Fuel Decals
bressler(at)wyoming.com
PostPosted: Fri Dec 31, 2010 11:13 am    Post subject: Fuel Decals Reply with quote
Greetings for the New Year:
We have a 601 XLB with a Jabiru 3300 and are about to fix the wings to the fuse. Fuel options are 100LL or 95 octane mogas. Has any one suggestions how to label the fuel caps? (DO NOT ARCHIVE)
Thanks.   Wes & Lurlene Bressler - Laramie, WY
flyadive(at)gmail.com
PostPosted: Fri Dec 31, 2010 11:47 am    Post subject: Fuel Decals Reply with quote
There is no 95 octane mogas.  So just label the for fuel of 91 octane or higher.Do not specify MoGas or AvGas
On Fri, Dec 31, 2010 at 2:10 PM, Wes or Lurlene Bressler <bressler(at)wyoming.com (bressler(at)wyoming.com)> wrote:
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
arget="_blank">http://www.matronics.com/Navigator?Zenith-List
tp://forums.matronics.com
rpf(at)wi.rr.com
PostPosted: Fri Dec 31, 2010 2:35 pm    Post subject: Fuel Decals Reply with quote
Here's how I labeled mine.
 Filesize:  40.43 KB
 Viewed:  4115 Time(s)
jeffrey_davidson(at)earth
PostPosted: Fri Dec 31, 2010 7:26 pm    Post subject: Fuel Decals Reply with quote
I use 1100LL only so I labeled it that way. For that I simply used a sticker from ACS. Frankly, you can add the 95 Octane label with a "permanent marker" until you get the plane painted. Don't forget to label the capacity of the fuel tank too.
Jeff D.
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Wes or Lurlene Bressler
Sent: Friday, December 31, 2010 2:10 PM
Subject: Fuel Decals
