Wx sealing Fwd Fuse Top Skin
jchang10
PostPosted: Thu Jan 06, 2011 1:16 pm    Post subject: Wx sealing Fwd Fuse Top Skin Reply with quote
Hi, I am preparing to finally rivet down the Fwd Fuse Top Skin. I was wondering whether it is worth the trouble to proseal the rivet lines (see attached photo) to prevent any moisture leaking into the cabin area? Or is this not even an issue worth considering?
Jae
40533
 Filesize:  101.55 KB
 Viewed:  3161 Time(s)
Tim Olson
PostPosted: Thu Jan 06, 2011 3:35 pm    Post subject: Wx sealing Fwd Fuse Top Skin Reply with quote
Jae, it won't hurt to do it, but it probably isn't going to do very
much for you. You'll be painting all that area anyway. Also, the
windshield fairing will cover a lot of it. If I were doing it
all over again, I'd fill the rivets from the outside, on that
forward deck, and the seam along the sides.
Tim Olson - RV-10 N104CD
Jae
40533
http://forums.matronics.com/viewtopic.php?p=325847#325847
http://forums.matronics.com//files/capture_166.png
jchang10
PostPosted: Thu Jan 06, 2011 4:26 pm    Post subject: Re: Wx sealing Fwd Fuse Top Skin Reply with quote
Right, I forgot about paint. At this point, I have no idea how long it will be to get painted, so I'll probably do a bit of sealing esp. around the sides and the firewall then.
Jae
[quote="Tim Olson"]Jae, it won't hurt to do it, but it probably isn't going to do very
rv10builder(at)verizon.ne
PostPosted: Thu Jan 06, 2011 5:36 pm    Post subject: Wx sealing Fwd Fuse Top Skin Reply with quote
For what it's worth. I put etch, in prep for priming and body work on all
aluminum and the front upper area. I used my fire hose nozzle to get all the
etch out of the sides, bottom and top fusellage.
No water leaked in anywhere. If it can take the fire hose pressure it will
not leak in my mind.
Pascal
