measured as Outside Diameter (OD).  I suspect the aluminum tubing here is 5/16" OD so fittings would be sized as such.  The early kitfox kits I am familiar with came with 5/16 OD aluminum fuel line.
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=334612#334612
ist Un/Subscription,
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Guy Buchanan
PostPosted: Mon Mar 21, 2011 10:40 am    Post subject: Gascolator Reply with quote
What's interesting is that your previous post talked about "compression" fittings. Please don't be offended if I'm way off the mark; at the risk of insulting you I'll tell you that what you photographed is a flare fitting. A compression fitting uses a sleeve over the tube that gets "compressed" onto the tube by a nut and female receptacle compressing the wedges surfaces of the sleeve. In a flare fitting the end of the tube is flared after a nut and sleeve are put on and the flare simply rests against the cone you see on your "nipple". You'll need an aircraft flare fitting to match the AN hardware, as Lynn and Lowell said, as plumbing hardware is different. Google "flare fitting" and "compression fitting" and you'll see pictures showing the difference. Hope that helps.
Guy Buchanan Normal Guy Buchanan 8 20 2010-09-24T17:53:00Z 2011-01-02T22:52:00Z 1 25 149 1 1 173 14.00 <![endif]--> 59 Clean Clean false false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} <![endif]--> <![endif]--> <![endif]-->Guy Buchanan
Ramona, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Page 2 of 4
