rflick(at)ovalinternet.ne Guest
Posted: Fri Dec 10, 2010 6:39 am Post subject: weight amd balance |
hello anyone useing header tank in 601 hds with corvair engine? i have wing tanks and also a header tank but wonder if the corvair eng and header tank will make it hard to get wt and bal without adding wt or something. any comments appreciated. thanks ralph
Wingrider
Joined: 22 Nov 2006 Posts: 34 Location: Tullahoma, TN
Posted: Fri Dec 10, 2010 5:32 pm Post subject: Re: weight amd balance |
I have an HDS with the Zenith 10 gal wing tanks an 8 gal header tank and Corvair engine. No problem staying within the CG envelope. The forward CG is slightly below the minimum when calculated with a 170# pilot but I don't weigh 170. My battery is mounted on the firewall but at some point I will probably move it behind the passenger seat which will improve the W&B.
I read where someone stated the HDS glides like a well thrown man hole cover and after 20 hours phase 1 time I have to agree.
_________________ Rich Whittington
Tullahoma, TN
Zenith 601HDS
Corvair 3 Liter 120HP |
don.honabach(at)pcperfect Guest
Wingrider
Posted: Sun Dec 12, 2010 1:14 pm Post subject: Re: weight amd balance |
If you really want to bleed off some altitude come down at VNE, I've done 170 mph a couple of times.
Tullahoma, TN
Zenith 601HDS
