New Dremel accessory
rickofudall
PostPosted: Mon Jan 24, 2011 8:57 am    Post subject: New Dremel accessory Reply with quote
A couple of months ago I was in Lowe's when I remembered I needed a package of cut off wheels for my Dremel. At the display I found they have a new cut off wheel and drive mandrel out. The old ones were fragile and used a single screw to attach the wheel to the mandrel. The new one uses a spring loaded collar on the mandrel with a positive drive key to engage the wheel. The whole thing is just plain slick. The new cut off wheels last 3 to 4 times as long as the old ones even going through alloy steel. I cut the heads off two AN 5 bolts and the wheel only lost an 1/8" off its diameter. If you go to Lowe's look carefully I found the mandrel and five wheels as a special for $15. Separately they're about $18. Just to keep this specifically Kolb related, I was removing the elevator hinge from the horizontal stabilizer of a Mk IIIX yesterday. The original builder did a poor job of drilling the holes and every one of the stainless steel pop rivets spun before the drill separated the head from the body. I used the edge of the new Dremel cut off wheel to shave the head head of the rivet until I could just see the line concentric to the center hole. A light tap with a punch and the rivet was removed with no more damage to the hole. I did all 48 rivets in about a half hour and moved on. The cutoff wheel barely showed any wear.
Rick Girard
Zulu Delta
Mk IIIC
Thanks Homer, GBYM
  - Groucho Marx
mdnanwelch7(at)hotmail.co
PostPosted: Mon Jan 24, 2011 9:24 am    Post subject: New Dremel accessory Reply with quote
Hi Rick,
  Hmmm.  You find a nifty tool, and you wait a couple of months to share.   Hmmm!
 >Just to keep this specifically Kolb related, I was removing the elevator hinge
 >>Rick Girard
  Tools to use building airplanes are ALWAYS Kolb related!!  No further explanation
necessary.
  Speaking of Dremels.....   I have a Ryobi cut-off tool.  I have always like it, but it
is 99% dead now!!  It won't stay running for more than a few seconds, maybe the
brushes are burned up, but it's not worth trying to fix (IMO).  At any rate, I want a new
cut-off tool.  Since I just had a birthday a couple of days ago, I decided I will get me
one for a birthday gift....to me!!
  Since you recommend { finally : ) } the Dremel, and especially the new anvil mount,
I'll head over and check them out!!
  Thanks, Rick   BTW, are you referring to those fiber reinforced cut-off disks?  The ones that
come in that handy blue "slide out" container?  I've used those for years.  They are VERY
durable!  I used to break the cheapies in minutes, all the time.  Sometimes, in only seconds.
Mike Welch
MkIII
PostPosted: Mon Jan 24, 2011 10:06 am    Post subject: New Dremel accessory Reply with quote
Hmmm!
Mike Welch
Mike W/Rick G/Gang:
Realize this is not quite subject related, but wanted to share with you all,
if you don't mind.
I'm a die grinder kinda guy. I have a straight and a 90 degree grinder.
Probably paid 15 or 20 dollars a piece for them.
A few drops of Marvel Mystery Oil through the air intake every once in a
while and they go forever.
PostPosted: Mon Jan 24, 2011 10:56 am    Post subject: New Dremel accessory Reply with quote
John,
  There's no doubt I demand a lot from my tools.  Probably a lot more than they
were originally intended to put out.  I guess my approach is; if this tool can't
get the job done, then "I'll get the next bigger model!!"
  I haven't tried the Marvel oil maintenance....but I will from now on.  Darn
sure couldn't hurt.
  I kinda think my present Ryobi is toast, but what the heck, right now it's like an
old 'straight six' running on 4 cylinders.  I'll see if a little oil will help....
  I did find on eBay that neat, new mandrel Rick was talking about.  It has a
kind of butterfly hole in the disk, that spins and locks into the mandrel head.
Nice feature.
  MY problem is: I liked the Ryobi because it had about 8-10 speeds.  I don't
think the Dremel does.  I'd miss that feature.
  In the last year, I burned up two hand-held grinders!!  My old faithful Makita,
and it's replacement Milwaukie.  I'll be a little easier on my brand new Milwaukie.
Plus, from now on, I'll use some Marvel oil once in awhile...
Mike Welch
rickofudall
PostPosted: Mon Jan 24, 2011 11:09 am    Post subject: New Dremel accessory Reply with quote
Mike, The old cut off wheels I was referring to are the fiber reinforced ones with a 1/16" center hole for mounting. They were just too fragile for most anything and if you pushed them too hard the center cracked out and you were done. As you can see the new ones are much more robust.
Rick
On Mon, Jan 24, 2011 at 11:17 AM, Mike Welch <mdnanwelch7(at)hotmail.com (mdnanwelch7(at)hotmail.com)> wrote:
Hi Rick,
 >>Rick Girard
necessary.
Mike Welch
MkIII
tp://forums.matronics.com
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
 Filesize:  770.49 KB
 Viewed:  3687 Time(s)
williamtsullivan(at)att.n
PostPosted: Mon Jan 24, 2011 11:55 am    Post subject: New Dremel accessory Reply with quote
Mike- I don't think you can lube the electric tools. Maybe a drop on the bearings. If you use a Dremel for end grinding, like pushing straight in, the main shaft gets set back. My battery powered Dremel did that- my fault. I was able to disassemble and push the shaft back into position. John was talking about the air powered ones. If you have a compressor, get the 1/4" drive tools. By name brand ones, like Ingersoll or Chicago Pneumatic, or Snap-on. Craftsman used to make a 1/4" drive electric die grinder- 110V.
      Bill Sullivan
--- On Mon, 1/24/11, Mike Welch <mdnanwelch7(at)hotmail.com> wrote:
Subject: RE: New Dremel accessory
Date: Monday, January 24, 2011, 1:38 PM
get=_blank rel=nofollow>http://www.matronics.com/Navigator?Kolb-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
PostPosted: Mon Jan 24, 2011 12:01 pm    Post subject: New Dremel accessory Reply with quote
Hi Rick,
  The disks that I was referring to were fragile, unreinforced kind.
If you breathed on them hard, they broke!!  Pretty near useless, IMO,
unless you were cutting balsa wood....slowly!!
  The 'much better' ones I was referring to are the fiber reinforced ones.
I generally got lots of mileage out of these....that is, unless I bumped
them sideways, or layed the tool down too hard.  I have bent in half
dozens of these.  Yes, they do have the rediculously little 1/16" hole!!
  I haven't seen the new cut-off discs you're referring to.  I'll make it a
point to check them out.
  As I previously stated, I really liked the Ryobi rotary tool.  But, I'm open to
recommendations regarding the Dremel.  Does anyone have a "preferred
model" they like.....and why?
Mike Welch
PostPosted: Mon Jan 24, 2011 12:47 pm    Post subject: New Dremel accessory Reply with quote
Hi Bill,
  Thanks for pointing that out re: air tools.  I didn't catch that.  Doh!!
  No, I never use the rotary tool for anything except the cut-off discs.
  I know about oil in air tools.  That's not new to me, I just misunderstood
what he was getting at.   Thanks, Bill.
  Yeah, I know what you are getting at regarding the "name brand" tools.
I think that is where they got that expression;  You get what you pay for!!!
PostPosted: Mon Jan 24, 2011 1:02 pm    Post subject: New Dremel accessory Reply with quote
Mike- if you have a compressor, then I really recommend a 90 degree tool with the 3M "Roloc" disc accessory. The sanding discs will remove a lot of metal, and the "scruffy pad" discs will polish. Nice for brazing prep and finish, and polishing welds. Very controllable.
      Bill Sullivan
Date: Monday, January 24, 2011, 3:27 PM
Hi Bill,
captainron1(at)cox.net
PostPosted: Fri Jan 28, 2011 8:37 pm    Post subject: New Dremel accessory Reply with quote
I bought a Sears Craftsman Trade name Rotary grinder, it may be a Dremel or Dremel look alike over 10 years ago. I use it often. So far it has held up well. I see no sign of it giving up the ghost.
---- Mike Welch <mdnanwelch7(at)hotmail.com> wrote:
Hi Rick,
Mike Welch
kugelair.com
