Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Thu Dec 02, 2010 6:34 am Post subject: infinity grips |
I would like to see what people are using for all the buttons on the infinity grips. I'm trying to figure out what I want on these grips:
My list is:
Trigger - PTT
Hat - aileron/elevator trim
Thumb - Autopilot
Thumb - comm flip/flop?
Thumb halfway down the stick - Ident?
Pinky - screen change?
Do these make sense?
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Robin(at)PaintTheWeb.com Guest
Posted: Thu Dec 02, 2010 7:00 am Post subject: infinity grips |
On 3 of my planes I did:
· Trigger - PTT
Thumb - Autopilot
And didn’t bother with the remaining two buttons. My first with infinity grips was a steam gauge aircraft (RV-6A) so fewer things to switch. The next two RV-10 & RV-8A had the above layout but no additional buttons either. I almost added the Comm Swap which is swapping between Comm 1 & Comm 2 (not Flip Flop) but decided against based on how I use the panel. I didn’t want the ident feature b/c I seem to get ident requests less than once a flight and I didn’t want to ident by accident. After years of flying the Infinity stick I don’t think I have ever hit a button by mistake. On the G900X PFD one can get back to the main screen by holding the Clear button for 2 seconds. I guess that would have been a nice function to have on a stick button. Not too dissimilar to your Screen Change.
Good luck,
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Strasnuts
Sent: Thursday, December 02, 2010 6:35 AM
Subject: infinity grips
--> RV10-List message posted by: "Strasnuts" <sean(at)braunandco.com (sean(at)braunandco.com)>
My list is:
Trigger - PTT
Thumb - Autopilot
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p=322051#322051
.aeroelectric.com">www.aeroelectric.com
iption,
//www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
ttp://forums.matronics.com">http://forums.matronics.com
Checked by AVG - www.avg.com
Version: 10.0.1170 / [quote][b]
Posted: Thu Dec 02, 2010 7:08 am Post subject: infinity grips |
It does depend on your hardware / avionics configuration - but yours is similar to mine.
The PTT and Hat switches make sense to me and that's how I'm using them.
The upper thumb (green and red straddling the hat) switches swap my audio between my two radios and cycle through my autopilot modes - just like you're thinking.
The blue one (pinky) is for my altitude hold - engage / disengage.
The lower thumb (black) engages my starter (after first enabling a guarded safety switch). The black one is set up that way because my key is located below the throttle quadrant for use by either front seat occupant - this allows one hand on the throttle and the other to continue flying the plane while attempting a restart (admittedly - I have not used this and would rather not need to).
This setup has worked great for me for the last two years.
Ralph Capen
RV6A N822AR (at) N06 - itchin' to build again...looking two-digit RV's
sean(at)stephensville.com Guest
Posted: Thu Dec 02, 2010 7:26 am Post subject: infinity grips |
Btn 1 (Hat) - Pitch/Roll Trim
Btn 2 (Trigger) - PTT
Btn 3 (Red Thumb) - AP CWS
Btn 4 (Black Thumb) - VP-200 ACK
Btn 5 (Blue Pinky) - <undecided>
Btn 6 (Green Thumb) - Flaps * changing to toggle switch (ON)/OFF/(ON)
-Sean #40303
On 12/2/10 8:56 AM, Robin Marks wrote:
·Trigger - PTT
Thumb - Autopilot
Good luck,
Robin
<mailto:owner-rv10-list-server(at)matronics.com>
<mailto:owner-rv10-list-server(at)matronics.com>] *On Behalf Of *Strasnuts
*Sent:* Thursday, December 02, 2010 6:35 AM
*To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
*Subject:* infinity grips
<mailto:sean(at)braunandco.com>>
My list is:
Trigger - PTT
Thumb - Autopilot
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
iption,
Checked by AVG - www.avg.com <http://www.avg.com>
Posted: Thu Dec 02, 2010 7:36 am Post subject: infinity grips |
I've always done it this way. If you don't have yaw trim, then that frees up a button from this list for flip/flop. You could put in a momentary toggle to give you two buttons in one, so left on what I use as a yaw trim button could be flip/flop and right could be screen change. I really like having flaps on the stick. I wouldn't do it any other way personally.
Trigger - PTT
Hat - Pitch/Roll Trim
Top Inboard Thumb - Flaps
Top Outboard Thumb - Yaw Trim
Side Thumb - Auto Pilot
Pinky - Acknowledge, flip flop, screen change, etc. (momentary button better than push-on/push-off)
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Dec 2, 2010, at 9:34 AM, Strasnuts wrote:
My list is:
Trigger - PTT
Thumb - Autopilot
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
johngoodman
Posted: Thu Dec 02, 2010 7:43 am Post subject: Re: infinity grips |
I used the blue pinky button for Ident.
Green thumb for A/P disc.
Black thumb for Comm swap
Red is empty for now.
Posted: Thu Dec 02, 2010 7:45 am Post subject: infinity grips |
Sean,
May I recommend a toggle ON/OFF/(ON) for the flaps? It's nice to be able to feel that button up and know that the flaps are retracted.
Jesse Saint
C: 352-427-0285
F: 815-377-3694
On Dec 2, 2010, at 10:20 AM, Sean Stephens wrote:
-Sean #40303
> ·Trigger - PTT
> Thumb - Autopilot
> Good luck,
> Robin
> *From:*owner-rv10-list-server(at)matronics.com <mailto:owner-rv10-list-server(at)matronics.com> [mailto:owner-rv10-list-server(at)matronics.com <mailto:owner-rv10-list-server(at)matronics.com>] *On Behalf Of *Strasnuts
> My list is:
> Trigger - PTT
> Thumb - Autopilot
> Cust. #40936
> RV-10 SB Fuselage
> N801VR reserved
> iption,
> No virus found in this message.
rene(at)felker.com Guest
Posted: Thu Dec 02, 2010 7:53 am Post subject: infinity grips |
Trigger - PTT
Top Outboard Thumb - Autopilot
Side Thumb - Frequency Flip Flop, Comm 1 (Love this one)
Pinky - Ident (Not used very often.....thinking of chancing to COMM1/COMM2
flip flop.)
Rene' Felker
N423CF
801-721-6080
Posted: Thu Dec 02, 2010 8:09 am Post subject: infinity grips |
Good point. Looks like the VP-200 can be configured that way also.
Also noticed you put flaps on the inboard side of the stick as opposed
to how I have the AP CWS there. I think that makes better sense as to
further avoid possible unintended use of the CWS btn. And it is easier
to get at there.
Config changes to the following:
Btn 3 (Red Thumb) - Flaps * changing to toggle switch ON/OFF/(ON)
Btn 5 (Blue Pinky) -<undecided> Ident or COM1 freq flip flop
Btn 6 (Green Thumb) - AP CWS * would probably switch btn color to Red
-Sean #40303
On 12/2/10 9:42 AM, Jesse Saint wrote:
Sean,
Jesse Saint
C: 352-427-0285
F: 815-377-3694
> -Sean #40303
lessdragprod(at)aol.com Guest
Posted: Thu Dec 02, 2010 8:25 am Post subject: infinity grips |
Hi All,
It looks like there is a combination of similarities and differences in switch functions.
My list is:
Trigger - PTT
Thumb (right of hat) - Starter (with panel switch in series)
Thumb (left of hat) - Flap (toggle switch on/off/momentary on)
Thumb (halfway down the stick) - #1 radio flip/flop
Pinky - Autopilot engage/disengage
The front stick on my Less Drag Special (modified HR2) is hard wired with the 17(?) wires.
The rear stick only has the 4 wires required for the Cann Aerospace Buss card. The rear stick will not be wired into the system until I install the Cann Buss modules. The rear stick will have a enable/disable switch on the instrument panel. (future development)
The left stick on my RV-6A has a Ray Allen stick grip using the Trigger switch for PTT and the hat for elevator and aileron trim.
The right stick has the four wires connecting all of the Infinity stick grip switches to a Cann Aerospace Buss module. As we complete adding in the Cann Aerospace Buss modules, I will finish designating the switch functions. (For flight safety, there will be an enable/disable switch on the pilot side of the instrument panel for the passenger stick grip switches.)
With the Cann Aerospace Buss modules and the Infinity stick grip modification, the function of each stick grip switch can be designated and/or changed without rewiring the stick grip.
Jim Ayers
Tim Olson
Posted: Thu Dec 02, 2010 8:26 am Post subject: infinity grips |
Trigger - PTT
Thumb (DPST Momentary) - COM1 / COM2 flip-flop
(works good to flip active to standby on either COM)
Thumb - EFIS Screen mode (cycles PFD/MFD/Engine page)
Thumb halfway down the stick - AP Disconnect
Pinky - EFIS Mute
If your system supports it, I'd definitely do an audio mute
for terrain/traffic/engine warnings on your stick. Also,
of course 100% should have AP disconnect. I use the
com flip flop a lot. Basically I love my stick button layout,
but if you don't have an EFIS mode change button, you'll
have one button to assign to something else.
Some people put flaps, starter, ident, and other things on
the switch...personally I find no use for those to be
that handy or used that often...and some things done
wrong could be downright dangerous.
Tim Olson - RV-10 N104CD
On 12/2/2010 8:34 AM, Strasnuts wrote:
My list is:
Trigger - PTT
Thumb - Autopilot
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
Strasnuts
Posted: Thu Dec 02, 2010 8:58 am Post subject: Re: infinity grips |
These are great ideas.
I would like to mute terrain on VFR flights and maybe have a TCAS inhibit on the stick. I could run my terrain audio to the AUX in on the audio panel and turn it on before IFR flights.
780 Hours
dmaib@me.com
Posted: Thu Dec 02, 2010 3:38 pm Post subject: infinity grips |
Trigger-PTT
Hat_ elevator/aileron trim
Thumb-comm flip flop
Thumb-VP200 acknowledge/checklist advance. (in my opinion this is a must have if you have VP)
Halfway down stick_ Autopilot disconnect/CWS
Pinky-rudder trim
If I had it to do over, I would consider putting a start button on the pinky instead of rudder trim. It would be nice to be able to hold the stick while activating the starter and manipulating the throttle with the right hand. VP will keep you from engaging the starter at a time when you don't want to.
$.02 worth
David Maib
40559
Flying.
My list is:
Trigger - PTT
Thumb - Autopilot
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Strasnuts
Posted: Sat Dec 18, 2010 7:02 am Post subject: Re: infinity grips |
When ordering my infinity from Aircraft Spruce I ran into, "AC with flap/brake or AC without flap/brake." What does that mean? I know the RV-10 doesn't have one but what am I changing in the switch configuration? Infinity Grip's web sight is so convoluted and scattered I would rather use Aircraft Spruce.
780 Hours
Posted: Sat Dec 18, 2010 8:29 am Post subject: infinity grips |
The infinity Grip site is a confusing mess. Calling Infinity when I ordered my grips for the RV-4, RV-6A RV-10 and most recently my 8A was the exact same song & grumbling dance. "Did you see the order form on the website" "Yes but it was confusing and I didn’t want to make a mistake in ordering." That is how everyone of my conversations went with JD but in each case we went through the choices & options and the ordering took about 20 minutes to get exactly what I needed. Just understand what switch, button, toggle you want including type of switch (momentary, push on/off) and of course what hand orientation your grips should be. Don’t forget the button switches are available in different colors so decide ahead of time your AP disconnect color vs. your Flip/Flop button color. Know ahead of time the amount of wiring length you want because he sells the bundled wire by the foot. Once you have completed the grip transaction be ready for the hard sell on his engine pre-oiler and a few other items. I thanked him for the suggestions but passed on those items. I think this the best & most accurate way to order these grips. In the end I get what I need and have discussed the choices with the most knowledgeable if occasionally a touch gruff developer of the product.
"Best time to call is after 1400 CA California time, and evenings, at (619) 448-5103 ."
A note on the wiring. His bundle of wiring in the blue sleeve has a LOT of wires in it. I think each wire has an associated ground wire. This bundle is difficult to fish through the control stick. Don’t flake out and run the wires external to the stick. I suggest you eliminate most of the ground wires that you don't need and fish the balance of the wires through the stick. I call my set up "hillbilly wiring" but it works well and is much cleaner than an external wiring job. BTW I am not saying it is impossible to run the entire bundle through the stick, just very difficult. We finally learned on the 8A the best technique.
126.33 KB |
15236 Time(s) |
Strasnuts
Posted: Sat Dec 18, 2010 8:46 am Post subject: infinity grips |
Thx Robin, That helps a lot!
On Dec 18, 2010, at 9:25, Robin Marks <Robin(at)PaintTheWeb.com (Robin(at)PaintTheWeb.com)> wrote:
<image002.jpg>
780 Hours
Posted: Sat Dec 18, 2010 10:48 am Post subject: infinity grips |
I'm guessing here, but on the Aircraft Spruce site, I am assuming that
with or without flaps is referring to either a toggle switch or a button
in the one position beside the coolie hat.
I agree on Infinity's website. If there was another vendor that offered
just one more button than the Ray Allen G307, I'd have gone to them in
the blink of an eye. It's brutal trying to get around that site.
If anyone knows of an ambidextrous grip with just one stinkin' more
button than the Ray Allen G307 has. I'm wondering if there would be any
way for me to add another button to the G307?
-Sean #40303
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
Posted: Sat Dec 18, 2010 11:52 am Post subject: infinity grips |
Does the Tosten come up short? It's what I've installed.
http://www.tostenmanufacturing.com/catalog/aircraft-grips/cs-8-aircraft-grip.html
Bill "waiting for painting temps" Watson
On 12/18/2010 1:44 PM, Sean Stephens wrote:
button in the one position beside the coolie hat.
offered just one more button than the Ray Allen G307, I'd have gone to
them in the blink of an eye. It's brutal trying to get around that site.
any way for me to add another button to the G307?
-Sean #40303
Tim Olson
Posted: Sat Dec 18, 2010 12:06 pm Post subject: infinity grips |
Actually, I would recommend ordering direct. You could
call them and they'll help you figure out what you need
based on what you want. I wouldn't order that part
3rd party. I remember going through that order sheet
myself.
On 12/18/2010 9:02 AM, Strasnuts wrote:
-------- Cust. #40936 RV-10 SB Fuselage N801VR reserved
http://forums.matronics.com/viewtopic.php?p=323750#323750
Tim Olson
Posted: Sat Dec 18, 2010 12:10 pm Post subject: infinity grips |
I left all wires as-in, in the blue sheath, and was able to run
the blue sheath through the stick so that it exits the stick
under the seats. I think it's nice having that thick chafe
protection on the wires.
On 12/18/2010 10:25 AM, Robin Marks wrote:
[quote] The infinity Grip site is a confusing mess. Calling Infinity when I
the website" "_Yes but it was confusing and I didn’t want to make a
mistake in ordering_." That is how everyone of my conversations went
(619) 448-5103 ."
