OV protection for Alt energized contactor
jonlaury
PostPosted: Mon Nov 22, 2010 12:37 pm    Post subject: OV protection for Alt energized contactor Reply with quote
My Stby alternator energizes its contactor, per the attached drawing.
How do I provide OV protection to the circuit with an OVM 14?
Stby Alt OV protection study.pdf
 Filename:  Stby Alt OV protection study.pdf
 Filesize:  21.67 KB
 Downloaded:  431 Time(s)
Float Flyr
PostPosted: Tue Nov 23, 2010 11:53 am    Post subject: OV protection for Alt energized contactor Reply with quote
Looks to me if the S terminal of your Ford regulator senses too high a
voltage for any reason then it will cut all power to the F terminal of your
alternator. Problem with this set up is that it doesn't give you an
indication that you have gone into an OV situation.
Notice the G2 ground to the case of the regulator is important to have this
clean and corrosion free.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
jonlaury
PostPosted: Tue Nov 23, 2010 1:05 pm    Post subject: Re: OV protection for Alt energized contactor Reply with quote
Noel,
Thanks for your observations. I think I've addressed my own original question with Bob N's direction to an example of std procedure. See the other "OV protection ..." thread
A forest and trees thing.
Float Flyr
PostPosted: Thu Nov 25, 2010 7:30 pm    Post subject: OV protection for Alt energized contactor Reply with quote
Thanks guys That part of the schematic wasn't on the first diagram I saw...
It's good to be, pun intended, on the same page with the rest of you.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
