Setting up the Fuel lines
WurlyBird
PostPosted: Fri Dec 10, 2010 2:39 am    Post subject: Setting up the Fuel lines Reply with quote
So when I get home I replacing my fuel tanks and re-running all the fuel lines since I don't like the way the builder did it. The fuel lines come out of the tanks on the bottom of the rear inboard portion of the tank, I believe this is where the drain or strainer is supposed to go. the port on the inboard side had a line with a valve on it that could be used, very infrequently, for draining fuel. Once inside the lines run behind the seat and under the door up to the header tank behind the panel. I don't like that the lowest point of the system is in aluminum tubing under the door. there is also no vent for the header as it is plugged off instead of going back to one of the tanks. this should go to the TOP of one tank, correct?
So how do you have your lines running? How does the manual recommend running the lines? Is there any benefit to going to the nylon header that goes behind the seat? Any other thoughts? Thanks.
James
James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl.
lcfitt(at)sbcglobal.net
PostPosted: Fri Dec 10, 2010 7:45 am    Post subject: Setting up the Fuel lines Reply with quote
James,
I think this will be pretty much the consensus over the years. The later
Kitfoxes use a header tank that is placed near the bottom behind the
passenger seat. Because this becomes the low point in the system many have
done away with the gascollator. The fuel lines are run from the main tanks
to the header tank, then at the side of the seat to the shut off valve.
Some, myself included have added a switchable 4.5 psi max Facet fuel pump in
the aluminum line just out of the header tank.
Lowell
From: "WurlyBird" <james.t.trizzino(at)us.army.mil>
Sent: Friday, December 10, 2010 2:40 AM
Subject: Setting up the Fuel lines
correct?
James
James
Kitfox 3 / 582 / 70&quot; IVO 2 blade GA
50 hrs on the Fox in between deployments,
now she lies in wait
http://forums.matronics.com/viewtopic.php?p=322817#322817
Pat Reilly
PostPosted: Fri Dec 10, 2010 9:44 am    Post subject: Setting up the Fuel lines Reply with quote
James, My fuel routing sounds similar to yours. But, I do have a vent line from the nylon header back to the wing tank. The header tank is to be mounted low behind the seat to give a reserve when steep desent unports a wing tank. I had an aluminum header tank mounted much higher and John McBean suggested the lower mounted nylon tank. I do have shut off valves on each wing tank supply line and the vent line also.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Fri, Dec 10, 2010 at 4:40 AM, WurlyBird <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)> wrote:
--> Kitfox-List message posted by: "WurlyBird" <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)>
James
James
ber is the Annual List Fund Raiser.  Click on
/" target="_blank">www.aeroelectric.com
omebuiltHELP www.homebuilthelp.com
http:/r generous support!
ronics List Features Navigator to browse
s.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Guy Buchanan
PostPosted: Fri Dec 10, 2010 2:04 pm    Post subject: Setting up the Fuel lines Reply with quote
James,
Let's see: wing tanks, strainer, 1' of 1/2" flex tube turning aft
along upper fuselage member above triangular window, converting to 3/8"
aluminum tube, around the seatbelt mount and back forward to the top of
the poly header tank low behind the bulkhead behind the right seat. 1/4"
Aluminum tube vent from the top of the header tank to the top of the
right wing tank. (Blue 1/4" fuel line from just over the rear corner of
the triangle window to the tank.) Fuel drain out the bottom of the
header tank. (My gascolator.) 3/8" fuel pickup centered two inches above
the bottom of the header tank to a fuel filter just forward of the
header tank, around the right seat below the door sill, back to
centerline to a fuel valve in my "center console", then forward through
the firewall just above the lower motor mount bolt.
The only benefit to the low aft header tank is that it acts as a
gascolator and that it vents uphill all the way to the wing tank. (You
have trouble pushing bubbles down hill.)
Guy Buchanan
Kitfox IV-1200 / 592 C / Warp 3cs
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Tom Jones
PostPosted: Sat Dec 11, 2010 8:35 am    Post subject: Re: Setting up the Fuel lines Reply with quote
James, I had mine plumbed like yours are but also did not like the low spot in the line under the door. I changed it to how the service Bulletin recommends with the panel tank. In the last picture the line under the windshield screw on the left is the main line from the wing tank. The other line is the vent. The vent line is connected to each side of the two high spots of the panel tank and a T in this line runs to the top of the wing tank. You can see the vent line and fitting in the top of the wing tank in the site gauge picture.
One advantage of a rear header tank is it makes for a good down hill slope all the way from the wing tank. In the pictures you can see the slope in the lines above the door is just about level with the panel tank routing. To get all the fuel in the wing tank to drain I must fly with that wing high for a little while.
Service Bulletin #29 http://www.kitfoxaircraft.com/support/service_bulletins/sb29.htm
 Filesize:  78.6 KB
 Viewed:  5775 Time(s)
 Filesize:  54.17 KB
 Filesize:  47.02 KB
 Filesize:  47.83 KB
Tom Jones
Classic IV
Ellensburg, WA
