Alternate Air intake
Goto page 1, 2  Next
philperry9(at)gmail.com
PostPosted: Wed Dec 29, 2010 8:56 pm    Post subject: Alternate Air intake Reply with quote
I'm just curious how many people have alternate air intake doors on their airplanes and if anyone has seen a need for one?
Phil [quote][b]
dlm34077(at)q.com
PostPosted: Wed Dec 29, 2010 9:14 pm    Post subject: Alternate Air intake Reply with quote
which alternate air? engine yes; have not used. alternate air for pitot static system yes and never used. I use the engine air intake as a door opening on the underside of the airbox which bypasses the filter. Since I have no round gauges I use a Curtiss valve in the panel to open the static line in case of airframe icing of the static ports. hope it never happens.
Tim Olson
PostPosted: Wed Dec 29, 2010 9:39 pm    Post subject: Alternate Air intake Reply with quote
If you mean on the FAB, yes...it's something you definitely
want to have. You don't need to build the carb heat
valve if you are using an IO-540 though...just the
alternate air. It's an emergency only thing, so you
won't need it until you really NEED it.
Tim Olson - RV-10 N104CD
Phil
rv10builder(at)verizon.ne
PostPosted: Thu Dec 30, 2010 7:54 am    Post subject: Alternate Air intake Reply with quote
insurance! yes I have it installed for the engine.
no, I hope I never need it, but if the inlet gets plugged I'll be darn glad to have it.
if you mean the alt air for static, inside the cabin, no I have other redundancies to make up for that failure.
On this topic, what have others done to cover the alt air knob so it does not get confused for a brake, or heat.. Mine sits in the Vans stock position (left of throttle) and I fear I may pull it one night by mistake.
Pascal
Sent: Wednesday, December 29, 2010 8:53 PM
Subject: Alternate Air intake
Phil[quote]
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
jchang10
PostPosted: Thu Dec 30, 2010 8:21 am    Post subject: Alternate Air intake Reply with quote
I have it installed. While installing it, I recalled a story from a friend of mine.
As a much younger and bolder pilot, he ended up flying his C182 in near white-out snowy conditions. He said all of the snow he had injested had blocked up his air filter giving him issues. I don't recall all the details, but he was lucky to get it down at an airport that miraculously appeared in front of him, to the amazement of the FBO workers.
Jae
40533
On 12/29/2010 8:53 PM, Phillip Perry wrote: [quote]
Phil
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
PostPosted: Thu Dec 30, 2010 9:01 am    Post subject: Alternate Air intake Reply with quote
Yeah I'm not asking about the static, that's pretty easy and I have it installed.   I'm more concerned with a blocked filter scenario.
Does anyone have photos of their installation?  Cowling mods, etc?  I'm trying to get my mind around the plumbing, etc.
Thanks for the help,
Phil [quote][b]
dlm34077(at)q.com
PostPosted: Thu Dec 30, 2010 9:36 am    Post subject: Alternate Air intake Reply with quote
The letters STOP on the knob; my buddy did pull it once; and yes it is possible to close it manually by an alumimium tube several feet long underneath the aircraft. cowling was not removed.
PostPosted: Thu Dec 30, 2010 9:39 am    Post subject: Alternate Air intake Reply with quote
When you get the FAB it has the directions. It is basically a hole under the center of the airbox/air filter with a guillotine type door, it goes back through the firewall and, in my case, sits next to the throttle. That is all completely stock.
When you ask for a cowling mod.. are you getting a non stock cowling? engine? etc? otherwise you're thinking this too hard, it is all pretty simple stuff.
Pascal
Sent: Thursday, December 30, 2010 8:57 AM
Subject: Re: Alternate Air intake
Phil[quote]
PostPosted: Thu Dec 30, 2010 9:42 am    Post subject: Alternate Air intake Reply with quote
Phil[quote]
Tim Olson
PostPosted: Thu Dec 30, 2010 9:48 am    Post subject: Alternate Air intake Reply with quote
There's nothing really to it. It's a guillotine type valve
on the bottom of the airbox. You pull the cable and the
blade swings open and opens a hole directly into your
intake....inside the filter.
There was a maintenance issue with this, BTW....rivets in
fibergalss...no aluminum backing...not good. I fixed
mine recently:
http://www.myrv10.com/N104CD/maintenance/20090503/index.html
Here's the bottom of the box:
http://www.myrv10.com/N104CD/engine/20051127/RV200511220080.html
So there really isn't any plumbing required.
Phil
pilotdds(at)aol.com
PostPosted: Thu Dec 30, 2010 10:56 am    Post subject: Alternate Air intake Reply with quote
I have used the alternate air in a mooney when the air filter presumably iced up-wings were ice protected-mp gradually dropped to 14 inches with a tubocharged engine-activating the alternate air returned power to near normal-safety dictates having the option to bypass the airfilter.Another thing to watch for are the rivets in the vans airbox pulling through the glass-this happened to one of mine-I replaced them with small screws and washers+ a little extra glass,I was an early version that had a trapdoor desined to automatically open like a c-206 or 210.Vans issued a S.B. to go to a manual system.It was the manual system that developed loose rivets in the glass.-Happy new year and lets go for 0 accidents in 2011-jim
gengrumpy(at)aol.com
PostPosted: Thu Dec 30, 2010 11:37 am    Post subject: Alternate Air intake Reply with quote
I agree with Dave.
My knob is painted white (all others black) with red letters on it saying ALT AIR.
I can push mine close from underneath as well with long screwdriver or something similar.
grumpy
On Dec 30, 2010, at 11:27 AM, DLM wrote:
[quote]The letters STOP on the knob; my buddy did pull it once; and yes it is possible to close it manually by an alumimium tube several feet long underneath the aircraft. cowling was not removed.
[quote]---
PostPosted: Thu Dec 30, 2010 11:52 am    Post subject: Alternate Air intake Reply with quote
Like Tim, I did not like just the stock kit.
So I modified mine by adding a large aluminum plate on the bottom of
the fiberglass housing. That gave a solid base for the door.
Then I added 2 long bolts (fwd and aft bolts on bottom picture) that
go from the bottom plate to the top plate for added security.
grumpy
mine recently:
> it
> I'm
> Phil
pastedGraphic.pdf
 Filename:  pastedGraphic.pdf
 Filesize:  169.71 KB
 Downloaded:  541 Time(s)
pastedGraphic.pdf
 Filesize:  161.7 KB
 Downloaded:  368 Time(s)
jesse(at)saintaviation.co
PostPosted: Thu Dec 30, 2010 5:46 pm    Post subject: Alternate Air intake Reply with quote
There have already been a lot of replies, but IIRC, the plans call the trap door in the front of the FAB the "alternate air" and the one on the bottom the "air filter bypass". I think the air filter bypass is definitely needed, but not the alternate air, which really, as Tim mentioned, just acts as a carb heat. I have personally never had to use either. In the case of icing conditions, I can see how the alternate air could possibly be a help that could avoid needing to bypass the filter, but beyond that one scenario, the alternate air seems to add no service. I always install the bypass door so it an be closed by pushing the knob, but I realize that if it has to be used, it will likely not need to be closed again in flight, so that's probably not very important.
Jesse Saint
Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
Phil
taildragon(at)msn.com
PostPosted: Thu Dec 30, 2010 6:34 pm    Post subject: Alternate Air intake Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I don't usually get worked up over threads like this but I have a problem with any control in the cabin that is not reversible. Under what conditions (scenario) would you pull such a control, realizing that once you did, you can't reverse it? I am not trying to be ornery here, just trying to learn something so please educate me.
Roger
[quote] Original Message -----
Sent: Thursday, December 30, 2010 5:41 PM
Jesse Saint
C: 352-427-0285
F: 815-377-3694
Phil
title='about:3D"http://www.aeroelectric.com"' href='3D"http://www.aeroelectric.com"'>www.aeroelectric.com
title='about:3D"http://www.buildersbooks.com"' href='3D"http://www.buildersbooks.com"'>www.buildersbooks.com
title='about:3D"http://www.homebuilthelp.com"' href='3D"http://www.homebuilthelp.com"'>www.homebuilthelp.com
title='about:3D"http://www.matronics.com/contribution"' href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution
title='about:3D"http://www.matronics.com/Navigator?RV10-List"' href='3D"http://www.matronics.com/Navigator?RV10-List"'>http://www.matronics.com/Navigator?RV10-List
href='3D"http://forums.matronics.com"'>http://forums.matronics.com
indigoonlatigo(at)msn.com
PostPosted: Thu Dec 30, 2010 6:37 pm    Post subject: Alternate Air intake Reply with quote
How about using fuel tank sealant on the airfilter bypass door in addition to the rivets??
As for also installing the carburator heat door, seems to me that activating this door once the realization of icing or hail would be prudent and may allow one to not have to activate the "air filter bypass door". Seeing that the later cannot be closed in flight, the carb heat door would be the first line of defense.
Shut down proceedures might also be to close the Carb heat door to keep snow, nesting birds, other critters or insects out.
Just thinking out loud.
getting close to paint
John G
Date: Thu, 30 Dec 2010 20:41:52 -0500
Jesse Saint
C: 352-427-0285
F: 815-377-3694
[quote]Yeah I'm not asking about the static, that's pretty easy and I have it installed.   I'm more concerned with a blocked filter scenario.
Phil
s.com
on
RV10-List
dlm34077(at)q.com
PostPosted: Thu Dec 30, 2010 6:51 pm    Post subject: Alternate Air intake Reply with quote
The control only bypasses filtering air to the engine. So a ground reset is not an issue. If it is ever used the PIC won't be worrying about reset but getting the iced up 10 on the ground.
Dick Sipp
PostPosted: Thu Dec 30, 2010 6:57 pm    Post subject: Alternate Air intake Reply with quote
Think about a bird strike that plugs the normal air intake. There is no harm done in actuating the alternate air door, the engine operation not be effected much if at all and there would be no need to reverse until after landing. I know it is not designed to be “closed in flight” but my control will open and close the door at least with the engine shut down and on the ground. I have not tried it in flight.
Dick Sipp
N110DV 300 hours
Roger
Jesse Saint
C: 352-427-0285
F: 815-377-3694
Phil
pitts_pilot(at)bellsouth.
PostPosted: Thu Dec 30, 2010 7:10 pm    Post subject: Alternate Air intake Reply with quote
I'm with Roger ..... and since I'm not to that point, please tell me what prevents installation of a 'reversible' bypass control???
Linn
On 12/30/2010 9:31 PM, Roger Standley wrote: [quote] <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I don't usually get worked up over threads like this but I have a problem with any control in the cabin that is not reversible. Under what conditions (scenario) would you pull such a control, realizing that once you did, you can't reverse it? I am not trying to be ornery here, just trying to learn something so please educate me.
Roger
Subject: Re: RV10-List: Alternate Air intake
Jesse Saint
C: 352-427-0285
F: 815-377-3694
Phil
title='[url=about:3D]about:3D[/url]"http://www.aeroelectric.com"' href='3D"http://www.aeroelectric.com"'>www.aeroelectric.com
title='[url=about:3D]about:3D[/url]"http://www.buildersbooks.com"' href='3D"http://www.buildersbooks.com"'>www.buildersbooks.com
title='[url=about:3D]about:3D[/url]"http://www.homebuilthelp.com"' href='3D"http://www.homebuilthelp.com"'>www.homebuilthelp.com
title='[url=about:3D]about:3D[/url]"http://www.matronics.com/contribution"' href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution
title='[url=about:3D]about:3D[/url]"http://www.matronics.com/Navigator?RV10-List"' href='3D"http://www.matronics.com/Navigator?RV10-List"'>http://www.matronics.com/Navigator?RV10-List
PostPosted: Thu Dec 30, 2010 8:05 pm    Post subject: Alternate Air intake Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> OK, agreed. But let's follow this icing scenario. I am flying along and notice a drop in MP as the filter and maybe a drop in AS as the pitot ices up. I add throttle and get little response, maybe a drop in EGT. So I suspect icing? I pull Alt Air (it's reversible). MP gradually increases. AS continues to drop. I look at the GPS ground speed and see no change. I am thinking, the pitot is icing over, the engine filter was icing over but the Alt Air is working and keeping the engine going near normal. I descent looking for warmer air.
Is this the right way to work through this?
Roger
Goto page 1, 2  Next
Page 1 of 2
