Water temp sensor ground
paul.r.kuntz(at)gmail.com
PostPosted: Tue Dec 07, 2010 9:05 pm    Post subject: Water temp sensor ground Reply with quote
This photo shows a water temperature sensor in the coolant manifold riser on my Rotax 912 installation.  It's the brass-colored fitting screwed into the end of the short horizontal tube in the middle of the photo.  The sensor needs a ground, but the coolant manifold is connected by rubber hoses to the engine, so it's not presently grounded.  I would prefer to ground the sensor with a tabbed copper washer under the sensor itself, to which I could attach a ground wire, but I don't know a source.  I suppose I could fabricate one myself, but I'd rather buy one if they are available.  Alternatively, I could screw a hose clamp around the manifold and ground the clamp.  Any recommendations?
Paul Kuntz
http://www.pipistrelbuilders.com
PostPosted: Wed Dec 08, 2010 4:02 am    Post subject: Re: Water temp sensor ground Reply with quote
How about using a ring terminal? What inside diameter is required?
Maybe you could find one at an auto parts store. The electronic supply houses usually sell them in boxes of 10 or more.
Code:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=320758-ND
Ask around, someone might have one of the size needed.
Joe
Joe Gores
n8zg(at)att.net
PostPosted: Wed Dec 08, 2010 6:07 am    Post subject: Water temp sensor ground Reply with quote
Paul –
If the brass fitting had NPT threads, trying to clamp a tabbed washer between the fitting and the manifold is probably not a good idea. Clamping force is required to maintain electrical contact/continuity with the washer, fitting & sensor. NPT threads depend on taper & interference fit to seal. Finding the perfect thickness of washer to fill the gap between the manifold boss and the adapter shoulder while maintaining the correct fit of the NPT threads without over- or under-torquing might be challenging.
If it were my airplane, I think I’d drill thru one of the corners of the brass fitting (emulating a safety wire hole) and solder a wire in the hole for the ground. Example photos:
http://www.wicksaircraft.com/catalog/product_cat.php/subid=10147/index.html
http://www.gen-aircraft-hardware.com/images/pdf/nuts_corner_drilled.pdf
neal
Paul Kuntz
PostPosted: Wed Dec 08, 2010 6:37 am    Post subject: Water temp sensor ground Reply with quote
Neal,
That's not a bad idea, although this particular fitting has straight
threads, not tapered pipe threads. One problem I see with the soldered
ground wire is the possibility of wire fatigue at the solder joint.
Paul
On Wed, Dec 8, 2010 at 6:04 AM, Neal George <n8zg(at)att.net> wrote:
[quote] Paul –
pwmac(at)sisna.com
PostPosted: Wed Dec 08, 2010 6:59 am    Post subject: Water temp sensor ground Reply with quote
Dont know what brand you are installing, but most gauges come with optional two senders. One like yours and on with the required ground tab. Check the source for that option. Lots more samitary than a workaround with onbly one tab.
PaulW
At 08:56 PM 12/7/2010, you wrote:
[quote] This photo shows a water temperature sensor in the coolant manifold riser on my Rotax 912 installation. It's the brass-colored fitting screwed into the end of the short horizontal tube in the middle of the photo. The sensor needs a ground, but the coolant manifold is connected by rubber hoses to the engine, so it's not presently grounded. I would prefer to ground the sensor with a tabbed copper washer under the sensor itself, to which I could attach a ground wire, but I don't know a source. I suppose I could fabricate one myself, but I'd rather buy one if they are available. Alternatively, I could screw a hose clamp around the manifold and ground the clamp. Any recommendations?
Paul Kuntz
jon(at)finleyweb.net
Hi Paul,
The best option is to replace the sensor with one that has a ground connector (obviously). However; I have run into this same situation a number of times and have never come up with a really good solution (so am listening closely to the responses). The best I have come up is a hose clamp around the sensor with a ground wire underneith it (as you mentioned). The only trick to this seems to be adequately securing the wire against vibration or else it will break (at the hose clamp) over time. Of course (just to spite me I think), the most recent sensor I added was a large hexagon shape which made the hose clamp solution really crude.
Jon Finley
N314JF - Q2 - Subaru EJ-22
http://www.finleyweb.net/Q2Subaru.aspx
n8zg(at)att.net
PostPosted: Wed Dec 08, 2010 7:03 am    Post subject: Water temp sensor ground Reply with quote
The soldered joint presents a manageable risk.
Two easy options:
1- After soldering the joint, wrap the wire around the sensor once and secure with heat shrink or self-fusing silicone tape.
2 – Manipulate the wire to make it lay along the axis of the sensor before soldering. After soldering, bind the wire to the sensor body with heat shrink or self-fusing silicone tape after soldering.
There are many variations on exactly how to route, lay and affix the leads, depending on whether you plan to use individual wires for signal and ground, or some sort of paired conductor (shielded or twisted pair – for convenience, not noise rejection).
neal
Neal,
That's not a bad idea, although this particular fitting has straight threads, not tapered pipe threads. One problem I see with the soldered ground wire is the possibility of wire fatigue at the solder joint.
Paul
bbradburry(at)bellsouth.n
PostPosted: Wed Dec 08, 2010 12:34 pm    Post subject: Water temp sensor ground Reply with quote
The best solution is the ground tab as suggested below. Barring that, check for good continuity between the sensor body and the pipe it is screwed into. If it is making good contact, place a hose clamp around the pipe and attach a ground wire to the clamp.
Bill B
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jon Finley
Sent: Wednesday, December 08, 2010 9:56 AM
Subject: Re: AeroElectric-List: Water temp sensor ground
Hi Paul,
Jon Finley
PostPosted: Wed Dec 08, 2010 12:43 pm    Post subject: Water temp sensor ground Reply with quote
Good input, Neal.  Thanks.
Paul
On Wed, Dec 8, 2010 at 7:00 AM, Neal George <n8zg(at)att.net (n8zg(at)att.net)> wrote:
Two easy options:
neal
Neal,
Paul
"_blank">www.aeroelectric.com
.com/" target="_blank">www.buildersbooks.com
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
ttp://forums.matronics.com
Float Flyr
PostPosted: Wed Dec 08, 2010 5:09 pm    Post subject: Water temp sensor ground Reply with quote
Sure they’re called ring connectors. You will find they are usually copper plated with some metal silver colourted
Noel
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of paul wilson
Sent: December 8, 2010 11:26 AM
Subject: Re: Water temp sensor ground
PaulW
Paul Kuntz
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Wed Dec 08, 2010 5:31 pm    Post subject: Water temp sensor ground Reply with quote
Is there enough "meat" in the brass hex section
to drill and tap a 4-40 hole? If so, consider
a tapped hole and PIDG terminal to attach ground
wire.
Bob . . . [quote][b]
Float Flyr
PostPosted: Thu Dec 09, 2010 5:41 am    Post subject: Water temp sensor ground Reply with quote
You may also use a clamp to attach a ground braid to the pipe itself and then attach the other end of the braid to a suitable ground.  If you want a little cleaner job silver solder either a tang or a nut to the pipe and use that to attach the braid.
Noel
Hi Paul,
Jon Finley
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Thu Dec 09, 2010 6:06 am    Post subject: Water temp sensor ground Reply with quote
Soldering is not a good idea especially in areas of high vibration like the engine. Solder wicks up into wire and cause a point where all the vibration bending is concentrated on one small point. This can cause the wire to break at that point. Better to use a crimp fitting or just attach the ground to the pipe with a clamp.
Noel
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Paul Kuntz
Sent: December 8, 2010 5:11 PM
Paul
Two easy options:
neal
Neal,
Paul
.com/" target="_blank">www.buildersbooks.com="_blank">www.homebuilthelp.com_blank">http://www.matronics.com/contributionist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-Listttp://forums.matronics.com
5
6
7
8
9
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
n8zg(at)att.net
PostPosted: Thu Dec 09, 2010 8:25 am    Post subject: Water temp sensor ground Reply with quote
Very true, Noel –
Thus the admonition to immobilize the joint and a short length of the associated lead.
neal
Noel
Paul
Two easy options:
neal
