Radio noise
madriver42(at)gmail.com
PostPosted: Mon Nov 29, 2010 8:51 am    Post subject: Radio noise Reply with quote
I know this has been discussed before but like to ask anyway.  I installed an old RST 360 com radio in my 701 panel and when I start the "Rotax" it is very noisy. Seems to be a whine don't know whether or not this is alternator or ignition.  Saw a wiring diagram for another radio which stated that you must install a 22,000uf capacitor in series on the 12v feed when used with the Rotax engine installation. Will this cure the problem?  Your valued thoughts please.
Phil Smith
CH 701 - Flying
Buhl, ID
VIXEN
PostPosted: Mon Nov 29, 2010 9:26 am    Post subject: Radio noise Reply with quote
G`morning Phil
I am having a similar problem with my Kitfox Vixen with a 912UL. My radio is a new ICOM A210. I have installed one capacitor on the output from the voltage regulator. This helped but the problem still there but not where I would like it. None of my wiring is shielded and I am wondering if this would help.
I hope this topic is of interest to the group. I look forward to ALL suggestions.
Don Hudgeon
Kitfox Vixen
Summerland,BC
Canada
On Mon, Nov 29, 2010 at 8:47 AM, Philip Smith <madriver42(at)gmail.com (madriver42(at)gmail.com)> wrote:
[quote]I know this has been discussed before but like to ask anyway.  I installed an old RST 360 com radio in my 701 panel and when I start the "Rotax" it is very noisy. Seems to be a whine don't know whether or not this is alternator or ignition.  Saw a wiring diagram for another radio which stated that you must install a 22,000uf capacitor in series on the 12v feed when used with the Rotax engine installation. Will this cure the problem?  Your valued thoughts please.
Phil Smith
CH 701 - Flying
Buhl, ID
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
gpabruce(at)gmail.com
PostPosted: Mon Nov 29, 2010 5:16 pm    Post subject: Radio noise Reply with quote
You might disable the alternator by lifting the field wire and eleminate one or the other. It is most likely ignition noise (high volatage side). Do you have shielded wires?
In series or in parallel?  Series doesn't sound right but then I don't know if you are saying what I think you are saying. Series would not allow any current to flow on a DC circuit hense the radio would not work. Parallel would essentially filter out the unwanted noise sending it to ground.
I should leave my 2 cents out. I don't know, I'm only guessing so don't follow me. It's only a thought.
Bruce
[quote] I know this has been discussed before but like to ask anyway.  I installed an old RST 360 com radio in my 701 panel and when I start the "Rotax" it is very noisy. Seems to be a whine don't know whether or not this is alternator or ignition.  Saw a wiring diagram for another radio which stated that you must install a 22,000uf capacitor in series on the 12v feed when used with the Rotax engine installation. Will this cure the problem?  Your valued thoughts please.
Phil Smith
CH 701 - Flying
Buhl, ID
"_blank">www.aeroelectric.com
.com/" target="_blank">www.buildersbooks.com
ttp://forums.matronics.com
PostPosted: Mon Nov 29, 2010 5:45 pm    Post subject: Radio noise Reply with quote
I need to qualify what I said. There are two potential sources in the radio, (if the radio is the device in question)
  1. Noise on the power lead. This can be filtered out out power input with a parallel capacitor.
  2. Electro Static noise through the antennae caused by high voltage radiation from the high voltage side of the ignition system e.g. coil, high voltage spark plug leads and so on. I just seen some shielded wires and covers for Experimental type engine running regular plugs. I will see if I can find them and include in another post.
I would try to identify and isolate the noise first. You may find you have some noise from both sources. As you isolate the problem you have a better chance of fixing it and testing to see if you fixed it. There may be some other device to blame.
**** First try with the radio with the master on with no engine running to eliminate any non-engine devices. Next easiest: To Isolate the antennae as a source, try grounding it with a alligator clip wire (test lead) to ground. (do not transmit during this test) This should make a noticeable reduction or eliminate completely the radio noise if it's radiation noise from the high voltage ignition. This may be the quickest and easiest method to isolate one source from the other. Simply ground the antennae. Third (not difficult): If you still have noise, disable the alternator next, do you still have the same noise . . . .I hope not . . Let me know how you come out. Once you establish the source(s) of the noise, then it's easier to filter it out with caps and so on.
Hope this helps.
Bruce
On Mon, Nov 29, 2010 at 5:10 PM, b d <gpabruce(at)gmail.com (gpabruce(at)gmail.com)> wrote:
[quote] You might disable the alternator by lifting the field wire and eleminate one or the other. It is most likely ignition noise (high volatage side). Do you have shielded wires?
Bruce
Phil Smith
CH 701 - Flying
Buhl, ID
rjquillin(at)cox.net
PostPosted: Mon Nov 29, 2010 6:07 pm    Post subject: Radio noise Reply with quote
As no one else commented on what seems to be a typo or misunderstanding of terms...
That capacitor would be parallel; that is the positive terminal to your buss, and the negative terminal to airframe or whatever you are using for a "ground".
For a component to be in "series", the load current would flow through the component in series; clearly for DC and a capacitor, this would not work. Were it a coil, inductor, series would be the proper configuration.
Ron Q.
PostPosted: Tue Nov 30, 2010 2:58 am    Post subject: Radio noise Reply with quote
Ron,
I'd say you agree with me, right Ron?  I typically like to leave some wiggle room for interpretation so I phrased my observation as a question as opposed to a fact. Some people explain "parallel and series" circuits differently than you and I do. You and I see and explain them the same the correct way.  I'm not trying to be petty or split hairs because it really doesn't matter, I'm only pointing out that I did address the "parallel and series" issue earlier.  See below.
Best regards, Bruce
On Mon, Nov 29, 2010 at 6:04 PM, Ron Quillin <rjquillin(at)cox.net (rjquillin(at)cox.net)> wrote:
Bruce:
"In series or in parallel?  Series doesn't sound right but then I don't know if you are saying what I think you are saying. Series would not allow any current to flow on a DC circuit hense the radio would not work. Parallel would essentially filter out the unwanted noise sending it to ground."   (previous post)
Ron Q.
PostPosted: Tue Nov 30, 2010 7:53 am    Post subject: Radio noise Reply with quote
Ron correctly replies:
or misunderstanding of terms... That capacitor would
Ron Q.
Some people explain "parallel and series" circuits differently than you . . .
May I suggest that differences in explanation have
more to do with illuminating the speaker's understanding
than it does with debating the value of various
'interpretations'?
I'll refer the debaters to the Z-figures were there
are numerous examples of how the subject capacitor
is wired. I'll also cite every text I've ever
picked up wherein Ohms law, reactance, and measurement
of currents and voltages are explained in uniform and
explicit illustrations for series and parallel connections.
An exemplar figure from the texts I used at Great Lakes
Naval Training Schools:
[img]cid:.0[/img]
This goes to the value of common understanding
of the words used in language. Without common understanding
the useful exchange of
ideas and knowledge cannot take
place.
 Filesize:  70.01 KB
 Viewed:  7202 Time(s)
PostPosted: Tue Nov 30, 2010 10:25 am    Post subject: Radio noise Reply with quote
On Mon, Nov 29, 2010 at 8:47 AM, Philip Smith <madriver42(at)gmail.com> wrote:
At 11:17 AM 11/29/2010, you wrote:
G`morning Phil
Shielding of wires never fixes a "whine".
By whine, I presume you're describing a
sort of musical pitch noise. Further, if
it rises and falls in pitch with engine RPM,
it's almost certainly CONDUCTED noise from
the alternator coming in on the +14V bus
-OR- or is being injected to a signal or
power pathway due to poor grounding practice.
Here's the problem with attempts to remotely
diagnose and/or suggest prophylactic measures.
The combinations of engine, radios, and
intercoms being discussed have been installed
many, many times before with no reported
problems. From this admittedly anecdotal
observation I deduce that something in the
problem-systems is DIFFERENT than for the
historical fleet of similar systems.
The 'street-wise' suggestions for fixing
the symptoms will include a sprinkling of
materials and processes known to have some
beneficial effects on some noise problem on
some system at some point in history. But
as described in the chapter on noise, every
noise problem has a (1) victim (obviously),
(2) a propagation pathway and a (3) source.
Deducing the noise-trinity is a lot like
playing the board game Clue. In the
cases before us now, we know (1) and (3).
The task is to deduce (2). Techniques
for filling in (2)____________ blank
are described in the chapter on noise.
Alternatively, one can ponder a constellation
of hypotheticals with some assurance that
EVENTUALLY the noise can be run to ground
or at least reduced to tolerable levels.
PostPosted: Tue Nov 30, 2010 5:12 pm    Post subject: Radio noise Reply with quote
At 06:51 PM 11/30/2010, you wrote:
Okay, whatever! LOL
Read that wrong. My apologies . . .
Float Flyr
PostPosted: Tue Nov 30, 2010 6:21 pm    Post subject: Radio noise Reply with quote
Bob:
I feel a bit like I must have early onset Alzheimer’s. I should have noticed that the description was to wire the capacitor in series on a DC circuit. As I’m sure you know but others may not, capacitors block DC and pass AC. So if you have a problem with noise on a DC feed simply put a capacitor from that line to ground and any noise (AC) on that line should be shunted to ground assuming the capacitor is of adequate size.
Noel
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: November 30, 2010 12:20 PM
Subject: Re: Radio noise
Ron Q.
'interpretations'?
the useful exchange ofideas and knowledge cannot take   place.
 Filesize:  70.01 KB
 Viewed:  7192 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
ulflyer(at)verizon.net
PostPosted: Thu Dec 02, 2010 1:02 am    Post subject: Radio noise Reply with quote
Whoa - don't think the capacitor you reference should be installed in series, it should be from the regulator +12V DC output terminal to DC ground. Jump in if I have this wrong!
jerb
Phil Smith
CH 701 - Flying
Buhl, ID
Float Flyr
PostPosted: Thu Dec 02, 2010 2:51 pm    Post subject: Radio noise Reply with quote
Exactly!
Noel
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jerb
Sent: December 2, 2010 5:28 AM
jerb
Phil Smith
CH 701 - Flying
Buhl, ID
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
