Fuselink Link 14/10 AWG connection
Harold Lanfear
PostPosted: Fri Nov 05, 2010 6:38 am    Post subject: Fuselink Link 14/10 AWG connection Reply with quote
I’m following Bob’s Z-13/20 circuit and ready to install the 14 AWG fusible link in the 10 AWG feed to the Battery Buss. However, there are no crimp connectors matching both sizes; can I solder this joint or are there better ways? I don’t have spade and socket terminals to match and hate to make a purchase for just a couple of terminals. Thanks much.
Kitfox 660+ Hrs, RV-8 70% done/ 90% to go!
Neal.George(at)hurlburt.a
PostPosted: Fri Nov 05, 2010 7:39 am    Post subject: Fuselink Link 14/10 AWG connection Reply with quote
Harold -
You have several acceptable options. Among them:
1. Solder the 10-ga to 14-ga junctions, support with heat-shrink & cover
with fiberglass tube.
2. Strip the 14-ga wire back twice as far as you normally would and fold
the stripped end back on itself to better fill the 10-ga crimp connector.
Heat-shrink and fiberglass tube as indicated in AEC.
neal
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.09 KB
 Downloaded:  672 Time(s)
PostPosted: Fri Nov 05, 2010 9:15 am    Post subject: Fuselink Link 14/10 AWG connection Reply with quote
Suggest you use a MAX 30 fuse and
mating in-line fuse holder
[img]cid:7.1.0.9.0.20101105120853.01ee94a0(at)aeroelectric.com.0[/img]
available from most big-box auto parts
stores.
 Filesize:  11.95 KB
 Viewed:  11223 Time(s)
pwmac(at)sisna.com
PostPosted: Fri Nov 05, 2010 9:45 am    Post subject: Fuselink Link 14/10 AWG connection Reply with quote
NAPA is now selling the kind Bob likes. They have the double metal
that allows the insulation to be crimped. You need to crimp twice to
get both the wire and the insulation. They pass my pull test and grab
the 1/4" spade plenty hard. Try them before you buy the AMP ones. So
far just red and blue not yellow where I live. Check your store If
they have the yellow you will be good to go with a little heat shrink.
Maybe Bob will give us and evaluation?? HINT.
Paul
At 07:26 AM 11/5/2010, you wrote:
I'm following Bob's Z-13/20 circuit and ready to install the 14 AWG
or are there better ways? I don't have spade and socket terminals
PostPosted: Fri Nov 05, 2010 10:20 am    Post subject: Fuselink Link 14/10 AWG connection Reply with quote
grab the 1/4" spade plenty hard. Try them before you buy the AMP
ones. So far just red and blue not yellow where I live. Check your
store If they have the yellow you will be good to go with a little heat shrink.
Hmmmm . . . do you have a manufacturer and part
number by chance? We might be able to learn a
lot from the manufacturer's data.
pwmac(at)sisna.com
PostPosted: Fri Nov 05, 2010 3:39 pm    Post subject: Fuselink Link 14/10 AWG connection Reply with quote
I am 1000 miles away from my shop, but I have a package of the new
style butt connectors in my truck. NAPA P/N 784331. They are reds
tranlucent plastic and have the extra metal extension. I use several
rachet crimpers and they all give a good result with these things.
Takes 2 crimps with my crimpers to grab theinsulation.
Branded by Balkamp (a NAPA house brand). Made In Taiwan
The other stuff in my truck are the cheepe 3M automotive stuff you
are fanmiliar with and they will not grab the insulation. However
they do give the soild crimp like your AMP tests.
Mabe the attached pic will reveal something?
At 11:17 AM 11/5/2010, you wrote:
<nuckolls.bob(at)aeroelectric.com>
>to get both the wire and the insulation. They pass my pull test and
 Filesize:  41.42 KB
 Viewed:  11216 Time(s)
PostPosted: Sat Nov 06, 2010 5:38 am    Post subject: Fuselink Link 14/10 AWG connection Reply with quote
Hmmm . . . are these normally stocked in the stores
or do they have to order them in? Are they available
in less than full box lots?
pwmac(at)sisna.com
PostPosted: Sat Nov 06, 2010 6:16 am    Post subject: Fuselink Link 14/10 AWG connection Reply with quote
Stock item in Durango CO store. Stock from the Albuerque warehouse.
Find then on the shelf. no need to ask at the desk.
Paul
>several rachet crimpers and they all give a good result with these
>things. Takes 2 crimps with my crimpers to grab theinsulation.
PostPosted: Sat Nov 06, 2010 8:45 am    Post subject: Fuselink Link 14/10 AWG connection Reply with quote
Paul
I'll see if I can pick some up. I'm going to Wichita
tonight.
eschlanser
PostPosted: Fri May 24, 2013 2:03 pm    Post subject: Re: Fuselink Link 14/10 AWG connection Reply with quote
Did you ever pick up some of these and/or check the manufacturer's data? Wondering if they really are the "right stuff".
Eric S.
Paul
tonight.
PostPosted: Sat May 25, 2013 12:10 pm    Post subject: Fuselink Link 14/10 AWG connection Reply with quote
At 05:03 PM 5/24/2013, you wrote:
Eric S.
Man . . . that's been awhile. I had to stop
in several NAPA stores before I found any
butt splices and then they were similar but
a different part number. I think they were okay
in performance. It's been so long ago I don't
recall.
There's a bunch of PIDG alternatives out there,
many are adequate to the task. It would be difficult
to evaluate a bunch of PIDG wannabe parts and
attempt to sprinkle any sort of holy-water on
them. That could crank up a never ending task!
I think it's pretty clear what we expect of our
non-insulated and pre-insulated terminals for
performance. We've discussed the fact that a
useful study mates wires, terminals and tools.
There's some illustrated discussions on the website.
I think the best general rule of thumb I can offer
is to do your own tear-down of the as-applied
terminal and see how the two metals come together
and how well the insulation is gripped without
'squashing' it.
I use a Dremel tool cut-off wheel to section
the wire grip. Polish the cut-line with 800 wet-or-
dry paper. I have a 40X binocular inspection
'scope through which I can evaluate the work-
product and take pictures. There are dozens of
really reasonable illuminated, pocket microscopes
on ebay . . .
http://tinyurl.com/py6x8uq
that would be quite adequate for getting up
close and personal with the 'mash'. With a few
simple tools and a lot of curiosity, you can
easily deduce suitability to task for a variety
of wire/terminal/tool combinations.
