Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Thu Jan 13, 2011 7:32 pm Post subject: Control stick connector |
What are builders using to connect the infinity grip wires to the panel? I saw some pictures a while ago that showed the connector mounted to the landing gear bracket. Which connector is being used. 25 D-sub? I didn't order the longer cables.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
rene(at)felker.com Guest
Posted: Thu Jan 13, 2011 8:12 pm Post subject: Control stick connector |
I used the 25 D-sub...
Rene'
801-721-6080
Posted: Fri Jan 14, 2011 6:06 am Post subject: Control stick connector |
I used 16-pin CPC connectors under the seats and then wired the sticks together under the seats as necessary and then wired them up to the panel through the side panels.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Jan 13, 2011, at 10:32 PM, Strasnuts wrote:
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p=326973#326973
johngoodman
Posted: Fri Jan 14, 2011 6:41 am Post subject: Re: Control stick connector |
I used Aerotronics for my panel and they had a Circular Plastic Connector (CPC) by Amp already hanging there under the panel. All I had to do is put together the other half of the CPC plug with the wires from the stick.
rv10rob(at)gmail.com Guest
Posted: Fri Jan 14, 2011 8:43 am Post subject: Control stick connector |
Just finished this yesterday. I used a 25-pin d-sub zip tied to the landing gear mount. Seems to work fine.
-Rob
On Thu, Jan 13, 2011 at 7:32 PM, Strasnuts <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
| Quote: | --> RV10-List message posted by: "Strasnuts" <sean(at)braunandco.com (sean(at)braunandco.com)>
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
t Un/Subscription,
www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
ivankris
Joined: 29 May 2009 Posts: 21 Location: Guelph, Ontario. Canada
rvdave
Posted: Sat Jan 15, 2011 6:16 pm Post subject: Re: Control stick connector |
Has anyone drilled into the control sticks so the blue cable could go inside the stick instead of exterior?
_________________ Dave Ford
Cadillac, MI |
Strasnuts
Posted: Sat Jan 15, 2011 6:25 pm Post subject: Re: Control stick connector |
Thanks Ivan,
That is where I saw the original pictures months ago and forgot where I saw them. That's perfect.
780 Hours
Tim Olson
gnolin(at)sbcglobal.net Guest
Posted: Sun Jan 16, 2011 11:27 am Post subject: Control stick connector |
I was able to get the blue cable into the tube by filing a little relief notch to make the 90 degree turn into a hole I drilled into the curved part of the stick. I'll get a picture that shows this better than words can describe.
Hank Nolin = rv-10 Soon
On Jan 15, 2011, at 8:16 PM, "rvdave" <davidbf(at)centurytel.net> wrote:
johngoodman
Posted: Sun Jan 16, 2011 4:29 pm Post subject: Re: Control stick connector |
| rvdave wrote: | | Has anyone drilled into the control sticks so the blue cable could go inside the stick instead of exterior? |
I didn't bother. I used lacing to firmly attach it to the back of the stick, and then had Abby at Flightline Interiors make a "boot" for the stick in my upholstery color - looks fantastic. About eighty bucks and worth it.
Posted: Sun Jan 16, 2011 6:43 pm Post subject: Control stick connector |
I did, I put a 90 degree bend in the upper stick. pretty much followed Tim
Olson's site for doing mine. Looks much cleaner to me, but it does take some
work to make it come through the tube to the bottom. Not hard and looks much
more mice than leaving it on with zip ties. A small boot off the bottom
panel into the flightstick and painting the stick would be nice. I think I
took this picture from Greg Hale's site.
With that said, a full flightstick boot would cover the stick as well and
look equally nice.
Pascal
Sent: Saturday, January 15, 2011 6:16 PM
Subject: Re: Control stick connector
101.23 KB |
19874 Time(s) |
kearney
Posted: Mon Jan 17, 2011 5:01 am Post subject: Control stick connector |
Hi Pascal
That looks like a beautiful interior in your -10.
One question on the infinity cable - how did you handle the cable at the bottom end if the control stick?
Cheers
Les
On 2011-01-16, at 7:40 PM, Pascal <rv10builder(at)verizon.net> wrote:
| Quote: | I did, I put a 90 degree bend in the upper stick. pretty much followed Tim Olson's site for doing mine. Looks much cleaner to me, but it does take some work to make it come through the tube to the bottom. Not hard and looks much more mice than leaving it on with zip ties. A small boot off the bottom panel into the flightstick and painting the stick would be nice. I think I took this picture from Greg Hale's site.
With that said, a full flightstick boot would cover the stick as well and look equally nice.
Pascal
> Dave Ford
> RV6 flying
> RV10 building
> Cadillac, MI
> http://forums.matronics.com/viewtopic.php?p=327154#327154
<rv-10 boot.jpg>
Posted: Mon Jan 17, 2011 6:57 am Post subject: Control stick connector |
Don’t I wish!! That is Greg Hale's interior
(http://nwacaptain.com/rv10_home.html) Just using as an example of how good
it looks with the small boot and the stick painted.
As far as the cable on the bottom, comes straight out into a service loop
and held in place with a clamp on the landing gear bracket to allow for all
the play the stick will need.
Pascal
aerosport1
Posted: Mon Jan 17, 2011 7:27 am Post subject: Control stick connector |
Here are some picture of the stick covers I made for my sticks. I have the
cable on the outside of the stick and these have a nice zipper in the front.
I have made these for some other builders as well. They are very easy to put
on.
Geoff Combs
President
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
84.51 KB |
19851 Time(s) |
84.17 KB |
19851 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Lenny Iszak
Posted: Mon Jan 17, 2011 10:21 am Post subject: Re: Control stick connector |
I had a steering wheel reupholstery guy wrap the control sticks and the windhsield bar with black leather and red stiches. I'll be running the cables inside the sticks.
Lenny
57.36 KB |
19838 Time(s) |
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
Posted: Mon Jan 17, 2011 10:45 am Post subject: Control stick connector |
Although mine are also done, I would be interested in seeing pictures of how
the red stitching look..
