Epistaxis
Joined: 19 Dec 2010 Posts: 13 Location: Nebraska, USA
Posted: Tue Jan 11, 2011 11:00 am Post subject: Yak 55: Longwing winter cover |
I would like to purchase a complete OEM Russian set of covers for a Yak 55 long wing. I`m also looking for a Russian topdead center indicator as would be found in the M14p tool kit. Please let me know off line if you have one or the other and would like to sell... Thanks
Posted: Tue Jan 11, 2011 11:39 am Post subject: Yak 55: Longwing winter cover |
Shawn,I carry the insulated engine cover/wraps in stock, Will fit all Yaks, CJ's etc. Contact off list please.
Best,
Doug
On Tue, Jan 11, 2011 at 11:00 AM, Epistaxis <ShawnJBurwell(at)aol.com (ShawnJBurwell(at)aol.com)> wrote:
[quote]--> Yak-List message posted by: "Epistaxis" <ShawnJBurwell(at)aol.com (ShawnJBurwell(at)aol.com)>
http://forums.matronics.com/viewtopic.php?p=326550#326550
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
Posted: Tue Jan 11, 2011 11:45 am Post subject: Yak 55: Longwing winter cover |
Contact West London Aeroclub for TDC gauge.
Doc
On Jan 11, 2011, at 1:00 PM, "Epistaxis" <ShawnJBurwell(at)aol.com> wrote:
radiopicture
Posted: Tue Jan 11, 2011 12:12 pm Post subject: Yak 55: Longwing winter cover |
Hey, Doug, I forgot to thank you for that cover you sent. It's working out great. -Eric
On Jan 11, 2011, at 2:30 PM, doug sapp wrote:
[quote]Shawn,I carry the insulated engine cover/wraps in stock, Will fit all Yaks, CJ's etc. Contact off list please.
Best,
Doug
| Quote: | --> Yak-List message posted by: "Epistaxis" <ShawnJBurwell(at)aol.com (ShawnJBurwell(at)aol.com)>
le, List Admin.
| [b]
Posted: Tue Jan 11, 2011 12:47 pm Post subject: Yak 55: Longwing winter cover |
Be VERY careful using the Russian TDC gauge. I have had 2 jam inside
the cylinder and had to cut the gauge off just above the spark plug hole
to release the hook end of the gauge that touches the top of the piston.
Only then was I able to unscrew the bottom section of the gauge. The
problem is the poor manufacturing quality of the gauge. The slide
mechanism was binding and when it bound inside the cylinder, I hoped and
prayed that by cutting it off with a Dremel tool, I would be able to
remove the bottom section and not have to pull the cylinder.
I no longer use the Russian TDC instruments for this reason. I don't
want to try for 3.
Dennis
On 1/11/2011 1:41 PM, Roger Kemp M.D. wrote:
Doc
A. Dennis Savarese
334-285-2141
334-546-8182 (cell)
Skype: Yakguy1
www.yak-52.com
