Winter oil?
tdawson-townsend(at)auror
PostPosted: Tue Nov 30, 2010 10:28 am    Post subject: Winter oil? Reply with quote
After finishing my test period, I’ve actually still got SAE 50 mineral oil in the plane, which is obviously more of a summer weight than winter (Massachusetts).
What are thoughts about leaving the SAE 50 in until the next oil change? I was thinking that the crucial part for oil temperature and viscosity is at start up, so as long as I am diligent about getting some pre-heat before starting, the SAE 50 might be okay for the short term. (airplane is always hangared, too)
TDT
Tim Dawson-Townsend
RV-10 N52KS (http://aprs.fi/?call=n52ks)
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
 Filesize:  57.07 KB
 Viewed:  3980 Time(s)
jcumins(at)jcis.net
PostPosted: Tue Nov 30, 2010 10:45 am    Post subject: Winter oil? Reply with quote
In Mass I would recommend you change and go to Mineral oil at 40 weight no need to go to 30 weight it is not cold enough there.
We ran 40 weight in all our planes at the fbo I worked at In anchorage Ak. Every winter and the average temp there was +5 f and only a week or 2 colder then that.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94534
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy
Sent: Tuesday, November 30, 2010 10:24 AM
Subject: Winter oil?
TDT
Tim Dawson-Townsend
 Filesize:  1.55 KB
 Viewed:  3979 Time(s)
 Filesize:  57.07 KB
tsts4
PostPosted: Tue Nov 30, 2010 11:06 am    Post subject: Re: Winter oil? Reply with quote
As a data point -- over on the red board, the guy who makes CamGuard states he runs 20W50 Fall/Winter/Spring and W100 in the Summer. He's based in NJ.
Here's the link to the thread (note: it's really about CamGuard but oil gets discussed as well) in case you're curious:
http://forums.aopa.org/showthread.php?t=69147
Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying
amekler
PostPosted: Tue Nov 30, 2010 11:07 am    Post subject: Winter oil? Reply with quote
Tim,
I changed to multigrade after 40 hrs.
Alan
Sent from my iPod
On Nov 30, 2010, at 1:23 PM, "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero (tdawson-townsend(at)aurora.aero)> wrote:
TDT
Tim Dawson-Townsend
[url=mailto:tdt(at)aurora.aero]tdt(at)aurora.aero (tdt(at)aurora.aero)[/url]
<image001.png>
Kellym
PostPosted: Tue Nov 30, 2010 1:00 pm    Post subject: Winter oil? Reply with quote
Better yet, go to Phillips 20W50, either type M if you feel mineral is
important, or regular X/C since you have more than 25 hours on the
engine. I didn't like grade 80/40W oil when flying in Fairbanks, Alaska,
too thin when ever it warmed up. When multigrade became available, it
solved that problem. Add some CamGuard for corrosion protection if you
aren't going to fly at least 10 hr/month.
On 11/30/2010 11:39 AM, John Cumins wrote:
John G. Cumins
President
ISlogoLAsmall
2499 B1 Martin Rd
Fairfield Ca 94534
707-425-7100
707-425-7576 Fax
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
*Dawson-Townsend,Timothy
*Sent:* Tuesday, November 30, 2010 10:24 AM
*To:* rv10-list(at)matronics.com
*Subject:* Winter oil?
TDT
Tim Dawson-Townsend
tdt(at)aurora.aero <mailto:tdt(at)aurora.aero>
smaller flight
Kelly McMullen
KCHD
n801bh(at)netzero.com
PostPosted: Tue Nov 30, 2010 2:41 pm    Post subject: Winter oil? Reply with quote
If you have electricity in the hangar I would leave the oil in till the next change. Put one of these on the bottom of the sump. http://www.archeat.com/#
Ps. buy the one that's thermostatically controlled.
Thick oil is your friend if you warm the motor up correctly.
Ben.
Ben Haas
N801BH
www.haaspowerair.com
____________________________________________________________
$350,000 Life Insurance
Coverage as low as $13.04/month. Free, No Obligation Quotes.
QuoteWhiz.com [quote][b]
