sean(at)stephensville.com Guest
Posted: Mon Nov 15, 2010 7:07 am Post subject: Rivet Set Recommendation? |
What have others used for a rivet set to get the rivets on the fuse
skins next to the spar carry through in the attached pic? I don't have
a swivel flush set, but maybe that would work?
-Sean #40303
1 MB |
5677 Time(s) |
Neal.George(at)hurlburt.a Guest
Posted: Mon Nov 15, 2010 8:54 am Post subject: Rivet Set Recommendation? |
I believe I'd back-shoot those...
neal
What have others used for a rivet set to get the rivets on the fuse skins
next to the spar carry through in the attached pic? I don't have a swivel
-Sean #40303
 Download |
| Filename: |
smime.p7s |
5.09 KB |
| Downloaded: |
458 Time(s) |
Posted: Mon Nov 15, 2010 10:39 am Post subject: Rivet Set Recommendation? |
The shop side of these are inside the side channel, so they can't be
back shot. The forward ones can, but not the aft side.
On 11/15/10 10:44 AM, George, Neal E Capt USAF ACC 505 TRS/DOJ wrote:
| Quote: | I believe I'd back-shoot those...
neal
-Sean #40303
seipel(at)seznam.cz Guest
Posted: Mon Nov 15, 2010 11:08 am Post subject: Rivet Set Recommendation? |
I used http://www.yardstore.com/browse.cfm/4,3673.html
The face is curved enough to give you room for the rivet gun and still
keep it flat on the rivet.
PJ Seipel
RV-10 #40032
On 11/15/2010 10:04 AM, Sean Stephens wrote:
| Quote: | What have others used for a rivet set to get the rivets on the fuse
skins next to the spar carry through in the attached pic? I don't have a
-Sean #40303
9.34 KB |
5666 Time(s) |
Posted: Mon Nov 15, 2010 2:27 pm Post subject: Rivet Set Recommendation? |
Thanks for the link. For some reason the Yard Store slipped my mind.
I'm wondering if I'd get additional use out of a flush "C" set which
also seems like it would do the job.
http://www.yardstore.com/browse.cfm/4,3664.html
-Sean #40303
On 11/15/10 1:06 PM, PJ Seipel wrote:
| Quote: | I used http://www.yardstore.com/browse.cfm/4,3673.html
PJ Seipel
RV-10 #40032
> Thanks,
> -Sean #40303
Andy Turner
Posted: Mon Nov 15, 2010 7:29 pm Post subject: Re: Rivet Set Recommendation? |
I worried about those rivets and put them off for a while, as well as the rivets around the rear spar attach. Turned out though that my Avery swivel flush set worked fine. I pushed the rubber guard up against the spar, and there was just enough room to get good meat on the rivet, if that makes sense.
_________________ Andy Turner |
Posted: Sat Nov 20, 2010 2:29 pm Post subject: Rivet Set Recommendation? |
Just an update for those not to the fuse side skins yet. I actually
went with the 7 1/2 inch version of what PJ linked below just to make
sure I cleared the spar with the rivet gun.
http://www.yardstore.com/browse.cfm/4,3741.html
This worked great for the fuse side skins next to the spar. I wish I
had this set when doing the bottom wing skins next to the flap attach
also. One note, that is similar for other longer rivet sets. It takes
quite a bit more pressure with the added length. This is one of those
places that I wished I had gotten a 3x gun instead of a 2x.
-Sean #40303 (long and nasty section 29 almost complete)
| Quote: | > I used http://www.yardstore.com/browse.cfm/4,3673.html
> still keep it flat on the rivet.
> PJ Seipel
> RV-10 #40032
>> have a
>> Thanks,
>> -Sean #40303
rv10flyer
Posted: Sat Nov 20, 2010 3:06 pm Post subject: I used my long back rivet set |
on the rivets near flap hinges and these. Already had this tool and did not want to buy another tool for just a few places. Just put masking tape over rivets to help keep it from sliding, have a helper on the other side and keep your set straight.
_________________ Wayne G. |
