capt_riney(at)yahoo.com Guest
Posted: Tue Nov 09, 2010 12:25 pm Post subject: Mark III Data Plate |
Getting ready for my airworthiness inspection. Curious as where others have mounted their data plate. I'm thinking about putting on the aft part of the fuselage tube, back by the tail feathers.
Mark Rinehart
Indy Mark III
Posted: Tue Nov 09, 2010 12:36 pm Post subject: Mark III Data Plate |
that's where mine is
BB
On 9, Nov 2010, at 3:21 PM, mark rinehart wrote:
Mark Rinehart
Indy Mark III
by0ung(at)brigham.net Guest
Posted: Tue Nov 09, 2010 1:52 pm Post subject: Mark III Data Plate |
I put mine on the side of the boom tube up by the h section.
boyd young
Mark Rinehart
Indy Mark III
bill_joe(at)bellsouth.net Guest
Posted: Tue Nov 09, 2010 2:55 pm Post subject: Mark III Data Plate |
Hi guys,,when I got my inspection the FAA wants that on the rear end of the tube. Bill Futrell
ces308
Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
Posted: Tue Nov 09, 2010 6:18 pm Post subject: Re: Mark III Data Plate |
My inspector didn't care as long as it was on the out side of the aircraft...mine is at the tail of the fuselage..
chris ambrose
M3X/jab
n327CS
651.98 KB |
8019 Time(s) |
Posted: Tue Nov 09, 2010 6:53 pm Post subject: Mark III Data Plate |
In my case the inspector said the reason the manual calls for it to be
somewhere in the tail section is because in a lot of crashes that is the
only thing left in case of fire or something like that. Bill
pj.ladd(at)btinternet.com Guest
Posted: Wed Nov 10, 2010 8:07 am Post subject: Mark III Data Plate |
The idea of the data plate being metal is that it will survive anywhere.
Mines on the engine bearer
Pat
rickofudall
Posted: Wed Nov 10, 2010 9:27 am Post subject: Mark III Data Plate |
Pat, all, this is the FAR that concerns the aircraft identification plate:
5.11 Marking of products.
(a) Aircraft . A manufacturer of aircraft covered under §21.182 of this chapter must mark each aircraft by attaching a fireproof identification plate that—
(1) Includes the information specified in §45.13 using an approved method of fireproof marking;
(2) Must be secured in such a manner that it will not likely be defaced or removed during normal service, or lost or destroyed in an accident; and
(3) Except as provided in paragraphs (d) through (h) of this section, must be secured to the aircraft fuselage exterior so that it is legible to a person on the ground, and must be either adjacent to and aft of the rear-most entrance door or on the fuselage surface near the tail surfaces.
Rick Girard
On Wed, Nov 10, 2010 at 10:04 AM, Pat Ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Pat Ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
The idea of the data plate being metal is that it will survive anywhere. Mines on the engine bearer
Pat
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
http://forums.matronics.com
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
- G.K. Chesterton
rickofudall
Cut the 4 off of 45.11
Rick
On Wed, Nov 10, 2010 at 11:24 AM, Richard Girard <aslsa.rng(at)gmail.com>wrote:
[quote] Pat, all, this is the FAR that concerns the aircraft identification plate:
(a) *Aircraft *. A manufacturer of aircraft covered under §21.182 of this
plate that—
Posted: Thu Nov 11, 2010 2:04 am Post subject: Mark III Data Plate |
Hi Richard,
interesting. I don`t think that I have ever seen a written spec. about the plate placement. Main thing is that it is likely to survive a crash. What is on the plate is specified of course.
Pat
rickofudall
Posted: Thu Nov 11, 2010 10:42 am Post subject: Mark III Data Plate |
Pat, I don't know about the validity of the story, but what I've been told by several, including the FAA inspector who issued the Airworthiness Certificate for my Firestar, that this data plate was mandated following a request from the DEA. So many planes were being stolen in Florida and surrounding states to be used for drug running and then crashed in the Everglades that they needed a way to determine ownership of the aircraft without having to bring in heavy equipment to dig it out. Hence the request that the plate be put behind the rear most loading door or near the tail.
Rick
On Thu, Nov 11, 2010 at 4:01 AM, Pat Ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
| Quote: | Hi Richard,
Pat
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
- G.K. Chesterton
Posted: Thu Nov 11, 2010 11:22 am Post subject: Mark III Data Plate |
I don't know about the validity >>
Interesting. I don`t think there are any records here of smuggling by ulralight from France. More likely to be Pakistanis, Indians or other alien.
Pat
