iPad bracket
Robin(at)PaintTheWeb.com
PostPosted: Sat Nov 13, 2010 2:36 pm    Post subject: iPad bracket Reply with quote
I doubt this would work in an airplane due to turbulence driving down the
iPad but in theory this mounted to the top of the canopy would allow of
excellent positioning to review content and then swing away when not in use
coop85(at)verizon.net
PostPosted: Sun Nov 14, 2010 4:09 pm    Post subject: iPad bracket Reply with quote
This actually looks pretty slick.  It would be easy enough to make some kind of a catch to hold the display up when out of place, perhaps a spring clip to catch the tube.
Thanks for the idea…now all I need is an iPad!
Marcus
40286
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Saturday, November 13, 2010 5:30 PM
Subject: iPad bracket
I doubt this would work in an airplane due to turbulence driving down the iPad but in theory this mounted to the top of the canopy would allow of excellent positioning to review content and then swing away when not in use.
Robin
Description
What luxury to have cabinet-mounted iPad! What luxury to have an iPad at all, really. At $70 (plus the cost of an iPad) lazy recipe-readers could have one under every cupboard in the kitchen. Sign me up for 10.
Griffin's cabinet mount dock is probably not intended for holding an iPad permanently, but I like to imagine people will have one in the kitchen, the garage and even the bathroom. Stuff prising it out of the brackets every time you want to use it, right? Amirite?
The mount's arm rotates by 360-degrees, and the whole 'pad can move 90-degrees so it aligns flush under a cupboard, and then can be pulled out when in use. In the US it's $70, and in the UK it's £50, available now. [Griffin]
 Filesize:  123.48 KB
 Viewed:  1308 Time(s)
PostPosted: Sun Nov 14, 2010 5:12 pm    Post subject: iPad bracket Reply with quote
I bet this would probably work better because one can get any length
articulating arm with twist lock.
Robin
[image: http://www.ram-mount.com/Portals/0/PartImages/RAM-B-138-AP8U.jpg]
http://www.ram-mount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045049051056045065080056085/Default.aspx
*From:* owner-rv10-list-server(at)matronics.com [mailto:
owner-rv10-list-server(at)matronics.com] *On Behalf Of *Marcus Cooper
*Sent:* Sunday, November 14, 2010 4:06 PM
*To:* rv10-list(at)matronics.com
*Subject:* RE: iPad bracket
to catch the tube.
Marcus
40286
owner-rv10-list-server(at)matronics.com] *On Behalf Of *Robin Marks
*Sent:* Saturday, November 13, 2010 5:30 PM
*Subject:* iPad bracket
