Performance numbers at higher alt.
rick.conti(at)boeing.com
PostPosted: Tue May 02, 2006 10:47 am    Post subject: Performance numbers at higher alt. Reply with quote
I would think an antenna lying on its side would not be as effective as one protruding from the fuselage, if for no other reason the polarity will be horizontal vice vertical and that can cause significant signal loss.  Also, the radiation pattern will be greater outward on the aircraft side, since the aircraft is in fact the ground plane.
Thank You
Rick Conti
Senior Engineering Manager
The Boeing Company
          office: 703 - 414 - 6141
blackberry: 571 - 215 - 6134
Sent: Tuesday, May 02, 2006 2:17 PM
Subject: RE: RV10-List: Performance numbers at highter alt.
I can remember reading, but don’t know where, that you ground it through the nutplate.  I.e. you rivet the antenna between the nutplates and the wingtip.
Rene' Felker
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)aol.com
Sent: Tuesday, May 02, 2006 11:52 AM
Subject: Re: RV10-List: Performance numbers at highter alt.
Randy,I have a flying Rv-10.Panel was built by aerocraft.I am trying to mount Bob archer ant and am curious how you grounded it given the fact the wingtips slide inside the skin?Anyone else familiar and have suggestions?
Tdawson(at)avidyne.com
PostPosted: Tue May 02, 2006 11:03 am    Post subject: Performance numbers at higher alt. Reply with quote
Nah, I’d call THIS a ground plane . .
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Conti, Rick
Sent: Tuesday, May 02, 2006 2:43 PM
Subject: RE: RV10-List: Performance numbers at higher alt.
Thank You
Rick Conti
The Boeing Company
Rene' Felker
 Filesize:  42.99 KB
 Viewed:  319 Time(s)
PostPosted: Tue May 02, 2006 11:17 am    Post subject: Performance numbers at higher alt. Reply with quote
If you look closely, you’ll see he doesn’t need an antenna.  All the pilot has to do is stick his head out the door and yell for a taxi clearance.
Thank You
Rick Conti
The Boeing Company
From: Tim Dawson-Townsend [mailto:Tdawson(at)avidyne.com]
Sent: Tuesday, May 02, 2006 3:00 PM
Thank You
Rick Conti
The Boeing Company
Rene' Felker
 Filesize:  42.99 KB
 Viewed:  293 Time(s)
wcurtis(at)core.com
PostPosted: Tue May 02, 2006 12:15 pm    Post subject: Performance numbers at higher alt. Reply with quote
[quote]I would think an antenna lying on its side would not be as >effective as one protruding from the fuselage, if for no other >reason the polarity will be horizontal vice vertical and that can >cause significant signal loss. Also, the radiation pattern will be >greater outward on the aircraft side, since the aircraft is in fact >the ground plane. Rick, My assumption here is we are talking about the Bob Archer NAV antennas. That being so, these operate best horizontally. Think of the "cat whiskers" and "bow tie" NAV antennas in production aircraft. Comm antennas on the other hand, are another story. They operate best vertically. William Curtis http://nerv10.com/
PostPosted: Tue May 02, 2006 12:43 pm    Post subject: Performance numbers at higher alt. Reply with quote
Roger that.
DO NOT ARCHIVE
Thank You
Rick Conti
The Boeing Company
Sent: Tuesday, May 02, 2006 4:13 PM
To: RV10-List(at)matronics.com
Subject: RE: Performance numbers at higher alt.
>the ground plane.
Rick,
William Curtis
http://nerv10.com/
rvbuilder(at)sausen.net
PostPosted: Tue May 02, 2006 12:52 pm    Post subject: Performance numbers at higher alt. Reply with quote
Nav, MB antennas = horizontally polarized
Com, transponder, = vertically polarized
Sat based antennas = circularly polarized (no ground plane)
Subspace antennas = strange polarization (quantum ground plane)
Michael Sausen
RV-10 #352 Working on Fuselage
Recent RV-10 Build Activity
Sent: Tuesday, May 02, 2006 1:43 PM
Thank You
Rick Conti
The Boeing Company
Subject: RE: Performance numbers at highter alt.
Rene' Felker
Subject: Re: Performance numbers at highter alt.
-----Original Message-----
Sent: Sun, 30 Apr 2006 10:35:46 -0700
Subject: Performance numbers at highter alt.
10.500 alt
20.6 mp
2300 rpm
12.4 gph
136 ind
162 adj
159 gs
10,520 alt.
11,390 density alt Dynon
136kts ind
160 kts adj.
155 kts gs.
12.2 gph
62% power
13,500
13,610 adj dynon
11.3 gph
18.3 mp
2300 rpm
130 kts ind.
162 kts adj
12 gph
151 kts gs (headwind)
Randy N610RV
deej(at)deej.net
PostPosted: Tue May 02, 2006 1:05 pm    Post subject: Performance numbers at higher alt. Reply with quote
Main deflector? *grin*
-Dj
Randy(at)abros.com
PostPosted: Tue May 02, 2006 4:03 pm    Post subject: Performance numbers at higher alt. Reply with quote
Rick, I have 2 com antennas. One whip and one in the wing tip.  The wing tip is about 70% as good as the whip.  Plenty good enough if you don’t want extra antenna hanging out.  Personal choice.  Randy
Sent: Tuesday, May 02, 2006 11:43 AM
Thank You
Rick Conti
The Boeing Company
Rene' Felker
bob.kaufmann(at)cox.net
PostPosted: Tue May 02, 2006 5:39 pm    Post subject: Performance numbers at higher alt. Reply with quote
I’d call it a job opening.
Bob K
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Dawson-Townsend
Sent: Tuesday, May 02, 2006 11:00 AM
Thank You
Rick Conti
The Boeing Company
Rene' Felker
 Filesize:  42.99 KB
 Viewed:  287 Time(s)
