Kolb Firestar Winter storage
Goto page 1, 2  Next
Dennis Thate
PostPosted: Thu Nov 18, 2010 8:22 pm    Post subject: Kolb Firestar Winter storage Reply with quote
I've just purchased a Kolb Firestar / Rotax 503 ULDCDI , I'm putting it in Winter storage. What is the best protocal for storing the Rotax 503UL DCDI for five months ?
rickofudall
PostPosted: Thu Nov 18, 2010 8:53 pm    Post subject: Kolb Firestar Winter storage Reply with quote
Dennis, Get a spray can of misting oil from the local boat shop. Warm the engine to operating temp, shut it down, remove air filter(s), restart engine and bring throttle up to about 3000 RPM, spray misting oil into carb throats until engine dies. Remove a spark plug from each cylinder and spray oil into cylinders. Replace plugs, seal exhaust with a small rubber ball when it's cool enough not to melt the ball. I use a piece of thick plastic over each carb throat ( a zip lock freezer bag is perfect material ) and put air filter(s) back on. See two stroke Operations Manual 11.1.3, page 11-2 for more detailed instructions, but this will get you in the ball park.
Rick Girard
On Thu, Nov 18, 2010 at 10:22 PM, Dennis Thate <retroman(at)frontier.com (retroman(at)frontier.com)> wrote:
--> Kolb-List message posted by: "Dennis Thate" <retroman(at)frontier.com (retroman(at)frontier.com)>
http://forums.matronics.com/viewtopic.php?p=319987#319987
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
 - G.K. Chesterton
by0ung(at)brigham.net
PostPosted: Fri Nov 19, 2010 7:21 am    Post subject: Kolb Firestar Winter storage Reply with quote
I bought a plane so I could go all 12 months of the year,,, unlike boating when there was ice on the lake.. the best thing is to use the plane in the winter and give the engine a good exercise on a regular basis. short of that,,,,, the fogging oil is a real good alternative.
body
Dennis Thate
PostPosted: Fri Nov 19, 2010 12:53 pm    Post subject: Re: Kolb Firestar Winter storage Reply with quote
by0ung,
Our Midwest Winters are very bitter, I prefer not to fly open Cockpit in them. I admire the pilots that do.
Dennis
 Filesize:  45.35 KB
 Viewed:  27419 Time(s)
PostPosted: Fri Nov 19, 2010 1:49 pm    Post subject: Kolb Firestar Winter storage Reply with quote
by0ung,
Dennis
probably not much worse than here in northern ut,,,, guess that is why I put on the full enclosure and heater. I have gone out when outside temps hover round 20, 10 when I landed,,,, but days up in the high 30s and low 40s are much preferred.
boyd
zeprep251(at)aol.com
PostPosted: Fri Nov 19, 2010 6:34 pm    Post subject: Kolb Firestar Winter storage Reply with quote
Boyd,
Ship it down to Rick Neilsen in Fla.He'll keep it warm for you.
G.Aman
PostPosted: Sat Nov 20, 2010 9:04 am    Post subject: Kolb Firestar Winter storage Reply with quote
Boyd,
G.Aman
guess if i were not a scardi cat... and most of all if i were retired and had the time... I would fly it down and keep it warm with rick... should have done it last year when my son was in the keys.
boyd
neilsenrm(at)gmail.com
PostPosted: Sat Nov 20, 2010 2:56 pm    Post subject: Kolb Firestar Winter storage Reply with quote
Boyd
Hey just a bunch of short hops strung together. It is certainly nice to be retired so time isn't an issue. It's been in the low 80s and sunny in Florida. Come on down.
I will miss not having my Kolb down here this winter but not that $300/ month hanger charge. I think it will be cheaper to rent this winter. Tuesday I'm scheduled to get checked out in a Sport Cruiser (this is the new Piper LSA). It will not be anything like a Kolb but it is flying and a bit faster.
Gary when you get down here we will need to schedule a flyin. If we can get Buford to leave his home airport again we may be able to talk George A in to joining us????
Rick Neilsen
Redrive VW Powered MKIIIC
On Sat, Nov 20, 2010 at 12:02 PM, b young <by0ung(at)brigham.net (by0ung(at)brigham.net)> wrote:
[quote] B oyd,
G.Aman
boyd
.com/" target="_blank">www.buildersbooks.com
rickofudall
PostPosted: Sat Nov 20, 2010 3:49 pm    Post subject: Kolb Firestar Winter storage Reply with quote
Rick, You'll like the Piper. Very light handling. I wonder how they set the prop. The Sport Cruiser dealer in Wichita had both his aircraft set so that the 912 could only turn 5200 RPM on take off, but the EFIS showed a nice 138 kt cruise. Not exactly LSA legal, but it sure was fun.
Rick Girard
On Sat, Nov 20, 2010 at 4:48 PM, Richard Neilsen <neilsenrm(at)gmail.com (neilsenrm(at)gmail.com)> wrote:
Boyd
Rick Neilsen
B oyd,
G.Aman
boyd
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
 - G.K. Chesterton
PostPosted: Sat Nov 20, 2010 4:06 pm    Post subject: Kolb Firestar Winter storage Reply with quote
Boyd,
Just rubb'in it in a little.Packing up the Mk3 and heading south in about 10 days.Tell Becky, Marj says hi.
G.A.
PostPosted: Sat Nov 20, 2010 4:10 pm    Post subject: Kolb Firestar Winter storage Reply with quote
Rick, Sounds good to me.See you in a couple weeks
G.A.
PostPosted: Sat Nov 20, 2010 4:36 pm    Post subject: Kolb Firestar Winter storage Reply with quote
Boyd
Rick Neilsen
just need someone to donate say half a mil... d find a way to get more than 1% interest in the bank.... i would have retired last week.
boyd
beauford
PostPosted: Sat Nov 20, 2010 6:41 pm    Post subject: Kolb Firestar Winter storage Reply with quote
Brother Rick…
I have a car…and a truck. In the event the Nazi 447 will not start…or the Kleenex Kolb will not fly because my butt and the Macanudo stogie are too heavy… will come anyway…
p.s. Brother Alexander is known to be a sucker for these events…
Beauford
FF-076
Brandon, FL
If you forward this e-mail, please remove my name before sending it... I promise to do the same for you...
Thanks...
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of b young
Sent: Saturday, November 20, 2010 7:33 PM
Subject: Re: Kolb Firestar Winter storage
Boyd
Rick Neilsen
boyd
<www.buildersbooks.comwww.homebuilthelp.comhttp://www.matronic=================
http://forums.matronics.com[/url]=====[/b][b]
Dennis Thate
PostPosted: Sat Nov 20, 2010 7:57 pm    Post subject: Re: Kolb Firestar Winter storage Reply with quote
by0ung
Have to admit...this does look like fun
 Filesize:  47.44 KB
 Viewed:  27381 Time(s)
PostPosted: Sat Nov 20, 2010 8:58 pm    Post subject: Kolb Firestar Winter storage Reply with quote
Ohooooo.......
Gasp...
Is that frozen water?????
Some time in my past I remember bone chilling Michigan winters. I have a pair of frozen water skies that I built for my MKIIIC. I used water skies that I glued and screwed a chunk of 2X4 to with blocking for support. The hinge is a standard door hinge with the hinge pin replaced with a bolt for easy (sort of) removal. The skies were attached just inside the wheels just above the ground so that the plane would roll on a hard surface yet slide in deep snow. The pictured restraining cables keep the skies restrained to a limited movement yet allow rotation and movement over snow banks. The bungee shown was doubled and kept the ski tips up in flight. The aluminum tangs shown fit in front and back of the lower wing strut fittings on the fuselage.
Rick Neilsen
1st Redrive VW Powered MKIIIC
On Sat, Nov 20, 2010 at 10:57 PM, Dennis Thate <retroman(at)frontier.com (retroman(at)frontier.com)> wrote:
by0ung
http://forums.matronics.com/viewtopic.php?p=320230#320230
http://forums.matronics.com/===
he Contribution link below to find out more about
* The Builder's Bookstore www.buildersbooks.com
s.com/contribution" target="_blank">http://www.matronics.com/contribution
                             -Matt Dralle, Li    - The Kolb-List Email Forum -
b-List" target="_blank">http://www.matronics.com/Navigator?Kolb-List<    - MATRONICS WEB FORUMS -
=   --> h
 Filesize:  236.29 KB
 Viewed:  27378 Time(s)
elleryweld(at)aol.com
PostPosted: Sun Nov 21, 2010 6:04 am    Post subject: Kolb Firestar Winter storage Reply with quote
it is Dennis that's my old Firestar & the skis I built for it winter flying is the best
Ellery Batchelder Jr.
PostPosted: Sun Nov 21, 2010 7:44 am    Post subject: Kolb Firestar Winter storage Reply with quote
p.s. Brother Alexander is known to be a sucker for these events…<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Beauford
what do you mean..... if the 447 wont start? i thought the kleenex flying machine used a rubber band.
LOL
boyd
PostPosted: Sun Nov 21, 2010 8:06 am    Post subject: Kolb Firestar Winter storage Reply with quote
--> Kolb-List message posted by: "Dennis Thate" <[url=mhtml:{5AC3E496-28A9-4636-8462-BD772D208FC1}mid://00000194/!x-usc:mailto:retroman(at)frontier.com]retroman(at)frontier.com[/url]>
by0ung
have to admit,,, i have never tired skis..... thought about it a bunch.
boyd young
utah
pj.ladd(at)btinternet.com
PostPosted: Mon Nov 22, 2010 3:12 am    Post subject: Kolb Firestar Winter storage Reply with quote
have to admit,,, i have never tired skis.>>
Hi,
I have a friend, a CFI of a local ultralight school who told me that in his youth he tied the bumpers (fender?) of a car to the undercariage.
This was in a particularly hard winter and he wanted to visit his girl friend on the other side of the valley.
Of course this was in olden times when they were a separate item which could be easily unbolted from the car, not moulded into the body as they are now.
Cheers
Pat
Dennis Thate
PostPosted: Tue Nov 30, 2010 2:25 pm    Post subject: Re: Kolb Firestar Winter storage Reply with quote
I found this excellent video on Winter Storage of Rotax Aircraft engines.
http://www.mefeedia.com/watch/26641749
Goto page 1, 2  Next
Page 1 of 2
