jan_de_jong(at)casema.nl Guest
Posted: Fri Feb 11, 2011 2:55 am Post subject: Battery disconnect switch |
Please have a look at:
http://www.tycoelectronics.com/prodimages/pdf/130-C.pdf
Latching switch.
Takes no continuous current.
Takes 50ms pulse of 2.5A instead.
Carries 190A. max. 1800A.
Switches 100A.
Weighs a little over half a S701-1.
Costs a little over double a S701-1.
Apart from the trouble of having to make a nice reliable pulse -
is this an attractive option?
Jan de Jong
Posted: Fri Feb 11, 2011 7:23 am Post subject: Battery disconnect switch |
At 05:50 AM 2/11/2011, you wrote:
Interesting find! This is but one example
of many that we can expect to come over
the horizon. This one is interesting in that
it's not a solid-state switch. Doing a tear-down
to see how it's assembled would be a great
education.
Lamar has had a solid-state contactor out for
some time. I've heard nothing about it's
utility or performance from users in the field.
An engineer at Lamar was going to send me a
sample but I think it slipped his mind. I
think I'll hit him up again. I thought I might
add a battery master switch to my pickup truck
and use the feature to put some real-time service
on products like these.
Jan, have you attempted to locate a stocking
distributor for this device? Any notion on
what it costs?
Posted: Fri Feb 11, 2011 7:55 am Post subject: Battery disconnect switch |
| Quote: | Jan, have you attempted to locate a stocking
what it costs?
Here it is . . .
http://www.alliedelec.com/search/productdetail.aspx?SKU=8860610
If I didn't already have a couple dozen
things on the to-do list, I'd run right out
an buy one. That will have to wait.
Given that it's a Tyco product and designed
for integration into automotive (worse than
airplanes) service, this looks like a really
interesting, low-risk product.
CAUTION: This is a set-reset, two-coil
latched device. Unlike legacy contactors,
it takes POWER to turn it on. It also takes
POWER to turn it off.
This is not necessarily a show-stopper but
you need to figure out how it changes your
master switch wiring/switch selection -and-
how it might affect some abnormal operating
situation.
This is NOT a drop-in, plug-n-play substitution
for the legacy contactor. The price is right
but do the substitution with some thought as
to the effects of new features added to your bag
of tricks.
JLuckey(at)pacbell.net Guest
Posted: Fri Feb 11, 2011 8:49 am Post subject: Battery disconnect switch |
.. a quick glance at the fact sheet indicates that a non-latching version
is also available...hmmmm... so why do we (I) want one?
1. includes coil spike-suppression diodes
2. looks cool
3. Price is not bad
It's only a little more expensive than the "standard" can-shaped solenoids
http://www.aircraftspruce.com/catalog/elpages/masterrelay.php.
Mounting will be different.
If we use the latching capability, does is make circuitry simpler, more
reliable, better, stronger, faster, (will it help prevent icing? - sorry,
couldn't resist
I'm w/ Bob, definitely needs more noodling..
-Jeff
Posted: Fri Feb 11, 2011 11:12 am Post subject: Battery disconnect switch |
In Europe RS sells the switch for £38.27 and €46,29 -, a lot more than
Allied. And VAT of 20% or so not yet included either!
The plug needed is Tyco 184046-1 with A key (there are A .. D keys) and
is hard to find.
I found only one retail source:
http://www.newunitedracetech.com/shop/index.php?main_page=product_info&cPath=1_15_24&products_id=6114
They charge $2.70.
To be able to use it as a normal on-off switch I am thinking of an
adapter with 3 input pins - ground, power and switch - and the required
4-pin Tyco plug as the output.
Switch to power (from open or ground) would generate an ON pulse, switch
to ground (from open or power) would generate an OFF pulse, switch to
open (from ground or power) would not do anything.
If ever no switching action results when expected: repeat manually -
introducing memory and automatic repeat goes too far I think.
Jan de Jong
Posted: Fri Feb 11, 2011 11:16 am Post subject: Battery disconnect switch |
At 11:46 AM 2/11/2011, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Jeff Luckey" <JLuckey(at)pacbell.net>
2. looks cool
3. Price is not bad |
[img]cid:7.1.0.9.0.20110211130251.01da57c0(at)aeroelectric.com.0[/img]
This is a direct descendant of the RPM/Stancor/White-Rogers
series of legacy contactors. The 70-111226 is a 3-wire
12v contactor with one coil internally attached to the
'BAT' terminal. It's the same class of contactor we've
been using in small airplanes for many, many moons.
66.99 KB |
18079 Time(s) |
Posted: Fri Feb 11, 2011 11:20 am Post subject: Battery disconnect switch |
| Quote: | To be able to use it as a normal on-off switch I am thinking of an
required 4-pin Tyco plug as the output.
switch to ground (from open or power) would generate an OFF pulse,
switch to open (from ground or power) would not do anything.
Another thought. The coil resistance is stated as 4.7 ohms.
This translates to a coil draw on the order of 2.5 amps
while energized. The specs also state 100 mS max for transfer
pulse. This means that you probably have to device control
circuitry that LIMITS control inputs to input pulses having
a fixed and limited duration.
klehman(at)albedo.net Guest
Posted: Fri Feb 11, 2011 11:45 am Post subject: Battery disconnect switch |
4. no continuous coil current for small electric systems
5. wider temperature limits
6. higher current silver contacts
7. they seem to be implying 42 volt disconnect capability which might
make it better for OVP
8. might be acceptable to run electric dependent engine supply through
it whereas I will not do that with the "standard" can-shaped contactor.
9. not subject to damage if the connector bolts turn during installation.
Cons
1. more difficult connections involving extra bolts and a specific
connector that will need to be sourced.
2. more difficult to mount and insulate connections from a metal airframe.
3. ??
On 2/11/2011 11:46 AM, Jeff Luckey wrote:
... a quick glance at the fact sheet indicates that a non-latching version
2. looks cool
3. Price is not bad
couldn't resist
-Jeff
Float Flyr
Posted: Fri Feb 11, 2011 1:08 pm Post subject: Battery disconnect switch |
Bob do you normally run your starter through this contactor?
Noel
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: February 11, 2011 2:42 PM
Subject: RE: Battery disconnect switch
2. looks cool
3. Price is not bad
66.99 KB |
18077 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Fri Feb 11, 2011 2:25 pm Post subject: Battery disconnect switch |
At 04:05 PM 2/11/2011, you wrote:
| Quote: | Bob do you normally run your starter through this contactor?
Sure. It's been done in a couple hundred thousand
airplanes for 70 years.
This contactor doesn't have to SWITCH starter current,
only CARRY it. Not a big deal
Posted: Fri Feb 11, 2011 4:12 pm Post subject: Battery disconnect switch |
through it whereas I will not do that with the "standard" can-shaped contactor.
I might repeat a past recommendation that stuff needed
to keep an engine lit should probably run directly from
a battery bus.
Posted: Sat Feb 12, 2011 7:27 am Post subject: Battery disconnect switch |
On 2/11/2011 3:18 PM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
I know that's conventional wisdom. But isn't it also conventional wisdom
that one reason starter current is routed through the main contactor is
so that in the event of a stuck starter contactor, the starter can be
disabled using the main contactor? Is the logic that the main contactor
only has to do it *once*?
Posted: Sat Feb 12, 2011 8:34 am Post subject: Battery disconnect switch |
| Quote: | > This contactor doesn't have to SWITCH starter current,
| Quote: | I know that's conventional wisdom. But isn't it also conventional
wisdom that one reason starter current is routed through the main
contactor is so that in the event of a stuck starter contactor, the
starter can be disabled using the main contactor?
Yes . . .
| Quote: | Is the logic that the main contactor only has to do it *once*?
. . . or never. I've never experienced a
stuck starter contactor. I've only been aware of
a few incidents where B&C customers suffered
the event without benefit of back up for killing
power to the starter. Neither even destroyed the
starter but one really melted the battery box
case.
Remember that contactor service life predictions
are based upon switching certain kinds of loads
usually in a laboratory environment. Hence the
wide variation in 'ratings' for a switch or contactor
that control incandescent lamps, DC motors, windshield
de-ice heaters, etc. But in no case do we see switches
or contactors offered with less than THOUSANDS of
cycles at their various 'rated' loads.
So the notion that a 70A rated contactor (70
series RPM/Stancor/White-Rogers) is in mortal
danger for having interrupted a 200A stuck
starter once, twice or even a few dozen times
is not supported by experience or physics.
Having said that, there IS a situation where
an el-cheepo contactor is at much greater risk
for opening a out-of-ratings load. Figure Z-24
proposes controlling the b-lead of a runaway
alternator. If the voltage rises fast enough
during contact spreading, there is a risk
of sustained arcing between the fully spread
contacts. This is one case where the contactor
might experience a one-time event that leads
to it's destruction. But better it's a $25 contactor
than more valuable/useful system components.
Speedy11(at)aol.com Guest
Posted: Sat Feb 12, 2011 5:06 pm Post subject: Battery disconnect switch |
The device is very noisy (86db) so you'd probably want to mount it somewhere where the noise is not bothersome.
Stan Sutterfield
In a message dated 2/12/2011 3:09:20 A.M. Eastern Standard Time, aeroelectric-list(at)matronics.com writes:
| Quote: | ... a quick glance at the fact sheet indicates that a non-latching version
2. looks cool
3. Price is not bad
couldn't resist
-Jeff
Float Flyr
Posted: Sat Feb 12, 2011 7:54 pm Post subject: Battery disconnect switch |
Always mount disconnect switches as close to the battery as possible. Cessna actually mounts theirs on the battery box (C-180) They also mount the relay for ground power on the box.
Noel
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com
Sent: February 12, 2011 9:34 PM
Subject: Re: Battery disconnect switch
Stan Sutterfield
2. looks cool
3. Price is not bad
couldn't resist
-Jeff |
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 01234567
Kitfox III-A
Posted: Sat Feb 12, 2011 11:08 pm Post subject: Battery disconnect switch |
Stan,
Not sure what you mean by noisy. Can you be more specific?
- Is the noise continuous?
- Is this device any noisier than the traditional solenoid?
- Have you done some kind of testing or do you have you worked w/ this device?
TIA,
-Jeff
Sent: Saturday, February 12, 2011 17:04
Stan Sutterfield
2. looks cool
3. Price is not bad
couldn't resist
-Jeff |
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
Posted: Sun Feb 13, 2011 7:36 pm Post subject: Battery disconnect switch |
Jeff,
What I mean by noisy is 86 dB. That is the noise generated by the device as listed on the Tyco web site.
86 dB, while not immediately damaging to hearing, is very loud and can damage hearing if experienced over time.
I wasn't referring to "noise" that would interfere with radio transmissions.
1. I don't know if the noise is continuous. Check with Tyco.
2. My experience with contactors normally used in aircraft is that the only significant noise generated is when the contactor is initially excited and the noise is the mechanical movement rather than an electrical noise. Thus, if the Tyco web site information is correct and if the noise is continuous, then my estimate is that the Tyco device is noisier than traditional solenoids.
3. No.
Stan Sutterfield
In a message dated 2/13/2011 3:01:45 A.M. Eastern Standard Time, aeroelectric-list(at)matronics.com writes:
| Quote: | Not sure what you mean by noisy. Can you be more specific?
1. Is the noise continuous?
2. Is this device any noisier than the traditional solenoid?
3. Have you done some kind of testing or do you have you worked w/ this
device?
Posted: Sun Feb 13, 2011 8:26 pm Post subject: Battery disconnect switch |
Stan,
I thought you were referring to electrical noise and thus was a little confused. I’m certain that it is not a continuous noise – just a single “thunk” or loud click when switching. The mechanical noise it makes when switching has never been a design criteria for me. (we aren’t talking about nuclear submarines here;).
Thanks for the clarification.
Sent: Sunday, February 13, 2011 19:29
Jeff,
3. No.
Stan Sutterfield
device? |
royalina
Posted: Wed Feb 16, 2011 10:01 pm Post subject: Re: Battery disconnect switch |
_________________ Diablo 3 Gold|Diablo 3 News|Diablo 3 Accounts |
