Robin Marks
Joined: 10 Jan 2006 Posts: 24 Location: San Luis Obispo, CA
Posted: Wed Jan 11, 2006 3:50 pm Post subject: EZ Pilot Autopilot |
Dear List,
I am unimpressed with my Navaid Autopilot and I am thinking
of swapping it out with an EZ Pilot ( www.trioavionics.com
<http://www.trioavionics.com/> ). It is that it is a direct replacement
interfacing with the Navaid servo. Probably telling the list what it
already knows. I will be hooking this up to a Garmin 250XL GPS/Com and a
Garmin 296 GPS. I would like to get feedback from the list to make sure
the EZ Pilot is a good unit worth installing.
Robin
RV-6A 240 hours
_________________ RV-4 Sold
RV-6A 0-360 - C/S Flying |
sportav8r(at)aol.com Guest
Posted: Wed Jan 11, 2006 6:28 pm Post subject: EZ Pilot Autopilot |
Robin- I'm quite happy with mine in the RV, both the EZ pilot and the altitude hold. You are correct about direct interface with Navaid roll servo.
shempdowling2(at)earthlin Guest
Posted: Wed Jan 11, 2006 7:33 pm Post subject: EZ Pilot Autopilot |
Are you sure you have the NavAid set up correctly? I have no qualms about
mine. I flick the switch to tk and it follows my gps course very closely,
including turns.
Shemp/Jeff Dowling
RV-6A, N915JD
235 hours
Chicago/Louisville
sbuc(at)hiwaay.net Guest
Posted: Wed Jan 11, 2006 8:09 pm Post subject: EZ Pilot Autopilot |
martin(at)gbonline.com Guest
Posted: Wed Jan 11, 2006 8:14 pm Post subject: EZ Pilot Autopilot |
Robin,
Consider a TRUTRAK. It will interface with the Navaid servo. You can order
it without the servo at a lower price. It is far superior to the TRIO imho.
Dick Martin
N233M RV8
Trutrak test pilot
Robin Marks
Posted: Wed Jan 11, 2006 10:21 pm Post subject: EZ Pilot Autopilot |
I actually did do my first search in the archives BEFORE requesting info
from the list. I guess my search skills match my autopilot skills.
Robin
Steve Glasgow
Posted: Thu Jan 12, 2006 2:29 am Post subject: Re: EZ Pilot Autopilot |
Robin,
I just installed my EZ pilot and love it. I had the Navaid and there is no comparison.
_________________ Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG |
luckymacy(at)comcast.net Guest
Posted: Thu Jan 12, 2006 7:13 am Post subject: EZ Pilot Autopilot |
dick martin wrote:
Robin,
Dick Martin
N233M RV8
Trutrak test pilot
Dick,
No doubt anyone with field experience with the new digital autopilots
will agree that TruTrak makes very nice equipment. Matter of fact, I fly
their AlTrak and it is superb in regard to doing what it is advertised
to do.
I am, however, intrigued by your opinion concerning the DigiTrak being
"far superior" to the EZ-Pilot. Since the EZ-Pilot offers much more in
the way of display information presented to the pilot than the DigiTrak,
there must be something in the way the DigiTrak performs in-flight that
compels you to make this assertion. I am very interested in hearing your
comments in this regard.
Since the EZ-Pilot in my RV-6 performs precisely as advertised, the
DigiTrak must be capable of some extraordinary performance. For the sake
of all us who are attempting to keep up with the advances in digital
autopilots, please provide your input as to how you have found the
DigiTrak to be far superior to the EZ-Pilot (and I suppose all other
systems since the digital units will out-perform analog systems) in
side-by-side comparisons.
Thank you in advance for your reply,
Sam Buchanan
Ollie Washburn
Joined: 10 Jan 2006 Posts: 56 Location: Central Florida
Posted: Thu Jan 12, 2006 7:32 am Post subject: EZ Pilot Autopilot |
I swapped my nav-aid head for the EZ-pilot and it has worked
perfectially. Before I was never sure which way the plane would go when I
turned the autopilot on. They are great people to work with and at S & F
they came out to my plane to try and help me figure out why it would not
couple with GPS, end result I needed one more wire coming from GPS.
Ollie Central Fl.
[quote] [Original Message]
To: <rv-list(at)matronics.com>
Date: 1/11/2006 9:19:50 PM
Subject: Re: EZ Pilot Autopilot
Robin-
I'm ve
_________________ Ollie RV6-A & Rans S7S
Central FL |
cweyant(at)chuckdirect.co Guest
Posted: Thu Jan 12, 2006 12:39 pm Post subject: EZ Pilot Autopilot |
Me too, I love my NavAid !
tomvelvick
Posted: Thu Jan 12, 2006 12:53 pm Post subject: Re: EZ Pilot Autopilot |
Hi Robin,
My EZ Pilot handles turbulence a lot better than the Navaid. I had to hand fly the RV in more than real light turbulence. The Navaid would get behind and cause some wild wing drops. The EZ Pilot does a way better job in turbulence and I let it fly the plane most of the time. I also find myself using the gps data on it instead of the gps so I turned the data windows off on the gps to give myself more room on the gps screen for the moving map. (Garmin GPS III Pilot). Got a Garmin 296 for Xmas so may change that when I get it mounted. The EZ pilot uses the NMEA data from the GPS instead of a plus/minus 50 millivolt analog signal that the Navaid uses so it knows a lot more about where you are and turns the correct way to intercept the course. The adjustments are all done in software on the unit, no little screws to turn like on the navaid. The EZ pilot almost always tracks within 0.00 to 0.02 miles of the course. This is way better than I could get with the Navaid. I also like the course offset feature so I can fly 1/4 mile for example to the right of the course centerline. I dont have the latest software updates so probably missing out on some of the new features but I think it is definately worth upgrading from the Navaid. Mine also included a patch cable to go between the EZ pilot head and the old cable to the Navaid Head. Just had to add a couple of wires to it, I believe so it was a real easy swap.
Tom Velvick
N53KT RV-4
N7053L RV-4
RV-6a canopy and wiring
| Robin Marks wrote: |
Dear List,
Robin
RV-6A 240 hours |
Charles Heathco
Posted: Thu Jan 12, 2006 4:39 pm Post subject: EZ Pilot Autopilot |
I have both the EZ pilot and the EZ-1 alt hold installed. Ez pilot is hooked to 296. I had some problems getting them going, but support was very good, and they work as advertised. The wiring for the Alt hold definatly requires some skill, but the EZ pilot has a mounting kit and wiring kit availible, Charlie Heathco (RV6a)
Posted: Fri Jan 13, 2006 5:15 am Post subject: EZ Pilot Autopilot |
Glad you ended up happy with yours, Charlie. I am with mine, too. C'mon, the Alt Hold wiring wasn't all that bad. It was the mounting bracket that took some puzzling out and some crawling around on the old belly
As I told Sid, the A/H was difficult to calibrate, since the vibe level in my stick from the engine made it impossible to feel the servo pulses I was supposed to tune out, so I ended up at factory defaults and it seems happy.
-Stormy
SSampson.SLN21(at)london. Guest
Posted: Fri Jan 13, 2006 10:19 am Post subject: EZ Pilot Autopilot |
I have followed this thread with interest.
The one thought I have is of the three units discussed (Tru track / Ezi /
Navaid) the true track servos look to be of a much better quality. I have
only handled the Navaid servo, which from pictures looks as though it is
common to the Ezi. It always appeared not too robust.
Anyone care to comment?
Thanks, Steve.
PS Do these companies make these servos themselves?.
Posted: Fri Jan 13, 2006 11:33 am Post subject: EZ Pilot Autopilot |
Steve Sampson wrote:
Thanks, Steve.
The TruTrak servo is indeed a nice looking and hefty unit. It uses a
stepping motor instead of a linear motor and clutch. However, I have
heard that a new version of this servo is in the works that has a clutch.
The Navaid servo is much lighter than the TruTrak and based on analog
technology that has been around for many years. In spite of its dated
appearance and light weight, the servo has an excellent field history in
service with both Navaid control heads and more recently with the
EZ-Pilot heads. This servo incorporates a clutch that releases the gear
train when power is removed from the servo.
Trio is shipping their new servo with their altitude hold devices and it
is a dandy both mechanically and electronically. This state-of-the-art
servo is the only one that includes an accelerometer *in the servo* that
is an integral part of the fail-safe system. The servo and control head
constantly poll each other, and if an argument can't be settled, the
system releases the servo. If the servo independently sees a high G load
from its built-in accelerometer, it will deactivate. As far as I know,
this is the only system that provides the servo with enough brains to
independently disconnect in an emergency without being commanded by the
control head. I suspect this new servo will eventually find its way into
the entire Trio product line.
Hope this info helps with understanding the various options. With the
exception of the Navaid servo used on the EZ-Pilot and the Navaid
version of the DigiTrak, as far as I know the other servos are produced
by the respective companies. I am not an employee of any autopilot
company, just a very interested bystander and customer of both Trio and
TruTrak.
Sam Buchanan
Posted: Fri Jan 13, 2006 2:03 pm Post subject: EZ Pilot Autopilot |
Sam Buchanan wrote:
| Quote: | Trio is shipping their new servo with their altitude hold devices and it
<snip>
I just received word from Trio that they have been shipping their new
Gold Standard servo (the one discussed above) with the EZ-Pilot since
about 45 days ago.
I looked inside one of these servos at OSH and the engineering and
materials look first class; should be a worthy component for their
excellent autopilots.
Sam Buchanan
don.wentz(at)intel.com Guest
Vanremog(at)AOL.COM Guest
Posted: Fri Jan 13, 2006 9:12 pm Post subject: EZ Pilot Autopilot |
In a message dated 1/13/2006 3:11:10 P.M. Pacific Standard Time,
don.wentz(at)intel.com writes:
With all this talk about selling of Navaids to buy other autopilots, any
of you selling the Navaids cheap?
Mine works great (compared to what I had before - nothing and I have
a friend with an RV-4 without even a T&B that would advance light years
with a 'crappy old Navaid' wing leveler.
I'm down with the Duck Dude on this one. My old vintage '97 Navaid has
worked fine since day one and, aside from the fact that it doesn't have an
altitude hold option (the Pig Dude never come thru on this one), I am generally
happy with it.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 771hrs, Silicon Valley, CA)
chaztuna(at)adelphia.net Guest
Posted: Sat Jan 14, 2006 8:01 am Post subject: EZ Pilot Autopilot |
Sam,
You you explain to me what a "stepper" motor is and how it differs?
Charlie Kuss
snipped
| Quote: | The TruTrak servo is indeed a nice looking and hefty unit. It uses a
snipped
