Auto oil filter for 912?
lloydeggstaff(at)gmail.co
PostPosted: Thu Feb 10, 2011 9:59 am    Post subject: Auto oil filter for 912? Reply with quote
I recall seeing listed an auto oil filter that can be used on the Rotax 912. Does anyone have that part number? [quote][b]
Tommy Walker
PostPosted: Thu Feb 10, 2011 10:39 am    Post subject: Re: Auto oil filter for 912? Reply with quote
[quote="lloydeggstaff(at)gmail.co"]I recall seeing listed�an auto oil filter that can be used on the Rotax 912. Does anyone have that part number?
I am going to try attaching a word document to this reply. It was written by Roger Lee in AZ who is a Rotax Maintenance Rated Repairman. It tells what and what not to use for the 912.
Tommy
Oil Filters.doc
 Filename:  Oil Filters.doc
 Filesize:  34 KB
 Downloaded:  866 Time(s)
Tommy Walker
N25A - Anniston, AL
PostPosted: Thu Feb 10, 2011 11:06 am    Post subject: Auto oil filter for 912? Reply with quote
Was not able to download the word document.
On Thu, Feb 10, 2011 at 8:39 AM, Tommy Walker <twalker(at)cableone.net (twalker(at)cableone.net)> wrote:
[quote]--> Kitfox-List message posted by: "Tommy Walker" <twalker(at)cableone.net (twalker(at)cableone.net)>
Tommy
Tommy Walker
N8701  -  Anniston, AL
http://forums.matronics.com/viewtopic.php?p=330481#330481
http://forums.matronics.com//==
Download, 7-Day Browse, Chat, FAQ,
ef="http://www.matronics.com/Navigator?Kitfox-List" target="_blank">htt======
Tommy Walker
PostPosted: Thu Feb 10, 2011 11:18 am    Post subject: Re: Auto oil filter for 912? Reply with quote
Lloyd, I just emailed the document to you at lloydeggstaff(at)gmail.com.
Let me know if you don't get it.
Tommy Walker
N25A - Anniston, AL
lcfitt(at)sbcglobal.net
PostPosted: Thu Feb 10, 2011 12:40 pm    Post subject: Auto oil filter for 912? Reply with quote
Tommy,
Thanks for the info. It came through fine here. Maybe it needs an later
version MS Word.
Lowell
Sent: Thursday, February 10, 2011 10:39 AM
Subject: Re: Auto oil filter for 912?
number?
> [b]
Tommy
Tommy Walker
http://forums.matronics.com//files/oil_filters_179.doc
Tommy Walker
PostPosted: Fri Feb 11, 2011 9:11 am    Post subject: Re: Auto oil filter for 912? Reply with quote
You're welcome!
lcfitt(at)sbcglobal.net wrote:
Tommy,
version MS Word.
Lowell
To: <kitfox>
Very Happy Very Happy
Tommy Walker
N25A - Anniston, AL
Tucsonchris
PostPosted: Fri Feb 18, 2011 6:49 am    Post subject: Re: Auto oil filter for 912? Reply with quote
FYI, the Purolator PureOne PL 10241 recommended is too tall to fit under the stock Kitfox exhaust, Bought one, tried it. I'd have to take the exhaust off each time and it doesn't look like that would be fun.
Chris G.
Tucson, Arizona
Marana Regional Airport
Kitfox SS
912s
jerrytex
PostPosted: Fri Feb 18, 2011 2:11 pm    Post subject: Re: Auto oil filter for 912? Reply with quote
I ran into the same problem with the Purolator being to tall. I went with the Napa Gold.
Roger Lee
PostPosted: Fri Feb 18, 2011 6:07 pm    Post subject: Re: Auto oil filter for 912? Reply with quote
The Pure One as the Fram are slightly less 1/2" longer than a stock Rotax filter. There are a few instances where owners have a stock exhaust that is a little too close to fit the filter in over the threaded mount. Some with stock Rotax exhaust don't have this problem and some just have different exhaust. The only way to find out is buy one and try it. Sorry there is no other way. Don't put any oil in it and you can take it back if it is a tad too long.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
pchristensen10(at)austin.
PostPosted: Sat Feb 19, 2011 8:02 am    Post subject: Auto oil filter for 912? Reply with quote
Carquest filter 85056 is exactly the same size as the NAPA 1056. It's
cheaper too.
Pete
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=331473#331473
PMorel
PostPosted: Tue Feb 22, 2011 6:59 am    Post subject: Re: Auto oil filter for 912? Reply with quote
I use NAPA 1215 Gold for my Rotax 912. I think they are about $7 each or somewhere around that price.
Paul Morel
912 Speedster
Locust Grove, GA
www.WingsAirPhotos.com
Roger Lee
PostPosted: Tue Feb 22, 2011 5:20 pm    Post subject: Re: Auto oil filter for 912? Reply with quote
Many of the different filters are made by the same company as another, but just has a different label. You cut them open and they are identical.
Roger Lee
Tucson, Az.
Cell 520-349-7056
marwynne(at)windstream.ne
PostPosted: Tue Feb 22, 2011 6:37 pm    Post subject: Auto oil filter for 912? Reply with quote
Isn't there an internal pressure relief valve. Are they all set at the
same back pressure ?
I am no expert. Just interested in the discussion.
Roger Lee
Tucson, Az.
Rotax Repair Center
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=331881#331881
Checked by AVG - www.avg.com
Roger Lee
PostPosted: Sat Feb 26, 2011 6:09 pm    Post subject: Re: Auto oil filter for 912? Reply with quote
The answer to your question is in the document posted by Tommy above.
Roger Lee
Tucson, Az.
Cell 520-349-7056
