fwf/engine hanging procedures
Goto page 1, 2  Next
rvdave
PostPosted: Thu Dec 02, 2010 6:04 pm    Post subject: fwf/engine hanging procedures Reply with quote
Am getting close to hanging engine to start trimming cowling, I don't yet have the fwf kit or anything yet. Should I be planning to be removing engine again and again while working on things between engine mount and firewall or can I plan on one time permanent mount?
Dave Ford
Cadillac, MI
dmaib(at)mac.com
PostPosted: Thu Dec 02, 2010 6:47 pm    Post subject: fwf/engine hanging procedures Reply with quote
Dave,
I imagine you will have it back off at least once and maybe more.
David Maib
40559
Flying
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=322125#322125
jesse(at)saintaviation.co
PostPosted: Thu Dec 02, 2010 8:15 pm    Post subject: fwf/engine hanging procedures Reply with quote
If you don't have the fwf kit yet you'll want to pull it off again. Lots of stuff gets mounted on the fw that is easier w/o the engine on.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
rvdave
PostPosted: Thu Dec 02, 2010 8:39 pm    Post subject: Re: fwf/engine hanging procedures Reply with quote
My thoughts are to first get isolators and bolts/nuts, hang engine to line up & mark where penetrations must be made through firewall, complete baffling & cowl fitting, take it off once for room to work, then if I haven't forgotten anything, one last mounting. Can it be that simple? Laughing
Dave Ford
Cadillac, MI
Strasnuts
PostPosted: Thu Dec 02, 2010 10:11 pm    Post subject: Re: fwf/engine hanging procedures Reply with quote
I hung my engine right away. I believe some items might be easier done without the engine but I had no problems doing everything later. Sometimes it's just easier to get some items done and go on. Maybe it is mental but mounting the engine was a motivator for me. That goes for the subpanel too. There comes a time when you just have to do it and move on and you get things done.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
rv10rob(at)gmail.com
PostPosted: Thu Dec 02, 2010 11:49 pm    Post subject: fwf/engine hanging procedures Reply with quote
I mounted mine only once.  If you have a pretty standard setup, mount stuff and put the firewall penetrations where Van's tells you to, and do the things Van's tells you to do before mounting the engine, it works out fine.  I did add a couple extra holes later on the upper part of the firewall, but there's plenty of room to work up there, even with the engine on.
I'd recommend getting the FWF kit now, or at least the few items you need to install before mounting the engine.
-Rob
On Thu, Dec 2, 2010 at 8:12 PM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
--> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Dec 2, 2010, at 9:04 PM, "rvdave" <davidbf(at)centurytel.net (davidbf(at)centurytel.net)> wrote:
--> RV10-List message posted by: "rvdave" <davidbf(at)centurytel.net (davidbf(at)centurytel.net)>
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
&gtnd Get Some AWESOME FREE Gifts!)
/" target="_blank">www.aeroelectric.com
omebuiltHELP www.homebuilthelp.com
http:/r generous support!
nics List Features Navigator to browse
s.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
ronics.com/" target="_blank">http://forums.matronics.com
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
rleffler
PostPosted: Fri Dec 03, 2010 2:36 am    Post subject: fwf/engine hanging procedures Reply with quote
As many have mentioned, I purchased these parts that are indicated on FF1-3 that would be easier to install before the engine mount.
I wanted to get the engine mounted so that I could start working on the cowl. Since I'm on the incur no debt plan, I didn't have the cash for the FWF kit. So to more effectively manage my budget, I just ordered these parts in advance. I'll order the rest of the FWF kit a few months down the road.
 Filesize:  30.54 KB
 Viewed:  13156 Time(s)
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
Mauledriver(at)nc.rr.com
PostPosted: Fri Dec 03, 2010 3:50 am    Post subject: fwf/engine hanging procedures Reply with quote
I mounted & removed mine once (with FWF kit) so I could do the cowl
fitting and for inspiration.
I would suggest not trying to remove or re-install with the prop
attached. The initial mounting was a surprisingly easy 1 person
operation. However, with the prop on it, I just couldn't coax it back
onto the mounting. It seemed like it shouldn't matter but once I
decided to remove the prop (multi-person op 3 weeks later), the engine
slipped on in 15 min.
PostPosted: Fri Dec 03, 2010 5:38 am    Post subject: fwf/engine hanging procedures Reply with quote
With that stuff mounted you should be fine with a final mount of the engine. Do you have the control cables? Make sure you have the holes enlarged and then you should be good to route them with the engine on. All of those parts listed are the parts that can be installed after the engine is on, but are much easier installed before the engine.
Jesse Saint
Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Dec 3, 2010, at 5:30 AM, Bob Leffler wrote:
[quote]As many have mentioned, I purchased these parts that are indicated on FF1-3 that would be easier to install before the engine mount.
<image001.jpg>
Tim Olson
PostPosted: Fri Dec 03, 2010 7:21 am    Post subject: fwf/engine hanging procedures Reply with quote
I mounted mine only once too. It wasn't a big deal. As long as the
oil filter isn't sticking out the back you can work on those cable
holes and such. Anything you can do on the firewall before
the engine will be easier, but if you just follow plans order
you'll get by fine.
Tim Olson - RV-10 N104CD
engine on.
-Rob
<mailto:jesse(at)saintaviation.com>> wrote:
<jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>>
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org <mailto:jesse(at)itecusa.org>
www.itecusa.org <http://www.itecusa.org/>
www.mavericklsa.com <http://www.mavericklsa.com/>
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
> Dave Ford
> RV6 flying
> RV10 building
> Cadillac, MI
omebuiltHELP www.homebuilthelp.com <http://www.homebuilthelp.com/>
<http://www.matronics.com/contribution>
Rob Kochman
rvdave
PostPosted: Sat Dec 04, 2010 8:44 am    Post subject: Re: fwf/engine hanging procedures Reply with quote
I've been going over the fwf list that Bob L. had in the archives, it showed 3 black cables, 2 for heat, what is the other one for?
3.00 CT A-740 BLACK PUSH PULL CABLE BLACK
Dave Ford
Cadillac, MI
dlm46007(at)cox.net
PostPosted: Sat Dec 04, 2010 8:55 am    Post subject: fwf/engine hanging procedures Reply with quote
alt air door for air box
dlm46007(at)cox.net
If you are installing a parking brake you will need to buy an extra.
Lew Gallagher
PostPosted: Sat Dec 04, 2010 8:56 am    Post subject: fwf/engine hanging procedures Reply with quote
Hey Dave,
We used that one for the bypass door on the air filter.
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
PostPosted: Sat Dec 04, 2010 9:05 am    Post subject: fwf/engine hanging procedures Reply with quote
Alternate air flap for air intake assembly?
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
Jim Combs
PostPosted: Sat Dec 04, 2010 9:16 am    Post subject: fwf/engine hanging procedures Reply with quote
alternate air
On Sat, Dec 4, 2010 at 11:44 AM, rvdave <davidbf(at)centurytel.net (davidbf(at)centurytel.net)> wrote:
[quote] --> RV10-List message posted by: "rvdave" <davidbf(at)centurytel.net (davidbf(at)centurytel.net)>
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=322263#322263
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
RV-10 -> N312F - Flying as of 12/2008
Robin(at)PaintTheWeb.com
PostPosted: Sat Dec 04, 2010 9:36 am    Post subject: fwf/engine hanging procedures Reply with quote
If you have an Airflow Performance Throttle body (FM200 / FM300) you will also need one for the Purge valve.
I chose Red for the heat and black for the Purge & Parking Brake.
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Jim Combs
Sent: Saturday, December 04, 2010 9:13 AM
Subject: Re: Re: fwf/engine hanging procedures
alternate air
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
le, List Admin.
         (And Get Some AWESOME FREE Gifts!)[/b][/quote] e Contribution link below to find out more about[/b][/quote] ee Incentive Gifts provided[/b][/quote] f="http://www.aeroelectric.com">www.aeroelectric.com[/b][/quote]ookstore www.buildersbooks.com[/b][/quote] ef="http://www.homebuilthelp.com">www.homebuilthelp.com[/b][/quote] ontribution">http://www.matronics.com/contribution[/b][/quote][/b][/quote] =================[/b][/b][/quote] = the many List utilities such as List Un/Subscription,[/b][/quote][/b][/quote] matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] =================[/b][/b][/quote] http://forums.matronics.com[/b][/quote] =================[/b][/quote]
Checked by AVG - www.avg.com
Version: 10.0.117
rvdave
PostPosted: Sat Dec 04, 2010 9:45 am    Post subject: Re: fwf/engine hanging procedures Reply with quote
ok thanks, I assume FAB kit comes with alternate air hardware?
Dave Ford
Cadillac, MI
PostPosted: Mon Dec 06, 2010 10:03 am    Post subject: fwf/engine hanging procedures Reply with quote
FWIW, my FAB kit came with a black cable, too, so I ended up with an extra.
On Sat, Dec 4, 2010 at 8:44 AM, rvdave <davidbf(at)centurytel.net (davidbf(at)centurytel.net)> wrote:
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
ber is the Annual List Fund Raiser.  Click on
Rob Kochman
indigoonlatigo(at)msn.com
PostPosted: Mon Dec 06, 2010 10:42 am    Post subject: fwf/engine hanging procedures Reply with quote
You have two cable for cabin heat.
One cable for the emergency FAB bypass door on the bottom of the airfilter box.
One cable for the Carberator heat which cuts off the air from the cowl scoop intake and allows hot air into the filter box via the cowl air inside the engine compartment.
I needed to purchase one more cable for the oil cooler butterfly valve.
The subpanel looks pretty goofy with five black handles sticking out of it along with the Mixture, prop and throttle.
Maybe someone will put the control for these on their control stick switches(just kidding!)
Date: Mon, 6 Dec 2010 09:59:26 -0800
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
Rob Kochman
_blank>www.aeroelectric.com
/" target=_blank>www.buildersbooks.com
=_blank>www.homebuilthelp.com
=_blank>http://www.matronics.com/contribution
arget=_blank>http://www.matronics.com/Navigator?RV10-List
Goto page 1, 2  Next
Page 1 of 2
