dave.gribble(at)mchsi.com Guest
Posted: Sun Dec 12, 2010 10:39 am Post subject: Teflon Wire - 7 strands vs. 19 stands |
I found some surplus M16878/4BGB1 wire. I think it is 20 AWG wire with teflon insulation and coated copper conductors. It is made of 7 strands of wire. I know that newer wire is made of up 19 strands. Will the 7 strand wire "work" with crimp connections such as AMP FastOn and crimped D-sub pins?
Thanks for any info,
dave gribble
peter(at)sportingaero.com Guest
Posted: Sun Dec 12, 2010 1:07 pm Post subject: Teflon Wire - 7 strands vs. 19 stands |
It will be very much less flexible than 19 strand wire, and so may break
in service.
Peter
On 12/12/2010 18:35, dave.gribble(at)mchsi.com wrote:
dave gribble
Posted: Sun Dec 12, 2010 1:36 pm Post subject: Teflon Wire - 7 strands vs. 19 stands |
At 12:35 PM 12/12/2010, you wrote:
See attached file for description of M16878 wires.
Yes, you have a Type E (600v thin teflon) wire that
will be 20AWG silver coated 7 strand copper.
Teflon was never real popular as an airframe wire.
It's not very tough although the temperature ratings
are great. 7-strand wire is not a really big deal.
A quintrillion vehicles including airplanes have
be wired with 7-strand wire . . . and we don't seem
to be hearing about the lack of vibration resistant
stranding.
If you got this wire cheap and you're thinking about
using a lot of it (it could probably substitute for
22AWG in most applications, then it's probably a
cost effective thing to do with no significant
increase in risks.
 Download |
| Filename: |
M16878_wire.pdf |
110.77 KB |
| Downloaded: |
287 Time(s) |
Bob McC
Posted: Sun Dec 12, 2010 1:49 pm Post subject: Teflon Wire - 7 strands vs. 19 stands |
Dave;
Yes, it will "work" with respect to being properly secured by the various terminals/connectors etc. However, 19 strand is considerably more flexible and consequently more vibration resistant than 7 strand. Both may perform satisfactorily in your application but if there is flexing involved (vibration?) the finer stranding will last longer and will impart lower loads on the devices to which it is attached. Gauge for gauge its fatigue resistance will be greater and mechanical forces transmitted less. This is the reason Bob recommends “welding cable” for fat wires due to its extremely fine stranding and hence greater flexibility. (Having said all that the fatigue resistance of the 7 strand may exceed the life of the airframe, but regardless the 19 strand will outlast it from an apples to apples fatigue standpoint)
Bob McC
> -----Original Message-----
> From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-
> server(at)matronics.com] On Behalf Of dave.gribble(at)mchsi.com
> Sent: Sunday, December 12, 2010 1:36 PM
> To: aeroelectric-list(at)matronics.com
> Subject: Teflon Wire - 7 strands vs. 19 stands
> --> AeroElectric-List message posted by: dave.gribble(at)mchsi.com
> dave gribble
> _-
[b]> style='mso-spacerun:yes'> -- Please Support Your Lists This Month --
> style='mso-spacerun:yes'> (And Get Some AWESOME FREE Gifts!)
[b]> style='mso-spacerun:yes'> November is the Annual List Fund Raiser. Click on
> style='mso-spacerun:yes'> the Contribution link below to find out more about
> style='mso-spacerun:yes'> this year's Terrific Free Incentive Gifts provided
> style='mso-spacerun:yes'> by:
[b]> style='mso-spacerun:yes'> * AeroElectric www.aeroelectric.com
> style='mso-spacerun:yes'> * The Builder's Bookstore www.buildersbooks.com
> style='mso-spacerun:yes'> * HomebuiltHELP www.homebuilthelp.com
[b]> style='mso-spacerun:yes'> List Contribution Web Site:
[b]> style='mso-spacerun:yes'> --> http://www.matronics.com/contribution
[b]> style='mso-spacerun:yes'> Thank you for your generous support!
[b]> style='mso-spacerun:yes'> -Matt Dralle, List Admin.
[b]> _-
> style='mso-spacerun:yes'> - The AeroElectric-List Email Forum -
[b]> style='mso-spacerun:yes'> --> http://www.matronics.com/Navigator?AeroElectric-List
[b]> _-
> style='mso-spacerun:yes'> - MATRONICS WEB FORUMS -
[b]> style='mso-spacerun:yes'> --> http://forums.matronics.com
[b]> _-
_________________ Bob McC
Falco #908
(just starting) |
Posted: Sun Dec 12, 2010 2:04 pm Post subject: Teflon Wire - 7 strands vs. 19 stands |
Thanks Bob - great reply.. but I'm confused about why the 20AWG Teflon wire "could substitute for 22AWG in most applications"
dave
Posted: Sun Dec 12, 2010 3:44 pm Post subject: Teflon Wire - 7 strands vs. 19 stands |
At 03:58 PM 12/12/2010, you wrote:
If you have a drawing that calls out 22AWG, then
you either go out and buy some 22AWG or you consider
substituting 20AWG assuming you don't mind taking the
hit on weight (very small) and the wire will fit into
all the crimped pins.
In terms of footage, 22AWG wire is the most popular size
in most airplanes. We did try 24AWG in the Premier . . .
I think the techs on the line are used to it now but
there was a lot of fuss at the beginning. It's more
difficult to work with.
I think I suggested to this List many years ago that
builders buy full spools of 20AWG wire (1000'). It's
cheaper in large quantities and can be used wherever
the drawings call for 22 or 20AWG. This one size MIGHT
account for 90% of all your wiring footage in a small
airplane and ease your procurement task.
