Air foil for cable...
nickc(at)mtaonline.net
PostPosted: Tue Jan 11, 2011 11:36 pm    Post subject: Air foil for cable... Reply with quote
Kolber’s,
A year or two ago someone posted drag values for parts of a Kolb, if I remember right. I was amazed at the drag values for the cables on the tail.
One of you, with a lot more skill than me, can probable come up with an airfoil for a cable!
Winter is not over yet, what do you think?
Thanks as all ways for all your knowledge!
Nick Cassara
Palmer, Alaska
Kolbra #1
GeoB
PostPosted: Wed Jan 12, 2011 12:55 am    Post subject: Air foil for cable... Reply with quote
I would like to see the drag values too.
I have been thinking about this issue- now, I am not any kind of aircraft guru, completely new to aircraft- so I am just 'seeding' the discussion with an idea.
Have you ever used Shoo-goo? Great stuff. Much stronger and tougher than silicone seal, yet comes in a squeeze tube.
I wish the feller in the lab coat in the video had demonstrated the drag of a tube faired on only one side, because that is what I am thinking- run a bead of shoo-goo down a cable, shape it into a 'V' between your fingers somehow.
A Kolber posted pics somewhere showing aluminum v-shaped fairings he had a sheet metal shop brake for him. They were rivited to the sides, forming a trailing edge streamlined shape. Don't know how effective they are (he had no test data either) but it gave me the idea on the cable streamlining.
GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors"
pj.ladd(at)btinternet.com
PostPosted: Wed Jan 12, 2011 2:54 am    Post subject: Air foil for cable... Reply with quote
With all the current excitement about cutting drag it occurs to me that most of the examples shown have been for much higher speeds that the ones we generally fly at.
I forget the maths now but doesn`t drag increase at the square of the speed or something like that?
Streamling lift struts etc might be worth it, and it looks nice, but is it worth it for cables at speeds of 50 to 70?
WW1 biplanes used tear drop shaped cables certainly but they were operating at around 100mph and few of us reach that and live to tell the tale.
Just a thought
Pat
elleryweld(at)aol.com
PostPosted: Wed Jan 12, 2011 4:46 am    Post subject: Air foil for cable... Reply with quote
would it reduce drag on a cable if you was to fold a peice of vinal tape in half to leave a 3/4 inch trailing edge? let the testing begin
Dana
PostPosted: Wed Jan 12, 2011 4:58 am    Post subject: Air foil for cable... Reply with quote
Streamlined wires have long been used in aircraft. There are a couple of companies that still make them today. They're solid wire, rolled to the streamline shape, then threads have to be formed at the ends... they're special order, of course, made to the specific length you need... and expensive.
Years ago, in U-control (control line) model airplane racing (these models can go 200+ mph, on 60' cables of around .015 diameter), somebody figured out that the lines were 80% or more of the drag, and came up with what was termed "funny lines"... basically a streamlined enclosure to hold the two lines close together, one behind the other. The original was a thin wall tube slipped over the front wire, and a bit of tap wrapped around and stuck to itself forming a tab in back, forming a crude airfoil shape. The rear wire ran through the gap in the tape immediately behind the tube. Later, molded plastic shapes were used. IIRC, they cleaned up in the speed events at the Nationals that year... and funny lines were promptly banned immediately afterwards.
-Dana
Beam me up, Scotty, it ate my phaser.
Richard Pike
PostPosted: Wed Jan 12, 2011 7:32 am    Post subject: Re: Air foil for cable... Reply with quote
This is overexposed, but you get the idea: OD 5/16" X 5/32" X 35", ID 1/8" X 1/4". Got it at the local RC hobby shop, thinwall aluminum, weight 1/2 oz. Ought to be able to slip a tail brace wire through it during cable assembly, Goop it to an end fitting to keep it from pivoting. Use 2 pieces, each one attached at an end fitting, leave the middle of the wire uncovered so you could still fold the tail? Maybe squeeze it thinner so that it has less cross section?
Food for thought...
Richard Pike
MKIII N420P (420ldPoops)
 Filesize:  35.93 KB
 Viewed:  5820 Time(s)
radiobluebook(at)gmail.co
PostPosted: Wed Jan 12, 2011 8:26 am    Post subject: Air foil for cable... Reply with quote
Regarding drag; this is an interesting video that has been circulating on other groups.
http://www.youtube.com/watch?v=ftq8jTQ8ANE
On Wed, Jan 12, 2011 at 2:53 AM, George Bearden <gab16(at)sbcglobal.net (gab16(at)sbcglobal.net)> wrote:
[quote]--> Kolb-List message posted by: George Bearden <gab16(at)sbcglobal.net (gab16(at)sbcglobal.net)>
n,
www.matronics.com/Navigator?Kolb-List" target="_blank">http://www.matronics.com/Navigator?Kolb-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Rex Rodebush
PostPosted: Wed Jan 12, 2011 9:48 am    Post subject: Re: Air foil for cable... Reply with quote
The experiment we saw on the video and many others are explained in the book "Shape and Flow, the Fluid Dynamics of Drag" by Ascher H. Shapiro, published by Doubleday Anchor. It's out of print but I got a copy via the internet.
Rex
mdnanwelch7(at)hotmail.co
PostPosted: Wed Jan 12, 2011 9:57 am    Post subject: Air foil for cable... Reply with quote
Ellery
Ellery,
  Yes, I bet it would....a lot.
  What about this idea?  I have a roll of heavy thickness aluminum tape, the
kind air conditioning installers use (that's who I go it from!!).  It has a protective
tape on it.
  What if we cut the tape to length, then bent it lengthwise, down the middle?
Then we pulled off the protective tape.  Next, carefully (!!) stick a length of
nylon string exactly down the center on the crease-line (this to hold the aluminum
tape back a bit from the blunt edge, sort of trying to maintain the airfoil shape).
  Now, with the cable good & tight, try to accurately adhere the tape onto one
edge of cable.  Once you have the orientation accurate, begin pinching the two
sides of the tape.
  It may take a couple of practice runs, but I bet a guy could make a really good
looking aluminum tape cable airfoils.
Mike Welch
PostPosted: Wed Jan 12, 2011 10:23 am    Post subject: Air foil for cable... Reply with quote
really good
Mike Welch
How much drag reduction to you expect to receive from streamlining 8 to 10
feet of 3/32" cable?
Doubt you or your Kolb would ever notice the difference.
The following does not pertain to cable air foils, but it does have
something to do with reducing drag and improving air flow to the prop on a
MKIII.
The first modification we made to my MKIII fuselage was replace the 7/16" or
1/2" round 4130 tubes with streamlined 4130 tubes at the rear of the
fuselage that brace the lower side of the rear engine mount. Don't know how
much good that did, but was bound to make some improvement removing that
drag and air turbulence right before it was fed into the cleanest part of
the prop arch.
Another thing we did that reduced drag was the main landing gear legs. Only
18" of .125" gear leg are exposed to the air stream.
Permanently enclosing the upper rear of the fuselage also reduced drag, as
did the keel faring on the bottom of the fuselage. The keel faring also
cleaned up air going to the prop.
Still the quickest MKIII until someone comes along that can out run me, side
by side.
Last race I had was at the Kolb Homecoming a couple years back with Steven
Green and his MKIII powered with a 912ULS. I beat hands down. Wink
If only I could have out run John Williamson and his 912ULS powered Kolbra.
John was 10 mph quicker than Miss P'fer. Skinny Kolbs are faster than fat
ones.
