Thruster87
Posted: Mon Nov 08, 2010 11:20 pm Post subject: Wanted First Flight Test Tables/Check-offs |
Hi Would anyone have a print out of a check-list for the first flight testing.Weather permitting will start this weekend.I have copies of the FAA and Chris Heintz first flight textbooks but wanted easy to tick checklist during flight.Getting my local CFI to do the first flights. Cheers Alan
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Tue Nov 09, 2010 3:42 am Post subject: Re: Wanted First Flight Test Tables/Check-offs |
Alan, Here is what I used for my first flight. I did not fill in all the blanks while I was flying since I had a ground crew who could write them down for me. My prime fill-in-the-blanks fields were stall speed and my final approach speed, the other blocks were to remind me to scan the instruments looking for gross errors. That is important since a first flight is a sensory overload experience. I have a Dynon D-180 that logged all of the data for post-flight analysis.
Good luck to you and your CFI!!
 Download |
| Filename: |
1st Flight Test Card.xls |
27.5 KB |
| Downloaded: |
421 Time(s) |
_________________ David Gallagher
Cincinnati, OH area |
a.f.rupp(at)att.net Guest
Posted: Tue Nov 09, 2010 5:38 am Post subject: Wanted First Flight Test Tables/Check-offs |
Alan, In WW's 2009 Corvair Flight Ops Manual Dr. Andy Elliott has an outline of first flight tests I believe are very comprehensive and efficient.
It would give you all the flight information necessary to know the flight characteristics of your airplane, that I would want for a POM, in a very complete and compact format.
Al Rupp
601XL Corvair powered
Sent: Tue, November 9, 2010 2:20:05 AM
Subject: Wanted First Flight Test Tables/Check-offs
Thruster87
Posted: Tue Nov 09, 2010 12:29 pm Post subject: Re: Wanted First Flight Test Tables/Check-offs |
Thanks to everyone, just what I was looking for Cheers Alan
