CorvairEngines-5th bearing
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> CorvairEngines-List
John Bolding
PostPosted: Wed Jan 26, 2011 7:05 pm    Post subject: CorvairEngines-5th bearing Reply with quote
A little more homework on the subject might be helpful to understand the difference.
- The Matronics CorvairEngines-List Email Forum -
http://www.matronics.com/Navigator?CorvairEngines-List
rvickski(at)yahoo.com
PostPosted: Thu Jan 27, 2011 2:06 am    Post subject: CorvairEngines-5th bearing Reply with quote
Well I need to apologize to Mike and the list, I was a little chapped about opinions being touted as facts.Forgive my satire.
Roy
On Jan 26, 2011, at 10:02 PM, John Bolding wrote:
[quote]A little more homework on the subject might be helpful to understand the difference.
[quote]---
tigerized(at)gmail.com
PostPosted: Thu Jan 27, 2011 6:25 am    Post subject: CorvairEngines-5th bearing Reply with quote
Brother Roy!
The latest KITPLANES (finally) contains the Experimotive column I
wrote about Dan, you, and Mark. In this piece I thought I did a pretty
good job of describing the difference between the different bearing
offerings.
Let me see if I can get a PDF of the article to you, it might help
correct some of the perceptions that people hold about price being the
final determining factor.
Rick
On Thu, Jan 27, 2011 at 2:04 AM, roy szarafinski <rvickski(at)yahoo.com> wrote:
[quote] Well I need to apologize to Mike and the list, I was a little chapped about
Forgive my satire.
Roy
difference.
MRus597999(at)aol.com
PostPosted: Thu Jan 27, 2011 9:05 am    Post subject: CorvairEngines-5th bearing Reply with quote
I apologize for being misinformed. I read the Kitplane article after I visited Roy's website. It does appear he has an excellent product and is well worth the reasonable price he is asking. It has been some time since I visited the site and it looks like he has and is creating some other very excellent products for the Corvair conversion. I am still working on upgrading my 601xl airframe and am a few months away from finishing it. I was already to start on my corvair when the FAA stopped all Zenith builders in their tracks. Maybe that's a good thing. I am going to really examine Roy's 5th bearing again.
Mike Russell
In a message dated 1/27/2011 6:25:09 A.M. Pacific Standard Time, tigerized(at)gmail.com writes:
[quote]--> CorvairEngines-List message posted by: Rick Lindstrom <tigerized(at)gmail.com>
Brother Roy!
offerings.
Rick
Forgive my satire.
Roy
difference.
PostPosted: Thu Jan 27, 2011 9:47 am    Post subject: CorvairEngines-5th bearing Reply with quote
IMHO, if you're engine is already mounted and running, Dan's solution
is, indeed, "better than air" and will prevent your crankshaft from
developing a split personality.
If you're still building your engine, then I'd seriously consider
Roy's solution and take advantage of his line boring skill and his
beautifully machined, servicable bearing.
In the grand scheme of things, the difference in money spent pales
when considering that both solutions will prevent you from a forced
landing, or worse, somewhere.
Again, this is just the opinion of a loud-mouthed journalist.
On Thu, Jan 27, 2011 at 9:02 AM, <MRus597999(at)aol.com> wrote:
[quote] I apologize for being misinformed. I read the Kitplane article after I
Mike Russell
Brother Roy!
offerings.
Rick
> about
> Forgive my satire.
> Roy
> difference.
bed(at)mindspring.com
PostPosted: Thu Jan 27, 2011 10:09 am    Post subject: CorvairEngines-5th bearing Reply with quote
Don't forget to check out the Aeromax bearing. Some good pictures are on a
website www.awesometrvl.com Down at the bottom of the first page.
bed
sblack
PostPosted: Thu Jan 27, 2011 10:24 am    Post subject: CorvairEngines-5th bearing Reply with quote
It is interesting to note that pretty much all of the crank failures have
been in higher performance airplanes like the KR and Sonex (Cleanex)? The
common theory has been that this is a function of aircraft speed and rpm. I
have a pet theory (doesn't everyone?) that it is not the airplane, but the
type of flying that is doing in these cranks where 40 yrs of flying in Piets
did not. When an airplane is in level flight at low aircraft aoa both the up
and down going blades see similar blade aoas. When pulling G, such as in a
tight turn, the down going and up going blade see substantially different
blade aoa, and hence blade loading (known as P factor). This means that
every revolution is a brutal bending cycle on the prop. I know from flying
65hp champs that I tended to be a bit gentle when just tooling around. But
when flying something with a bit more "hair" it is lots of fun to bank and
yank. So I think it is the style of flying that has as much to do with the
crank failures as anything. Aerobatics would be a certain fast track to a
silent landing. As for the different 5th bearings, one would need to have
some specialized knowledge to understand the relationship between bending
loads and bearing clearance to determine the advantage of the different
options. Theoretically the line bored precision installation should be
better, but it might also be that once you have even a crude 5th bearing on
there the improvement is so vast that the benefit from the extra tolerance
is in the wash. I think anyone who says they know for sure would have to
have some hard numbers (i.e. test data) or they are just guessing. It comes
down to engineering judgement and experience and it will be a few 1000
flight hrs before this experience starts to be built up. Right now it is
fortunate that there are several different approaches being taken. If
failures start to turn up in one type then valuable knowledge will be
tained. Hopefully any design shortcomings will show up during an inspection
and not result in an incident.
Scott Black
Montreal
Jodel F11 O-200
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> CorvairEngines-List All times are GMT - 8 Hours
