Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Mon Nov 22, 2010 5:52 am Post subject: Noisy Facet fuel pump |
Hi Guys. I'm finishing up my fuel system and had the opportunity to try out my Facet fuel pump. Sounds like a hammering noise. Are they all this noisy or is it just me……Geoff
_________________ Dual controls. Dynon 180. Icom 210 Garmin 296. Becker transponder. Sigtronics intercom. Electric flaperons. |
Roger Lee
Posted: Mon Nov 22, 2010 5:57 am Post subject: Re: Noisy Facet fuel pump |
Did you bleed the system of air? If the pump is pumping air it will be more noisy. It may also make a little more noise with no flow going on.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Geoff Heap
Posted: Mon Nov 22, 2010 7:02 am Post subject: Re: Noisy Facet fuel pump |
Yes there could be air in the system. This is the first time use and its exhibiting "flow" peculiarities even though it looks like a simple downhill route. My plans are circa 1990's. Small wing tanks hold about 6 gallon each and feed a 5 gallon header tank. The wing tanks are not hooked up yet. I'm probably jumping the gun here. I should wait untill the wing are permanently on. Typically these 3 tank systems have always had problems with flow. It looks like a "no brainer" liquid running downhill but then it goes back uphill to fill the header tank. From THERE it could be a "no brainer" downhill route to the engine. The pump in the photo is not my boost pump . It is my Transfer pump. Its used to start the flow if necessary. I'm going to shelve this for now and pick it up again when the wings are on. playing with it now may be futile. Thanks anyway Roger......Geoff
201 KB |
10145 Time(s) |
joeing701(at)simnet.is Guest
Posted: Mon Nov 22, 2010 11:35 pm Post subject: Noisy Facet fuel pump |
Hello Geoff.
I have this setup in my plane and it works very well. I only have a fuel gauge in the header tank and some clear tubes in the fuel lines coming from the wings to the Andair fuel valve. This way I know when the wing tanks are empty. My fuel transfere pump makes this rattleing sound but does not effect me because the sound of the engine drowns that out when I have to use the transfere pump. The pump has been in the plane for 5 years. I am very happy with this setup.
Best regards,
Johann G.
Iceland.
Zenith 701
Rotax 912 UL.
----- Upprunalegt skeyti -----
Frá: "Geoff Heap" <stol10(at)comcast.net>
Til: rotaxengines-list(at)matronics.com
Sent: Mánudagur, 22. nóvember, 2010 15:02:09 GMT +00:00 Monrovia
Efni: Re: Noisy Facet fuel pump
http://forums.matronics.com/viewtopic.php?p=320518#320518
http://forums.matronics.com//files/reduced_facet_transfer_pp_172.jpg
Geoff Heap
Posted: Tue Nov 23, 2010 4:54 am Post subject: Re: Noisy Facet fuel pump |
Johann. Nice to hear from you. It's been a while. Yes, I know your fuel system well. So the noise may stay. Oh well. By the way, I think your gross weight would be 960 lbs as its from older plans like mine. How do you like this aspect of your 701......Geoff
