Miscellaneous end of year questions
Goto page 1, 2  Next
kearney
PostPosted: Fri Dec 31, 2010 10:48 am    Post subject: Miscellaneous end of year questions Reply with quote
Hi
As I embark on a new adventure - wiring, I have a couple of questions for those who know their electrons.
My wire strippers don't seen to work very well on the fine Tefzel wires of the RayAllen servos. Can anyone give me the name / model of a good brand of wire strippers that will handle these wires? I suspect this will be an ongoing issue.
I notice in the plans (OP37-16) that the tail light ground is on the aft tail cone F1012 bulkhead. My plan was to run dedicated grounds back to the firewall ground block. Is there any issue (ground loops) with following the plans? Is a dedicated ground preferable? If a dedicated ground is preferred, is there any issue with gathering grounds to a common point (were practical) and then running a single dedicated ground back to the firewall ground block?
As I run wires to the rudder (as per the pans), what is the best way to protect these wires from the elements, prevent chaffing and cracking? My concern is that these wires may lose flexibility in cold weather but then again this may be a misplaced concern.
On the mechanical side, I am stumped over how to remove the tanks on my QB wings. The screws seem to be very well set and I don't think I can remove them without stripping the heads. Is there any trick to removing these screws (WD40 etc)?
Inquiring minds need to know…
Happy New Year
Les #40643 [quote][b]
pitts_pilot(at)bellsouth.
PostPosted: Fri Dec 31, 2010 11:56 am    Post subject: Miscellaneous end of year questions Reply with quote
Les, you're liable to get as many different answers as you'd get from a primer question. Wink
Here are mine.
Hi
I use a single edge razor blade. Just press the razor blade through the insulation, rotate the wire and repeat. With practice you can 'roll' the wire allowing the razor blade to follow the wire without 'sawing'. Depending on your make/model of stripper, you can buy blades that fit your wire size better.
The common practice among the certified planes is to use the airframe for grounds. Guess where the problems show up? For me, a single ground point is preferable, and on my -10 will be the feed-through on the firewall ..... because I'm running a ground wire along with my power to there. When I have a lot of grounds, like the instrument panel, I'll collect the grounds at a single point (sub-panel) and then connect to the firewall connection. In the tail, I have the battery negative attachment point.
Not a concern for me.
I've not been there yet, but if you have a NEW, high quality #2 phillips screwdriver, you can really lean on the handle while a pair of vise grips apply rotation. I have a couple of brand-name screwdrivers that I only use on difficult screws.
Linn
Happy New Year
Les #40643
rv10flyer
PostPosted: Fri Dec 31, 2010 12:18 pm    Post subject: Re: Miscellaneous end of year questions Reply with quote
I am using Ideal Stripmaster Cat# 45-177 16-26 Ga. Not cheap but they work really well. For larger wires I use a cheap pair from Lowe's. I use single edge razor on rg-400 or #2 ga.
I am grounding everything locally unless specified by mfr otherwise. All my unprimed aluminum should conduct electrons just fine. I am using an alodine pen from SteinAir. I will install forest of tabs behind the panel.
Use nylon wire ties per plans and run your strobe shielded cable(3-16ga) and tail nav lt wire 18 ga inside lower left stiffener. When exiting the stiffiner use a 2-3" piece of spiral wrap. I also use ms clamps/standoff brackets. I also use stick on/rivet on wire tie mounts(ACS). I used heat shrink where it passed through rear bulkhead to go into bottom rundder fairing. I also drilled hole to lower left of vs spar so that vs could be installed and removed while wiring was in place. Deburr hole edges with 320 grit really well. Run spiral wrap around wiring to tail light/strobe if desired. Tefzel wiring is very good and flexible unless your flying in the artic. Try lighting it on fire next to a cheap piece of pvc wiring and note smoke emmitted.
I ran rg-400 and pitch trim cable up right side in same place/same way.
Use a new #2 bit and do it by hand with alot of pressure.
Happy New Year.
Wayne G.
Kellym
PostPosted: Fri Dec 31, 2010 12:38 pm    Post subject: Miscellaneous end of year questions Reply with quote
Les,
Any electrical resistive load like a tail light does NOT need a ground
back to the firewall. They don't generate noise and a local ground is
fine. Only avionics and other noise generators like strobes and motors
need a unified ground.
Kelly
Kelly McMullen
KCHD
rv10builder(at)verizon.ne
PostPosted: Fri Dec 31, 2010 12:41 pm    Post subject: Miscellaneous end of year questions Reply with quote
I agree on the points from Linn.
As far as the tight screw.
spray WD-40, let it sit for a while
lightly tap the screwdriver (on the screw) with a hammer to loosen any locktite and help the lube pentrate
than try loosening- did that work?
no?
grab a heat gun and warm up the screw or just the opposite- dry ice, than try again
if that doesn't work, get a impact screw driver. I have never had to get to this point however.
Let us know what worked.
Pascal
Sent: Friday, December 31, 2010 11:52 AM
Subject: Re: Miscellaneous end of year questions
Here are mine.
Hi
Linn
Happy New Year
Les #40643
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
Bob Turner
PostPosted: Fri Dec 31, 2010 1:10 pm    Post subject: Re: Miscellaneous end of year questions Reply with quote
I chose to run a separate ground wire for the tail light, along side the power wire, because it goes within a few feet of where I am remote mounting the remote compass, and I wanted to minimize stray magnetic fields. This is probably anal overkill, but that's what I did.
Bob Turner
RV-10 QB
PostPosted: Fri Dec 31, 2010 1:21 pm    Post subject: Miscellaneous end of year questions Reply with quote
On 12/31/2010 3:39 PM, Pascal wrote:
Miscellaneous end of year questions I agree on the points from Linn.
no?
DON"T!!!!! Read that again!!!! The hammer force on an impact driver is enough to deform the structure. Came from experience. Sad
Linn
[quote] I have never had to get to this point however.
Pascal
Here are mine.
Hi
Linn
Happy New Year
Les #40643
dave.saylor.aircrafters(a
PostPosted: Fri Dec 31, 2010 1:26 pm    Post subject: Miscellaneous end of year questions Reply with quote
I use a couple schemes for running wires into the control surfaces.
Other planes have servos in the elevators and ailerons. I use the
same techniques for them.
If you don't have much distance to work with, you can wrap a foot or
so of tefzel wire tightly around a pencil to make your own coiled
wire. The coil tends to spread out the flexing.
Another way to accomplish the same thing is to run the wire as far as
possible in the direction of the hinge line. A foot or more is ideal.
Secure the wire outside the stern post and the rudder spar, so any
motion happens as twist around the long axis of the wire.
A little dab of valve grinding compound on the tip of a screwdriver
works magic on super-tight screws. It really makes the bit grab the
screw without slipping and damaging the screw.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
no?
try again
this point however.
Pascal
Here are mine.
Hi
ongoing issue.
wire size better.
block?
screws (WD40 etc)?
Linn
Happy New Year
Les #40643
Tim Olson
PostPosted: Fri Dec 31, 2010 1:35 pm    Post subject: Miscellaneous end of year questions Reply with quote
I have had a few good strippers over the years.
(geez, maybe I shouldn't say that in public? Smile )
Right now, my main sets are 2 of these IDEAL T-Strippers.
(also see attached)
http://www.google.com/products/catalog?num=10&hl=en&newwindow=1&q=ideal+T+stripper&um=1&ie=UTF-8&cid=395400644739097984&ei=I0YeTeuAE5O6ngeMwbz8DQ&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CDQQ8wIwAg#
It's nice because it covers most every gauge that you'll use
in the build, from I think 8 to 26 stranded. It's also very
cheap, and available locally.
It's not the only brand that's good, I'm sure there are dozens.
But, when you find one you like, buy 2....keep one for the
long term. The most important thing is to have one that's
well made and sharp.
Tefzel strips wonderfully. To strip the shielded stuff I
just spin the wire in the blades and bend it to crack the
groove and then pull off the sheath. The wires strip
normally, with no issue. Done a bunch of wires lately.
On your grounding question, for non-noisy loads like those
lights, you can basically do it however you want and you
won't have a problem.
Tim Olson - RV-10 N104CD
On 12/31/2010 12:45 PM, Les Kearney wrote:
Hi
Happy New Year
Les #40643
com>
uildersbooks.com>
lp.com>
 Filesize:  66.96 KB
 Viewed:  11942 Time(s)
davidsoutpost(at)comcast.
PostPosted: Fri Dec 31, 2010 3:13 pm    Post subject: Miscellaneous end of year questions Reply with quote
I use a thermal wire striper for striping wire. They are a bit expensive but you can sometimes find one on eBay for a decent price. No worries of nicking wires with these: http://www.google.com/products/catalog?q=stripall+wire+stripers&hl=en&client=firefox-a&hs=P4T&rls=org.mozilla:en-US:official&prmd=ivns&resnum=3&biw=1366&bih=587&um=1&ie=UTF-8&cid=1185846266203347523&sa=X&ei=WGAeTaqzEcj9nAfi2qz_DQ&ved=0CEsQ8gIwAQ#
Do yourself a favor and order a couple hundred of the SS Torx drive 100* screws from these guys,,,,,,no more fooling around with stripped Phillips head screws: http://www.microfasteners.com/catalog/standard.cfm?Category=SSC&SubCategory=FCMXS
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
bruce1hwjohnson(at)yahoo.
PostPosted: Fri Dec 31, 2010 5:57 pm    Post subject: Miscellaneous end of year questions Reply with quote
Just out of curiosity, why are you taking the tanks out? I'm afraid I am going to have to take mine out as they are leaking from the outlet port and the sealant is getting real gummy. They are also quick built.
From: "davidsoutpost(at)comcast.net" <davidsoutpost(at)comcast.net>
Sent: Fri, December 31, 2010 4:10:34 PM
p {margin:0;} I use a thermal wire striper for striping wire. They are a bit expensive but you can sometimes find one on eBay for a decent price.  No worries of nicking wires with these: http://www.google.com/products/catalog?q=stripall+wire+stripers&hl=en&client=firefox-a&hs=P4T&rls=org.mozilla:en-US:official&prmd=ivns&resnum=3&biw=1366&bih=587&um=1&ie=UTF-8&cid=1185846266203347523&sa=X&ei=WGAeTaqzEcj9nAfi2qz_DQ&ved=0CEsQ8gIwAQ#
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
dlm34077(at)q.com
PostPosted: Fri Dec 31, 2010 6:49 pm    Post subject: Miscellaneous end of year questions Reply with quote
Are your passengers standing on any part of the tank when loading/unloading?
PostPosted: Fri Dec 31, 2010 9:25 pm    Post subject: Miscellaneous end of year questions Reply with quote
Not really, I am still flying my 40 off. They started leaking as soon as I started filling the tanks full.
Sent: Fri, December 31, 2010 7:46:25 PM
 DIV { MARGIN:0px;} Are your passengers standing on any part of the tank when loading/unloading?
dlm34077(at)q.com
PostPosted: Fri Dec 31, 2010 9:45 pm    Post subject: Miscellaneous end of year questions Reply with quote
did you remove one/both? of them to install stall warning? My QBs stayed on; I never removed them. send me a phone number; I will be back home tomorrow afternoon.
kearney
PostPosted: Sat Jan 01, 2011 7:42 am    Post subject: Miscellaneous end of year questions Reply with quote
Hi Bruce
I want to inspect / flush the tankxs for leaks before I start flying (and wing install). It would seem this would be easier and more effective with the tanks off.
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bruce Johnson
Sent: December-31-10 10:22 PM
 DIV { MARGIN: 0px } Are your passengers standing on any part of the tank when loading/unloading?
dlm34077(at)q.com
PostPosted: Sat Jan 01, 2011 7:59 am    Post subject: Miscellaneous end of year questions Reply with quote
If the tanks/wings were QB and tested by Vans, why take them off now before flight and risk causing a leak. tanks can be removed after wing installation; hence after phase I if necessary. I flushed with mineral spirits to get the bits of proseal out and flew. No leaks or clogs after 375 hours. Only two tiny specks in the fuel filter screen when checked at 300 hours.
kearney
PostPosted: Sat Jan 01, 2011 8:02 am    Post subject: Miscellaneous end of year questions Reply with quote
Hi Wayne
Thanks for the detailed wire run info. I like how you have allowed for the
removal of the vertical stab. It sounds like the best plan for me is to use
Dave Saylor's "coil" method (thanks Dave) and skip the spiral wrap. I have
flown in -15c and I suspect the spiral wrap would become brittle and break
at that temperature.
Cheers & Happy New Year
Les
rv10flyer
PostPosted: Sat Jan 01, 2011 9:19 am    Post subject: Re: Miscellaneous end of year questions Reply with quote
Dave has some good ideas there. Thank you. Going to visit you someday out there.
Kearney, A single wire or even a few might do fine doing the coil method, but I installed the Whelen gray cable(3- 16ga w/shield) and there is no way to coil that without removing the outer jacket/shield.
You won't have to worry about the spiral wrap anywhere we fly. We used this on many military aircraft.
My spiral wrap specs: PTFE (TFE, Polytetrafluoroethylene) -450 °F to +500 °F. Chemically inert and non-flammable. Standard color is Natural. Black and other colors available.
Wayne G.
Kelly McMullen
PostPosted: Sat Jan 01, 2011 10:42 am    Post subject: Miscellaneous end of year questions Reply with quote
There is nothing about the remove/reinstall process that will influence whether the tanks leak or don't. None of the attach hardware penetrates the sealed area.
On Sat, Jan 1, 2011 at 8:55 AM, DLM <dlm34077(at)q.com (dlm34077(at)q.com)> wrote:
[quote] If the tanks/wings were QB and tested by Vans, why take them off now before flight and risk causing a leak. tanks can be removed after wing installation; hence after phase I if necessary. I flushed with mineral spirits to get the bits of proseal out and flew. No leaks or clogs after 375 hours. Only two tiny specks in the fuel filter screen when checked at 300 hours.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Mauledriver(at)nc.rr.com
PostPosted: Sun Jan 02, 2011 2:08 pm    Post subject: Miscellaneous end of year questions Reply with quote
2 more observations....
I had the same problem with the RayAllen wires using my no-name grip and strip type stripper. They were the only 24-26 gauge wires on the project. My strippers worked very well on every other (larger) gauge wire. The wires on the RayAllens are too thin is my thought.
Had the same problem with my QB tanks. What I found was that all phillips head drivers are not the same. Using my Craftsman drivers, I could only maul them. My neighbor cut some old drivers he had and welded on T-handles. The extra leverage seemed to help and I was able to remove one tank. On the second tank I accidentally picked up a rusty long shaft Enderes driver and found I could remove the screws without mauling them. I ended up buying a set of Enderes drivers - they are good but no magic. That particular rusty, long shaft driver is just particularly good.
http://everything2.com/title/The+Perfect+Screwdriver?bookmark_nonce=114f7664880ed9680ced7d19b5bf6a73&bookmark_id=883913&bookmark_seed=871591566.59759&op=bookmark
But all Phillips drivers are not equal. Try some different ones.
I'm not sure removing the tanks was such a good idea since all I did was air/balloon test them. If they leak with fluid in them, they will have to come off again. However, I did remove the screws for painting so it will look good if they do come off.
I really enjoyed the wiring - one of my favorite parts of the build.
Bill "waiting for warmer painting weather" Watson
Goto page 1, 2  Next
Page 1 of 2
