teamgrumman(at)yahoo.com Guest
Posted: Tue Nov 09, 2010 11:03 pm Post subject: brakes |
OK, how would this happen?
52.58 KB |
5203 Time(s) |
64.68 KB |
5203 Time(s) |
flyadive(at)gmail.com Guest
Posted: Wed Nov 10, 2010 5:37 am Post subject: brakes |
Gary:
Is it BROKEN out or WORN out part of the pin that we are seeing?
If broken out then it is a smelting problem and you found the 1 in a 1,000,000.
If it is worn out...
What does the pad plate look like?
It looks like it is the pilot side brake. And the top pin.
Forward movement of the plane with braking would cause a rotational torque upward in the direction of the top pin. This could constantly bang the pad plate against the pin.
The angle of the ware would indicate at what point in the travel the maximum pressure angle occurred.
But, would also show ware on the pad plate.
What does the pad look like?
Was the Piston kicked on an angle?
How was the Piston O-Ring?
Gary, you find some of the weirdest problems... It must be a West Coast Thing... Too close to California.
Barry
On Wed, Nov 10, 2010 at 1:59 AM, Gary Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
| Quote: | OK, how would this happen?
Barry
"Chop'd Liver"
bob.hodo(at)yahoo.com Guest
Posted: Wed Nov 10, 2010 5:39 am Post subject: brakes |
| Quote: | >>OK, how would this happen?<<<
Properly installed it could not have happened. Right?
Sure looks like that ground away pin rode against a flat surface that was turning while it was still. How does it fit against the top of the brake rotor? Is that a match? How it got there and stayed there is quite a puzzle, just from memory of how the pieces fit.
Bob Hodo
Posted: Wed Nov 10, 2010 6:02 am Post subject: brakes |
Gary & Bob H.:
Ya know I like Bob's answer/question. Is there more to the story that the picture is not showing?
Did it rub against the rotor?
Barry
On Wed, Nov 10, 2010 at 8:35 AM, Bob Hodo <bob.hodo(at)yahoo.com (bob.hodo(at)yahoo.com)> wrote:
| Quote: | >>>OK, how would this happen?<<<
Bob Hodo
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
st" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
tp://forums.matronics.com
Barry
"Chop'd Liver"
Posted: Wed Nov 10, 2010 9:46 am Post subject: brakes |
Your guess is as good as mine. I looked at all related parts. No abnormal wear.
Sent: Wed, November 10, 2010 5:35:15 AM
Subject: Re: brakes
Bob Hodo
Posted: Wed Nov 10, 2010 10:44 am Post subject: brakes |
Is the wear on that in pin fresh or did it happen a long time ago?
Sent via DROID on Verizon Wireless
-----Original message-----
[quote]From: Gary Vogt <teamgrumman(at)yahoo.com>
Sent: Wed, Nov 10, 2010 17:51:36 GMT+00:00
Subject: Re: TeamGrumman-List: brakes
Bob Hodo
garnerrice(at)hotmail.com Guest
Posted: Wed Nov 10, 2010 12:21 pm Post subject: brakes |
Its simple. Somebody at some point want to remove the guide pin and couldn't figure how to get a wrench on it. So now they can put the metric wrench on it and twist. Isn't that SAP? (standard alabamy practice)
Date: Wed, 10 Nov 2010 09:43:31 -0800
Subject: Re: brakes
.ExternalClass DIV {;} Your guess is as good as mine. I looked at all related parts. No abnormal wear.
Subject: Re: brakes
Bob Hodo
_blank>www.aeroelectric.com
/" target=_blank>www.buildersbooks.com
=_blank>www.homebuilthelp.com
=_blank>http://www.matronics.com/contribution
List" target=_blank>http://www.matronics.com/Navigator?TeamGrumman-List
ttp://forums.matronics.com
Posted: Wed Nov 10, 2010 2:21 pm Post subject: brakes |
Tell ya what Gary... After you pull the part - If you want to send it to me I'll do an acid test to see if it was a defect in material or abrasion.
Barry
On Wed, Nov 10, 2010 at 12:43 PM, Gary Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
| Quote: | Your guess is as good as mine. I looked at all related parts. No abnormal wear.
From: Bob Hodo <bob.hodo(at)yahoo.com (bob.hodo(at)yahoo.com)>
To: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
Bob Hodo
Barry
"Chop'd Liver"
Posted: Wed Nov 10, 2010 3:37 pm Post subject: brakes |
I replaced the part yesterday and threw the old one away. It looked like it had been there a while. If I were to guess, it looked like someone intensionally ground it down on a bench grinder.
Sent: Wed, November 10, 2010 2:19:04 PM
Subject: Re: brakes
Barry
Subject: Re: brakes
Bob Hodo
Barry
"Chop'd Liver"
flyv35b(at)minetfiber.com Guest
Posted: Wed Nov 10, 2010 4:42 pm Post subject: brakes |
Why not just replace the two pins? The caliper didn't look to bad if it were bead blasted and cleaned up.
Cliff
Posted: Wed Nov 10, 2010 8:01 pm Post subject: brakes |
you amaze me Cliff. No where in my email did I say I replaced the caliper.
Sent: Wed, November 10, 2010 4:39:43 PM
Subject: Re: brakes
DIV { MARGIN:0px;} Why not just replace the two pins? The caliper didn't look to bad if it were bead blasted and cleaned up.
Cliff
Posted: Thu Nov 11, 2010 6:45 am Post subject: brakes |
You're right, you just said you threw the part away. not the caliper. I guess I just assumed you threw the assembly away. Bad assumption.
jnlncody(at)wildblue.net Guest
Posted: Thu Nov 11, 2010 7:04 am Post subject: brakes |
Gary,
the only time I have had the brake assembly get notched was with a wheel bearing that was failing.
not the same type of aircraft it was on a Turbine Commander 840. Just maybe a similar thing is happening here
