Fuel Filter
jfrjr(at)roadrunner.com
PostPosted: Tue Nov 16, 2010 5:50 pm    Post subject: Fuel Filter Reply with quote
About to start my first annual and want to change the fuel filter from the single unit to two under the seats like others have done. Are folks just using a second ES Airflow filter or something smaller? Would appreciate part numbers if you have them. Jay Rowe #40301
jesse(at)saintaviation.co
PostPosted: Tue Nov 16, 2010 6:26 pm    Post subject: Fuel Filter Reply with quote
I have done this in one installation and used the ES Airflow filter from Airflow Performance on both sides. I really like the quality and serviceability of this filter. Note, however, that to remove and clean the filter, the fuel tank will have to be emptied completely because there will not be a fuel selector valve between the tank and the filter to provide a fuel shutoff.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Nov 16, 2010, at 8:46 PM, <jfrjr(at)roadrunner.com> <jfrjr(at)roadrunner.com> wrote:
kdbelue(at)charter.net
PostPosted: Wed Nov 17, 2010 6:21 am    Post subject: Fuel Filter Reply with quote
I put one of these filters in each wing root and they’ve worked great over 150hrs. Easy to clean and access in the wing root…
http://www.wicksaircraft.com/catalog/product_detail.php/pid=14137~subid=11799/index.html
FUEL FILTER-AN6
A high-performance fuel filter designed to meet the needs of the aerospace industry, providing 15 gpm fuel flow with no pressure drop along with maximum filtration protection. The 10 micron element is made of pleated 304 stainless steel and cleans easily with air or soluble rinse for indefinite re-use. The outer body is CNC machined from 6061-T6 aluminum and clear anodized. Includes plated mounting bracket. For use with all fuels. Size: [url=x-apple-data-detectors://1]4-1/4[/url]"x 2". Wt: 5 oz. Experimental aircraft only.
SKU: FF4006
Our Price: $72.85
Click to enlarge image
PRICE
AN6 FF4006 $72.85
On Nov 16, 2010, at 7:46 PM, <jfrjr(at)roadrunner.com (jfrjr(at)roadrunner.com)> wrote:
[quote]--> RV10-List message posted by: <jfrjr(at)roadrunner.com (jfrjr(at)roadrunner.com)>
dlm46007(at)cox.net
PostPosted: Wed Nov 17, 2010 9:06 am    Post subject: Fuel Filter Reply with quote
what flow do you get for takeoff? My EFIS shows a 24 gph rate for full power; I am using the Lyc IO540 D4A5.
drfred(at)suddenlinkmail.
PostPosted: Wed Nov 17, 2010 9:39 am    Post subject: Fuel Filter Reply with quote
Just finished my second condition inspection. I too, thought about
changing to move the filters under the seats. I purchased some of the
auto racing fuel filters. I don't have the part numbers here with me at
the office. Anyway, instillation would be straightforward. I planned
to put some valves on the tank side to not have the fuel problem with
changing them. As I look more closely at them, I decided to leave the
stock set up alone. I think David's post is asking the question of
proper fuel flow with the other filters. The stock filter in the tunnel
has a very large screen surface. The automotive racing ones and the one
from wicks noted unrestricted flow at 15 gal/hr. At take off, I also
see upwards of 22-24 ga/hr flow.
I also noted the screen size (about size of dime) looked like a great
place for a contaminant obstruction. A good size Texas bug could easily
knock out 50% of the fuel flow.
I also read another post somewhere that high up in the reasons for
experimental aircraft to fall from the sky was fuel system
modification. Decided not to do any more test piloting.
I made up a wrench to fit over the stock filter and it isn't as bad to
change as it could be.
Tim ; good post on the wheel pant bushings. Starting to see the same
changes. I had to re torque mine this year. Will make some spacers
the next time I have to get down there.
Dr Fred
300 hrs
515FW.
Albert Gardner
PostPosted: Wed Nov 17, 2010 10:02 am    Post subject: Fuel Filter Reply with quote
I made this cutout under the fuse to allow access to my filter from underneath. Works good.
Albert Gardner
N991RV
Yuma, AZ
 Filesize:  27.91 KB
 Viewed:  5601 Time(s)
RV-9A N872RV
RV-10 N991RV
PostPosted: Wed Nov 17, 2010 10:45 am    Post subject: Fuel Filter Reply with quote
The filter is good for 15gpm,
which is 900gph - way more than
what an IO540 consumes.....
On Nov 17, 2010, at 10:14 AM, "DLM" <dlm46007(at)cox.net (dlm46007(at)cox.net)> wrote:
[quote] what flow do you get for takeoff? My EFIS shows a 24 gph rate for full power; I am using the Lyc IO540 D4A5.
PostPosted: Wed Nov 17, 2010 10:54 am    Post subject: Fuel Filter Reply with quote
The Wicks filter I quoted earlier has a large filter element - much larger than a dime, more like 1.5 - 2 inches. When I was building, I was concerned about having only one filter - if it gets blocked you're coming down. With a filter on each tank, if one gets blocked, switch to the other tank.
Also, I don't like the hard to access filter in the tunnel. Filters in the wing root are easy to access. The Wick's filter quoted before will flow 15gpm, which is 900gph - way more than required.
On Nov 17, 2010, at 11:33 AM, "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> wrote:
Just finished my second condition inspection. I too, thought about changing to move the filters under the seats. I purchased some of the auto racing fuel filters. I don't have the part numbers here with me at the office. Anyway, instillation would be straightforward. I planned to put some valves on the tank side to not have the fuel problem with changing them. As I look more closely at them, I decided to leave the stock set up alone. I think David's post is asking the question of proper fuel flow with the other filters. The stock filter in the tunnel has a very large screen surface. The automotive racing ones and the one from wicks noted unrestricted flow at 15 gal/hr. At take off, I also see upwards of 22-24 ga/hr flow.
I also noted the screen size (about size of dime) looked like a great place for a contaminant obstruction. A good size Texas bug could easily knock out 50% of the fuel flow.
I also read another post somewhere that high up in the reasons for experimental aircraft to fall from the sky was fuel system modification. Decided not to do any more test piloting.
rene(at)felker.com
PostPosted: Wed Nov 17, 2010 3:54 pm    Post subject: Fuel Filter Reply with quote
"When I was building, I was concerned about having only one filter - if it
gets blocked you're coming down"
I am not sure this is true for the stock build. I would have to go back and
look, but there is a bypass line and check valve built in. I am not 100
percent sure, but maybe 90 percent.
Anybody else know for sure.
Rene' Felker
N423CF
801-721-6080
rv10builder(at)verizon.ne
PostPosted: Wed Nov 17, 2010 4:19 pm    Post subject: Fuel Filter Reply with quote
you are correct there is a bypass.
Sent: Wednesday, November 17, 2010 3:51 PM
Subject: RE: Fuel Filter
and
Rene' Felker
N423CF
801-721-6080
gengrumpy(at)aol.com
PostPosted: Wed Nov 17, 2010 7:45 pm    Post subject: Fuel Filter Reply with quote
I guess I don't see the issue here.
After building plus 4 condition inspections, I find the stock filter
removal and inspection a very simple matter.
You have to open up the tunnel anyway......
grumpy
partner14
PostPosted: Wed Nov 17, 2010 7:55 pm    Post subject: Fuel Filter Reply with quote
Just a little heads up.... one person is talking gallons per minute, the other, gallons per hour.
Don
--- On Wed, 11/17/10, DLM <dlm46007(at)cox.net> wrote:
Subject: Re: Fuel Filter
Date: Wednesday, November 17, 2010, 8:14 AM
Don A. McDonald
40636
Robin(at)PaintTheWeb.com
PostPosted: Wed Nov 17, 2010 8:19 pm    Post subject: Fuel Filter Reply with quote
Correction, one person is talking RV-10 and the other is taking F-18 (in economy mode).
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Don McDonald
Sent: Wednesday, November 17, 2010 7:53 PM
Don
--- On Wed, 11/17/10, DLM <dlm46007(at)cox.net (dlm46007(at)cox.net)> wrote:
From: DLM <dlm46007(at)cox.net (dlm46007(at)cox.net)>
Subject: Re: RV10-List: Fuel Filter
PostPosted: Wed Nov 17, 2010 8:33 pm    Post subject: Fuel Filter Reply with quote
There is a bypass around the pump if it stops or to relieve excess flow, which goes back to the fuel selector, but no bypass around the filter.
See the fuel pump manual on Tim's site:
http://www.myrv10.com/tips/maintenance/FuelSystem/index.html
On Nov 17, 2010, at 6:14 PM, "Pascal" <[url=mailto:rv10builder(at)verizon.net]rv10builder(at)verizon.net (rv10builder(at)verizon.net)[/url]> wrote:
--> RV10-List message posted by: "Pascal" <[url=mailto:rv10builder(at)verizon.net]rv10builder(at)verizon.net (rv10builder(at)verizon.net)[/url]>
From: "Rene Felker" <[url=mailto:rene(at)felker.com]rene(at)felker.com (rene(at)felker.com)[/url]>
To: <[url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]>
--> RV10-List message posted by: "Rene Felker" <[url=mailto:rene(at)felker.com]rene(at)felker.com (rene(at)felker.com)[/url]>
Rene' Felker
N423CF
801-721-6080
_-
PostPosted: Wed Nov 17, 2010 9:09 pm    Post subject: Fuel Filter Reply with quote
This is correct. If your filter becomes clogged, you will have no fuel flow to your engine. I have never seen more than just a little bit of "lint" in the filter when removing for cleaning. Usually any sizeable particles would be caught by the finger strainer in the tank or be sumped out. It is a good idea to periodically remove the sump drains and drain at least a little bit of fuel from the tank, which will help remove any particles that settle to the bottom of the tank and possibly other particles that are too big to get through the finger strainer in the tank. I personally think you would have to try extremely hard to intentionally cause a problem to be able to get the Airflow Performance filter clogged to the point of preventing enough fuel from getting to the engine. I think you would much sooner clog your finger strainer in the tank, of which you have two. The purpose of putting in two filters, IMHO, is to allow for easier removal for inspection by placing them under the front seats.
Jesse Saint
C: 352-427-0285
F: 815-377-3694
On Nov 17, 2010, at 11:17 PM, Kevin Belue wrote:
[quote]There is a bypass around the pump if it stops or to relieve excess flow, which goes back to the fuel selector, but no bypass around the filter.
[/url][url=http://www.myrv10.com/tips/maintenance/FuelSystem/index.html]http://www.myrv10.com/tips/maintenance/FuelSystem/index.html
On Nov 17, 2010, at 6:14 PM, "Pascal" < (rv10builder(at)verizon.net)rv10builder(at)verizon.net (rv10builder(at)verizon.net)> wrote:
--> RV10-List message posted by: "Pascal" < (rv10builder(at)verizon.net)rv10builder(at)verizon.net (rv10builder(at)verizon.net)>
From: "Rene Felker" < (rene(at)felker.com)rene(at)felker.com (rene(at)felker.com)>
To: < (rv10-list(at)matronics.com)rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
--> RV10-List message posted by: "Rene Felker" < (rene(at)felker.com)rene(at)felker.com (rene(at)felker.com)>
Rene' Felker
N423CF
801-721-6080
_-
href="http://www.aeroelectric.com/">www.aeroelectric.com
href="http://www.buildersbooks.com/">www.buildersbooks.com
href="http://www.homebuilthelp.com/">www.homebuilthelp.com
