Knife blade connectors
Kellym
PostPosted: Mon Nov 01, 2010 7:07 pm    Post subject: Knife blade connectors Reply with quote
Heard recently an allegation that this type of connector may no longer
be allowed on certified aircraft. Old wives tale or is there some
substance? I've learned to take 43-13 with a grain of salt, so figured
would ask the experts first.
Kelly
Kelly McMullen
KCHD
Neal.George(at)hurlburt.a
PostPosted: Tue Nov 02, 2010 4:23 am    Post subject: Knife blade connectors Reply with quote
News to me, Kelly,
Where'd you hear that?
neal
<kellym(at)aviating.com>
Kelly
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.09 KB
 Downloaded:  320 Time(s)
Kellym
PostPosted: Tue Nov 02, 2010 4:50 am    Post subject: Knife blade connectors Reply with quote
Another mail list, attributed to old crusty A&P/IA. I like those old
connectors, so wanted to be sure it was not based in anything official.
On 11/2/2010 5:17 AM, George, Neal E Capt USAF ACC 505 TRS/DOJ wrote:
News to me, Kelly,
neal
Kelly
Kelly McMullen
KCHD
PostPosted: Tue Nov 02, 2010 10:16 am    Post subject: Knife blade connectors Reply with quote
At 10:01 PM 11/1/2010, you wrote:
--> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com>
Heard recently an allegation that this type of connector may no longer be allowed on certified aircraft. Old wives tale or is there some substance? I've learned to take 43-13 with a grain of salt, so figured would ask the experts first.
There's a lot of confusion between what is "allowed" and
that which is no longer "common practice". As a general rule,
the folks-who-know-more-about-airplanes-than-we-do
will not indulge themselves in bans on specific products
unless they're involved in a safety of flight issue.
We've always had an interest in fabricating one-wire,
'serviceable' splices in certain wires. If one wanted
to avoid installing a one-pin connector, then some form
of breakable splice was called for. For the three weeks
I spent on the Cessna 310/320 assembly line, I installed
a bucket-full of "wrist-locks" . . .
[img]cid:.0[/img]
In other venues, the knife-splice was favored . . .
[img]cid:.1[/img]
Both technologies were covered with an insulating sleeve
secured in the center with a tie of string. Today, one might
use heat-shrink. Both technologies offer a tug-resistant
splice with good integrity.
When I left Hawker-Beech, these technologies had been replaced
in production for many years. Powers that be favored a line
of one-pin connectors. These were plastic housings with a
double-ended female connector molded in. A splice as achieved
by crimping the appropriate male pin on both wires and
seating them into the double-female housing.
It was fairly compact, used tools and pins commonly used
all over the airplane . . . and could be opened by simply
extracting one of the two pins with the appropriate tool.
MUCH more expensive for materials . . . a toss-up I think
for labor . . . but it IS the latest and greatest.
In the mean time, there's nothing 'wrong' with knife-
spices or wrist-locks if they meet your design goals.
 Filesize:  47.56 KB
 Viewed:  2472 Time(s)
 Filesize:  73.4 KB
