paddyclarke(at)lineone.ne Guest
Posted: Tue Nov 23, 2010 9:07 am Post subject: Brake Pads |
Hi Folks,
I bought some brake pads from Europa but they seem to be the wrong size - they are a bit smaller and the holes don't match. I got in touch with them and they say that they are the only ones they supply, though they have had the same problem reported by someone else.
Has anyone come across this, and if so, where did you get the right ones from?
Many Thanks,
Paddy Clarke
XS G-KIMM
Posted: Tue Nov 23, 2010 12:38 pm Post subject: Brake Pads |
Hi! Paddy.
I'm a little unsure about this info. because of the trike/mono factors
however I have a couple of Aircraft Spruce & Speciality Co. packets marked
"Rapco brake lining#RA 66-1?6 p/n 06-16956" Loc:19A" I can't make out the ?
I also had some confusion from Europa over the length of the rivets.
However I broke one lining and managed to use a spare lining canibalised
from my unused Mono brake so there must be some commonality.
I strongly advise you to use the correct rivet fitting tool ...that's why I
buggered one!
Europa is telling "porkies" since I'm quite sure my linings came from them
because I wouldn't have researched the Rapco linings myself.
I think there in lies the solution ....the Rapco rivets supplied with the
Rapco Linings aren't long enough so you need the longer rivets from Europa !
Bob Harrison G-PTAG
terrys(at)cisco.com Guest
Posted: Tue Nov 23, 2010 12:39 pm Post subject: Brake Pads |
Hi Paddy,
We have had the same problem, we put our old ones back on and told
Europa about the problem, even included a picture.
Terry Seaver
A135/N135TD
XS mono-wheel with 912S, Airmaster prop
Ivor Phillips
Posted: Tue Nov 23, 2010 1:46 pm Post subject: Brake Pads |
Hi Paddy
Not sure if this is any help but i have ordered a set of WHLBRL-1 linings with rivets from
Matco http://www.matcomfg.com/RelineKitsSwiftline-tp2-12.html
they come with two different length of rivets, these are suitable for the tri-gear,
regards
Ivor
On 23 November 2010 20:30, Robert C Harrison <ptag.dev(at)tiscali.co.uk (ptag.dev(at)tiscali.co.uk)> wrote:
[quote]--> Europa-List message posted by: "Robert C Harrison" <ptag.dev(at)tiscali.co.uk (ptag.dev(at)tiscali.co.uk)>
Hi! Paddy.
buggered one!
Bob Harrison G-PTAG
