Seat rail alignment issue
rv10rob(at)gmail.com
PostPosted: Sun Nov 07, 2010 9:49 am    Post subject: Seat rail alignment issue Reply with quote
Hi, all... I'm installing the seat rails now, and I have a fit problem.  I bolted the outboard mid rail support to the landing gear weldment (that was fun), but the holes for the rail aren't lining up with the seat floor.  The seat floor and rails agree, but the mid rail support doesn't.  Pic attached (left side of the picture is forward).  The right seat is pictured, but It's pretty much the same on the left side.  Anyone run into this issue?
Thanks...
-Rob
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
 Filesize:  460.02 KB
 Viewed:  1856 Time(s)
rleffler
PostPosted: Sun Nov 07, 2010 1:49 pm    Post subject: Seat rail alignment issue Reply with quote
I’m sure you’ve already thought of this, but I when I run into this situation, it’s usually because I’ve orientated the piece incorrectly. i.e. upside down or left swapped with right.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
Sent: Sunday, November 07, 2010 12:40 PM
To: rv10-list
Subject: Seat rail alignment issue
Thanks...
-Rob
Rob Kochman
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
PostPosted: Mon Nov 08, 2010 10:37 pm    Post subject: Seat rail alignment issue Reply with quote
Thanks, Bob... I looked around for something I might have done wrong, but there's not too much complicated around there, and the left and the right ones are the same.  For anyone else who may run into this, I called Van's, and they said it would be acceptable to "slot" the holes in the seat rail support, where it attaches to the gear weldment, so that's what I did, and all's well.
Thanks...
-Rob
On Sun, Nov 7, 2010 at 1:43 PM, Bob Leffler <rv(at)thelefflers.com (rv(at)thelefflers.com)> wrote:
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rob Kochman
To: rv10-list
Thanks...
-Rob
Rob Kochman
"_blank">www.aeroelectric.com
.com/" target="_blank">www.buildersbooks.com
ttp://forums.matronics.com
Rob Kochman
carl.froehlich(at)verizon
PostPosted: Tue Nov 09, 2010 3:54 am    Post subject: Seat rail alignment issue Reply with quote
I think the left and right seat plates are not identical.
Carl
Sent from my mobile phone.   Please read past the typos.
-----Original message-----
[quote]From: Rob Kochman <rv10rob(at)gmail.com>
To:
rv10-list(at)matronics.com
Sent:
Tue, Nov 9, 2010 06:30:55 GMT+00:00
Subject:
Re: RV10-List: Seat rail alignment issue
Thanks...
-Rob
To: rv10-list
Subject: RV10-List: Seat rail alignment issue
Thanks...
-Rob
Rob Kochman
Rob Kochman
sean(at)stephensville.com
PostPosted: Tue Nov 09, 2010 5:46 am    Post subject: Seat rail alignment issue Reply with quote
Just did the seat plates a few weeks ago. They are not identical, but
rather mirror images of one another. It took me a while to figure out
how they went together, but reading ahead in the plans and seeing how
they are supposed to attach helped.
Check and make sure you made them mirror images as opposed to identical.
-Sean #40303
Carl
To: *rv10-list(at)matronics.com*
Sent: *Tue, Nov 9, 2010 06:30:55 GMT+00:00*
Subject: *Re: Seat rail alignment issue
Thanks...
-Rob
<mailto:owner-rv10-list-server(at)matronics.com>
<mailto:owner-rv10-list-server(at)matronics.com>] *On Behalf Of
*Rob Kochman
*Sent:* Sunday, November 07, 2010 12:40 PM
*To:* rv10-list
*Subject:* Seat rail alignment issue
Thanks...
-Rob
Rob Kochman
Rob Kochman
���~��,�g���M4�G�q���z����.�'�����������������y�J�i��X��ˊ�lN �2���tg�J��a8�DA��l���z�����{�����[�u���–'$�p�ਞ��n�b�yb�Fޖ�-
��v�����i�.� �̞j�z��~'�çˆ�ǧ�+�'��'^t
���%y�k�ơ���i��0����^r��q�&� z���-�'�o�8�u���$��+y�ky��� 0n�u��n�$��&� �)]z���,r��h���[G�چ������h���[azZ\�l0�&y����^��(�����*'����ب�g�J+^����i��0�f����r�(��(���n�b�xm���� &j��',r��r��&�*'�N��*.~����zw���,��h�1�m�������)���������������8E]t.+-f��Z+�`��axƭ���r���^jÛ«z�Z�(�����Ƕ�j|���n�)b�'���!j���'�+����ب��r�y'���C�
å¡§{
����,x(Z�P��!j���ٮr�r��j�|���� &j��',r��5�â�«h�u�m���� ���'���o�j�j�+E]t.+-����������������0�8�Ia�T1
jg���r��z{Z�����i�^�&���lZ+�k�y����+�k&j��',r������+�k&j��',r��h�����������������'��k{��w/�tml=
PostPosted: Tue Nov 09, 2010 9:45 am    Post subject: Seat rail alignment issue Reply with quote
Yes, the plates (I think they're called seat bases in the plans) are not identical--the holes for the side panel attachment need to be on the outside.  The mid seat rail supports (the part that bolts to the gear weldment) are identical.
Thanks...
-Rob
On Tue, Nov 9, 2010 at 5:42 AM, Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)> wrote:
[quote]--> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
Just did the seat plates a few weeks ago.  They are not identical, but rather mirror images of one another.  It took me a while to figure out how they went together, but reading ahead in the plans and seeing how they are supposed to attach helped.
-Sean #40303
On 11/9/10 5:50 AM, carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net) wrote:
Carl
   *From: *Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)>*
   To: *rv10-list(at)matronics.com (rv10-list(at)matronics.com)*
   Subject: *Re: RV10-List: Seat rail alignment issue
   Thanks...
   -Rob
       *From:*owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)
       <mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)>
       <mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)>] *On Behalf Of
       *Rob Kochman
       *To:* rv10-list
       *Subject:* RV10-List: Seat rail alignment issue
       Thanks...
       -Rob
       --         Rob Kochman
   --     Rob Kochman
���~��,� g���M4�G�q���z����.�'�����������������y� J�i��X��ˊ�lN  �2���tg�J�� a 8� DA ��l���z��� ��{�����[�u ���–'$�p�ਞ��n�b�yb�Fޖ�- ��v�����i�.� �̞j� z��~' ��ǧ�+� '��'^t  ���%y�k�ơ���i��0����^r��q�&� z� ��-�' �o� 8 �u�� �$��+y�ky�� � 0n�u��n�$��&� �)]z� ��,r��h ���[G �چ��  ���� h���[azZ\�l0� &y����^��(�����*'����ب�g�J+^����i��0�f����r�(��(���n�b�xm���� &j��',r��r��&�*'�N ��*.~����zw���,��h�1�m ������ �)��������������� 8E]t.+- f��Z+�`��axƭ���r���^j۫z�Z�( �����Ƕ �j|���n�)b�'���!j���'�+����ب��r �y'���C� 塧{ ����,x(Z�P ��!j���ٮr �r ��j �| ���� &j��',r��5��h� uи�� m���� ���'�� �o�j�j�+E]t.+-����������������0 �8� Ia  �T1 jg���r��z{Z�� ���i�^�&���lZ+�k �y�� ��+�k&j��',r���� ��+�k&j��',r��h�����������������'��k{��w/�tml=
_-============================================================
_-=
_-=       -- Please Support Your Lists This Month --
_-=           (And Get Some AWESOME FREE Gifts!)
_-=
_-=   November is the Annual List Fund Raiser.  Click on
