Twin & Turbine Article
rcdettmer(at)charter.net
PostPosted: Mon Dec 27, 2010 6:41 am    Post subject: Twin & Turbine Article Reply with quote
Great article in the latest “Twin & Turbine” magazine about the Shrike Commander (Cover article). Also kudos to Barry Coleman for a mention of his upcoming book about Commanders. Nice going Barry. Happy New Year everyone..!!
Randy Dettmer, AIA, NCARB
680F / N6253X
Dettmer Architecture
663 Hill Street
San Luis Obispo, CA 93405
805 541 4864 / Fax 805 541 4865
www.dettmerarchitecture.com
 Filesize:  2.9 KB
 Viewed:  5387 Time(s)
barry.collman(at)air-brit
PostPosted: Mon Dec 27, 2010 7:27 am    Post subject: Twin & Turbine Article Reply with quote
Hello Randy,
I haven’t seen the article but I guess Chris Haag, a good friend of mine who owned the Shrike and is helping with the book, got that published.
I’m hoping he’ll forward a copy of the article, as one is supposed to be sent to him by the publishers.
Hope you all had an enjoyable Christmas and send very best wishes for 2011.
Best Regards,
Barry
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Randy Dettmer, AIA
Sent: 27 December 2010 14:38
Subject: Twin & Turbine Article
680F / N6253X
663 Hill Street
 Filesize:  2.9 KB
 Viewed:  5386 Time(s)
nico(at)cybersuperstore.c
PostPosted: Mon Dec 27, 2010 8:50 am    Post subject: Twin & Turbine Article Reply with quote
Hi Barry,
Would it be presumptuous to hope that the Commander list's members would get an advance copy of the book when it goes on sale?
Nico
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Barry Collman
Sent: Monday, December 27, 2010 7:22 AM
Subject: RE: Twin & Turbine Article
Hello Randy,
Best Regards,
Barry
680F / N6253X
[img]cid:444144516(at)27122010-2AA5[/img]
663 Hill Street
 Filesize:  2.9 KB
PostPosted: Mon Dec 27, 2010 10:28 am    Post subject: Twin & Turbine Article Reply with quote
Hi Nico,
The short answer is I don’t know!
The book is still some way off and a publication date, and indeed a publisher, are not yet known.
Best Regards,
Barry
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of cybersuperstore
Sent: 27 December 2010 16:47
Hi Barry,
Nico
Hello Randy,
Best Regards,
Barry
680F / N6253X
663 Hill Street
 Filesize:  2.9 KB
 Viewed:  5384 Time(s)
andrew.bridget(at)telus.n
PostPosted: Mon Dec 27, 2010 7:53 pm    Post subject: Twin & Turbine Article Reply with quote
Hi Barry,
If you want some advice about a publisher to avoid, contact me off-list.
Andrew
 Filesize:  2.9 KB
 Viewed:  5377 Time(s)
Peter.Bichier(at)utoledo.
PostPosted: Mon Dec 27, 2010 9:03 pm    Post subject: Twin & Turbine Article Reply with quote
Commanders,
Dianne White (Twin & Turbine editor) kindly shared the article with me:
Follow this link to the e-edition!
http://digital.turn-page.com/issue/20532
Merry Christmas & Happy New Year!
Peter Bichier
Lake Erie Center (Univeristy of Toledo)
Department of Environmental Sciences
(419) 530-8384
 Filesize:  2.9 KB
 Viewed:  5376 Time(s)
wjrhamilton(at)optusnet.c
PostPosted: Mon Dec 27, 2010 10:36 pm    Post subject: Twin & Turbine Article Reply with quote
Folks,
Read the article, made me more than a little envious.
However, there was one quite disturbing "recommendation" in using the JPI to run the engines 20 degrees on the rich side of peak EGT, a recipe for maximizing the chance of detonation. If you want to run rich of peak, make it more like 40+ colder.
If the engines had a set of GAMI injectors, you would be able to run on the lean side of peak EGT. Another furphie ( an Australian expression --- a bit like a factual Murphie --- but that ain't where the word came from) is that minimum fuel flow is at peak EGT ---- not if you are running lean of peak, it isn't.
I also notice another bit of disinformation in another article about in-flight icing, repeating "old wives tales" about the temperature range for icing, we have known better for the last 40 or so years.
Bill Hamilton
[quote] Bichier, Peter <Peter.Bichier(at)utoledo.edu> wrote:
Commanders,
Peter Bichier
(419) 530-8384
BobsV35B(at)aol.com
PostPosted: Tue Dec 28, 2010 3:31 am    Post subject: Twin & Turbine Article Reply with quote
Good Morning Bill,
If I may expand on your comments just a bit:
We should designate whether we are discussing Fahrenheit or Celsius temperatures.
The absolutely hottest and most potentially harmful place to operate any normal conforming piston engine is around fifty to sixty degrees Fahrenheit rich of peak EGT.
That is also the point where the engine will develop the most power possible given the amount of air being pumped through it. If it is normally aspirated and being operated above sixty-five to seventy-five percent power, it should be run at least 100 degrees Fahrenheit richer than peak EGT. Preferably one hundred and fifty.
If you want to get the most power possible out of every drop of fuel being used, you must operate on the lean side of peak somewhere between twenty and eighty degrees Fahrenheit. Twenty degrees works for power settings around fifty per cent and eighty lean of peak works well for supercharged engines that can be operated as high as eighty per cent power. The absolute worst place to operate a normally aspirated engine is fifty rich of peak at a power above sixty-five percent.
Below sixty-five percent power you can't hurt the engine with the mixture control.
All temperatures in Fahrenheit of course!<G>
All of the above assumes balanced fuel flow to each of those little engines that are connected to the same crankshaft.
Does that agree with your thinking?
It IS what I was taught in Ada at the Advanced Pilot Seminars. <G>
Happy Skies,
Old Bob
In a message dated 12/28/2010 12:36:37 A.M. Central Standard Time, wjrhamilton(at)optusnet.com.au writes:
[quote]--> Commander-List message posted by: William J Hamilton <wjrhamilton(at)optusnet.com.au>
Folks,
Bill Hamilton
Commanders,
Peter Bichier
(419) 530-8384
jimjan(at)us.ibm.com
PostPosted: Tue Dec 28, 2010 6:20 am    Post subject: Twin & Turbine Article Reply with quote
Jim Janaitis-----------------
Sent from my BlackBerry Handheld.
From: "cybersuperstore" [nico(at)cybersuperstore.com]
Sent: 12/27/2010 08:47 AM PST
To: <commander-list(at)matronics.com>
Hi Barry,
Nico
Hello Randy,
Best Regards,
Barry
680F / N6253X
663 Hill Street
 Filesize:  2.9 KB
 Viewed:  5372 Time(s)
PostPosted: Tue Dec 28, 2010 6:31 am    Post subject: Twin & Turbine Article Reply with quote
That resonates with what I was taught. But, that was in Africa, so you never know. Very Happy
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com
Sent: Tuesday, December 28, 2010 3:27 AM
Subject: Re: Twin & Turbine Article
Good Morning Bill,
Happy Skies,
Old Bob
Folks,
Bill Hamilton
Commanders,
Peter Bichier
(419) 530-8384
PostPosted: Tue Dec 28, 2010 6:25 pm    Post subject: Twin & Turbine Article Reply with quote
Old Bob,
I agree with you entirely.
I have been operating IO-540 Lycoming lean of peak since the 1960's, using 6 point temp. probes on all exhaust pipes, the relatively recent availability of calibrated injectors (GAMI) improves the efficiency even further.
Factory "recommendations" have varied over the years, but I still have the Lycoming (not Piper) engine handbook for the first IO-540 we ever had, in a 260C Comanche, and the lean of peak recommendations were clear and simple.
Quite apart from the fuel savings ( there are equal HP point either side of the peak HP point of the power curve) lean of peak running left us with (then) 1500h TBO cylinders that were so little worn that it was often possible to just deglaze, without boring oversize. As you mentioned, running on the air cold side of peak EGT means the mixture is too week for detonation.
Admittedly, we always ran with filter on both the hot and cold air, which helps in dusty conditions. And we always ran high boost, low rpm, essentially full throttle from takeoff, just winding the RPM back on climb, to give the % power required, until TOD.
If and when I get the -500A back in the air, it will have GAMI and 6 point EGT on the IO-470s (or maybe 520s, if I can manage it, $$$) and lean of peak will be the order of the day.
Bill Hamilton
[quote] BobsV35B(at)aol.com wrote:
Good Morning Bill,
temperatures.
Fahrenheit
rich of peak EGT.
normally
power, it
being
around
engines
worst
mixture
control.
engines
Happy Skies,
Old Bob
Folks,
JPI
for
make it
--- a
is
of
peak, it isn't.
range for
Bill Hamilton
> Commanders,
me:
> Peter Bichier
> (419) 530-8384
BobsV35B(at)aol.com
PostPosted: Wed Dec 29, 2010 6:03 am    Post subject: Twin & Turbine Article Reply with quote
Good Morning Bill,
I know it is very easy to spend someone else's money, but has anyone considered using the IO-550 in lieu of the 520 or 470 in that model Commander?
The 550 weighs the same and is physically identical in size to the 520. Continental is charging two to three thousand more for the 550 than the 520, but I will bet it costs them no more to build a 550 than it does to build a 520, or, for that matter, the 470.
Is the Sand Cast case required for the Commander? Not sure how Colemill is doing, but they do hold the certificate for an engine Continental builds for them which uses the old sand cast case with the new crank, cylinders,  and pistons to provide 550 cubic inches and three hundred horsepower. Not sure if it is available now, but that engine should work in your airplane if no one has an approval for the Permold case.
I am now on the third IO-550-B in my Bonanza and could not be happier. I fly higher, faster, and burn less fuel!
What is not to like?
Happy Skies,
Old Bob
In a message dated 12/28/2010 8:25:50 P.M. Central Standard Time, wjrhamilton(at)optusnet.com.au writes:
Old Bob,
Bill Hamilton
Good Morning Bill,
temperatures.
Fahrenheit
rich of peak EGT.
normally
power, it
being
around
engines
worst
mixture
control.
engines
Happy Skies,
Old Bob
Folks,
JPI
for
make it
--- a
is
of
peak, it isn't.
range for
Bill Hamilton
> Commanders,
me:
> Peter Bichier
> (419) 530-8384
