Okanogan Lew
Posted: Mon Jan 10, 2011 4:19 pm Post subject: Housai cylinder bore diameter CJ6A |
does anyone know the standard cyl. bore diameter in inches? Thanks.
Paul
radiopicture
Posted: Mon Jan 10, 2011 4:45 pm Post subject: Housai cylinder bore diameter CJ6A |
wlannon(at)persona.ca Guest
Posted: Mon Jan 10, 2011 6:48 pm Post subject: Housai cylinder bore diameter CJ6A |
Paul;
Huosai cyl. dia. is 105 mm or 4.13385" (4.134")
Walt
okanoganlew(at)gmail.com Guest
Posted: Mon Jan 10, 2011 7:34 pm Post subject: Housai cylinder bore diameter CJ6A |
Thanks Walt. Is a cyl. 5-6 thousands over still servicable? If not, does anyone make oversize rings?
Paul
On Mon, Jan 10, 2011 at 6:45 PM, Walter Lannon <wlannon(at)persona.ca (wlannon(at)persona.ca)> wrote:
[quote]--> Yak-List message posted by: Walter Lannon <wlannon(at)persona.ca (wlannon(at)persona.ca)>
Paul;
Walt
Posted: Mon Jan 10, 2011 9:41 pm Post subject: Housai cylinder bore diameter CJ6A |
Paul;
I think that may be acceptable if some choke still remains and you fit new standard rings though you could expect an increase in oil consumption.
Check with Doug for rings - maybe an oversize is available??
I believe the M14 has the same bore so that manual may be helpful in determining repair tolerances.
Walt
GeorgeCoy
Posted: Tue Jan 11, 2011 5:40 am Post subject: Housai cylinder bore diameter CJ6A |
Paul, I cannot answer for the Housai engine, but the M14 dimensions’ are as follows:
Standard size cylinder is a straight bore Min 104.970 mm (4.132 in) and Max is 105.030 mm (4.135 in)
First oversize is a straight bore of Min 105.12 mm (4.138 in) and Max of 105.18 mm (4.131 in ).
In both cases the max “Ovality” is .040 mm (.0016 in )
You will note that very little ware is permitted and the oversize rings are only .006 oversize.
We offer both standard and oversize pistons with the modern rings.
George Coy
Motorstar NA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com (george.coy(at)gmail.com)
SKYPE george.coy
motorstarna.com
george(at)gesoco.com Guest
Posted: Tue Jan 11, 2011 10:43 am Post subject: Housai cylinder bore diameter CJ6A |
George Coy
Motorstar NA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
SKYPE george.coy
motorstarna.com
