Slow day --- and cracks in the horizontal.
GrummanDude
PostPosted: Mon May 01, 2006 10:05 pm    Post subject: Slow day --- and cracks in the horizontal. Reply with quote
In a message dated 5/1/06 9:39:05 PM, gilalex(at)earthlink.net writes:
Is it standard practice to add red RTV to seal the upper and lower edges of
the oil cooler at the baffle?
I always use the Black RTV 732. It looks a lot better than the orange
stuff.
I've seen as much as a 30 degree drop when the cylinder baffle strap is cut
back on cyls #3 and #4. The larger exit ramps help also.
OK, I'm doing an annual on a plane that has cracks in the vertical supports
and the horizontal stiffener on the horizontal. Gil, I think this one is
cracked like yours. Do you know if your plane ever had damage to the horizontal?
This one has had the leading edge of the horizonatl replaced.
I've hired a DER to help engineer a better fix than just replacing the same
parts. If it works, I'm going to do an STC for it.
There . . . . . is that a good story?
or, how about
a McCauley prop for a Cheetah that has been cut down to 72 inches and pitched
to 63? New LyCon O320, ported and polished, turns 2850 at 7500 feet.
Trues at 134 knots at 7500 feet at 2700 rpm.
or, how about
I averaged 147 knots flying to Lancaster in my Tiger.
or, how about
I'm doing an STC for my larger cooling exit ramps.
or, how about
have you seen the one piece instrument panel I did for a Tiger about 6 years
ago? Well, I'm going to do another one. This one will be simialr but
'better' in my opinion.
or, how about
I've eliminated all of the interior plastic except for the canopy window
trim, the rear window trim and the forward console covers. That includes the
center plastic piece on the canopy and the top console cover in the front. The
top console cover is made of Carbon fiber with a cup holder!
Gary
Gary
AuCountry Aviation
Home of Team Grumman
rdp123(at)verizon.net
PostPosted: Mon May 01, 2006 10:19 pm    Post subject: Slow day --- and cracks in the horizontal. Reply with quote
Thanks Gary, now I am not bored anymore although I'm watching Jon Stewart
and he is tough competition even for stabilizer cracks.
Rick
res02p3h(at)verizon.net
PostPosted: Tue May 02, 2006 2:34 am    Post subject: Slow day --- and cracks in the horizontal. Reply with quote
Works for me!
Bruce
> edges of
orange
stuff.
strap is cut
supports
one is
the horizontal?
the same
or, how about
and pitched
or, how about
or, how about
or, how about
about 6 years
simialr but
or, how about
window
includes the
front. The
Gary
