OAT Sensor
Ianrat
PostPosted: Sun Jan 09, 2011 3:05 am    Post subject: OAT Sensor Reply with quote
Where is the best position to install an Out Side Temp Probe on a 601 XL.
Thank you
Ianrat
CH 601 XLB
Brisbane Australia
jeffrey_davidson(at)earth
PostPosted: Sun Jan 09, 2011 7:04 am    Post subject: OAT Sensor Reply with quote
Under the saddle in the bulkhead is protected from the direct sun, not
readily visible, and exposed to direct outside air.
Jeff Davidson
jaybannist(at)cs.com
PostPosted: Sun Jan 09, 2011 8:10 am    Post subject: OAT Sensor Reply with quote
Ian,
I mounted my OAT probe inside the right NACA intake fiberglass molding.  I figured it would have adequate outside air, not be affected by cowling temps nor the exhaust stream and would be out of the sunlight. It is also a short wiring run from the probe to my Dynon, which has an OAT readout. .
Jay
 Filesize:  138.74 KB
 Viewed:  6253 Time(s)
bryanmmartin
PostPosted: Sun Jan 09, 2011 1:33 pm    Post subject: OAT Sensor Reply with quote
That's where I put mine also.
On Jan 9, 2011, at 11:07 AM, jaybannist(at)cs.com wrote:
Ian,
Jay
Bryan Martin
do not archive.
Ianrat
PostPosted: Mon Jan 10, 2011 1:49 pm    Post subject: Re: OAT Sensor Reply with quote
Thank you.
I think I will go with the inlet position. This will keep the wiring short and also out of the way.
Ianrat
CH 601 XLB
Brisbane Australia.
