Randy(at)abros.com Guest
Posted: Sun Apr 30, 2006 9:38 am Post subject: Performance numbers at highter alt. |
10.500 alt
20.6 mp
2300 rpm
12.4 gph
136 ind
162 adj
159 gs
10,520 alt.
11,390 density alt Dynon
136kts ind
160 kts adj.
155 kts gs.
12.2 gph
62% power
13,500
13,610 adj dynon
11.3 gph
18.3 mp
2300 rpm
130 kts ind.
162 kts adj
12 gph
151 kts gs (headwind)
Randy N610RV
pilotdds(at)AOL.COM Guest
Posted: Tue May 02, 2006 9:56 am Post subject: Performance numbers at highter alt. |
Randy,I have a flying Rv-10.Panel was built by aerocraft.I am trying to mount Bob archer ant and am curious how you grounded it given the fact the wingtips slide inside the skin?Anyone else familiar and have suggestions?
rene(at)felker.com Guest
Posted: Tue May 02, 2006 10:21 am Post subject: Performance numbers at highter alt. |
I can remember reading, but don’t know where, that you ground it through the nutplate. I.e. you rivet the antenna between the nutplates and the wingtip.
Rene' Felker
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)aol.com
Sent: Tuesday, May 02, 2006 11:52 AM
Subject: Re: RV10-List: Performance numbers at highter alt.
Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Tue May 02, 2006 11:00 am Post subject: Performance numbers at highter alt. |
Check this site ... www.rvproject.com .. Dan Checkoway has done the grounding with wingtip antenna and reports good reception. I tried to find the specific address relating to your request, but was unable. I think there is a search function ... sorry I can't be of more help. With patience you'll find it.
Jerry Grimmonpre'
RV8A Electrical
jesse(at)itecusa.org Guest
We did it under the nutplates if I remember correctly, so it grounds through all of the screws and into the skin. I have seen another installation that uses aluminum angle on the outboard most rib and it doesn’t remove with the wingtips. I think I am going that way with this one. Not going to do another Wingtip COM, but the NAV seems to work great. Also going with the Marker antenna in the tip this time.
40415 in the paint and interior shop
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
Sent: Tuesday, May 02, 2006 12:52 PM
wcurtis(at)core.com Guest
Posted: Tue May 02, 2006 11:34 am Post subject: Performance numbers at highter alt. |
[quote]Randy,I have a flying Rv-10.Panel was built by aerocraft.I am >trying to mount Bob archer ant and am curious how you grounded it >given the fact the wingtips slide inside the skin?Anyone else >familiar and have suggestions? Use Aluminum tape. That and the screws through the nutplate will ensure conductive contact between the antenna and the wingtip. http://wcurtis.nerv10.com/07Wings/wings99y.html William Curtis 40237 - Fuse http://nerv10.com/
Posted: Tue May 02, 2006 4:03 pm Post subject: Performance numbers at highter alt. |
I grounded both through the nut plates. Nav and com work great. The com needs to be lifted up so it is as vertical as possible. I riveted an extra trip if alum to the bottom of the com antenna and then bent it so the antenna could angle up. Randy
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)AOL.COM
Sent: Tuesday, May 02, 2006 10:52 AM
jjessen
Posted: Wed May 03, 2006 12:35 pm Post subject: Performance numbers at highter alt. |
I must not understand how to search the archives correctly or perhaps what words to use for this one. I know it was discussed before. Anyway....
Problem: I have an extra hole (in my Tailcone top skin, fellas, sheesh.)
I didn't even know I had it until I began peeling off the plastic to get ready to final deburr my Tailcone front top skin. Sure enough there are two holes in the corresponding tab of the rib. Picture attached. Van's says to dimple and rivet and move on, since it's only one mistake in a long row of good holes. However, the holes in the skin are so close together that any dimpling will break through and make it a big hole. What to do?
John Jessen
~328 (this is my first mistake, of course)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Randy DeBauw
Sent: Tuesday, May 02, 2006 4:59 PM
Subject: RE: Performance numbers at highter alt.
Subject: Re: Performance numbers at highter alt.
-----Original Message-----
Sent: Sun, 30 Apr 2006 10:35:46 -0700
Subject: Performance numbers at highter alt.
10.500 alt
20.6 mp
2300 rpm
12.4 gph
136 ind
162 adj
159 gs
10,520 alt.
136kts ind
160 kts adj.
155 kts gs.
12.2 gph
62% power
13,500
13,610 adj dynon
11.3 gph
18.3 mp
2300 rpm
130 kts ind.
162 kts adj
12 gph
Randy N610RV
Posted: Wed May 03, 2006 1:08 pm Post subject: Performance numbers at highter alt. |
If the extra hole has a bulkhead flange behind it, simply bond the hole to
the flange and move on. I wouldn't(Didn't) put an extra rivet( in my case).
I accidentally made an extra hole with the C frame but it didn't go as far
as make the dimple. Use a metal epoxy after sanding all pieces and rivet
the rest as usual. Prep before painting and you will never ever see it
again.
John G. 409
[quote]From: "John Jessen" <jjessen(at)rcn.com>
Date: Wed, 3 May 2006 13:31:08 -0700
two
to
John Jessen
_____
_____
pascalreid(at)verizon.net Guest
Posted: Thu May 04, 2006 10:22 am Post subject: Performance numbers at highter alt. |
Randy;
I saw this report about props somewhere in my researching the RV-10 to death. Seeing your plane was compared to Vic Syracuse and the company plane, wondering if you could expand on this report, how valid is it?
Didn't see anything in the archives that covered if it did, please let me know where to look as I find the 11mph loss of the MT prop on Vic's plane compared to the 2 blade rather interesting.
Thanks!
Pascal
Description: |
Filesize: |
240.93 KB |
Viewed: |
410 Time(s) |
Description: |
Filesize: |
746.73 KB |
Viewed: |
427 Time(s) |
Posted: Mon May 08, 2006 4:03 pm Post subject: Performance numbers at highter alt. |
The 198 mph number on my plane was before I found the rigging problem. After running the numbers Ken Kruger recommended that I check the rigging. On the way home from Oshkosh I found that the Ailerons were 3/8” of an inch down from the flaps. I must not of had the flaps all of the way up when I set the Ailerons to match. I have not rerun the flight test to get a more accurate number. Randy
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Verizon
Sent: Thursday, May 04, 2006 11:17 AM
Randy;
Thanks!
Pascal
ericmpmail-rv10(at)yahoo. Guest
Posted: Mon May 08, 2006 9:22 pm Post subject: Performance numbers at highter alt. |
I thought at one point the RV-10 was going to have a
negative flap position for better cruise speeds. Does
anyone recall this as well? is full up zero or
slightly negative?
Eric
--- Randy DeBauw <Randy(at)abros.com> wrote:
[quote] The 198 mph number on my plane was before I found
that I check the
the Ailerons were
3/8" of an inch down from the flaps. I must not of
not rerun the
Behalf Of Verizon
highter alt.
Randy;
how valid is it?
it did, please let
Thanks!
Pascal
Posted: Tue May 09, 2006 4:23 am Post subject: Performance numbers at highter alt. |
Up 3 degrees from even with the wing cord is the cruise setting. We also
use this for climb so as not to forget to put it up, although they recommend
flat for climb.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
