Ray Allen Pushbutton Wiring Question
marty.santic(at)gmail.com
PostPosted: Wed Oct 27, 2010 7:18 am    Post subject: Ray Allen Pushbutton Wiring Question Reply with quote
The wire supplied with the Ray Allen microphone PTT grip is very small.  I would say it is #28 or #30.  What is a good butt-splice to use for this application.
Marty Santic
MNellis
PostPosted: Wed Oct 27, 2010 9:24 am    Post subject: Ray Allen Pushbutton Wiring Question Reply with quote
For wire that small a butt splice would not be apprpriate. Instead, soldering the wires together covered by heat shrink might be a better alternative.
[quote]The wire supplied with the Ray Allen microphone PTT grip is very small. I would say it is #28 or #30. What is a good butt-splice to use for this application.
Marty Santic
Mike Nellis
RV6 Fuselage
sprocket(at)vx-aviation.c
PostPosted: Wed Oct 27, 2010 9:52 am    Post subject: Ray Allen Pushbutton Wiring Question Reply with quote
Alternatively, use male and female crimp pins for a D-Sub connector and heat shrink them together.
Sent: Wednesday, October 27, 2010 10:18 AM
Subject: Re: Ray Allen Pushbutton Wiring Question
Marty Santic
Release Date: 10/27/10 06:34:00
rparigoris
PostPosted: Wed Oct 27, 2010 10:16 am    Post subject: Re: Ray Allen Pushbutton Wiring Question Reply with quote
You could also use solder type D-sub connectors with heat shrink.
I used the High Density 3 row D-sub connectors from Radio Shack modified to fit inside my stick.
See last 3 pics:
http://www.europaowners.org/forums/gallery2.php?g2_itemId=31671
Ron Parigoris
simon(at)synchdes.com
PostPosted: Wed Oct 27, 2010 11:15 am    Post subject: Ray Allen Pushbutton Wiring Question Reply with quote
These PICABOND butt splices are made by Tyco for the telephone cable
industry. I have the part drawing PDF if anyone needs it.
Digi-Key pn 61899-1-ND, Tyco connector butt splice, 24-28 AWG, orange,
61899-1, $.21 each
http://parts.digikey.com/1/parts/1914216-conn-splice-butt-24-28awg-orange-61899-1.html
Simon Ramirez
LEZ N-44LZ
Oviedo, FL USA
*Sent:* Wednesday, October 27, 2010 10:18 AM
*To:* aeroelectric-list(at)matronics.com
<mailto:aeroelectric-list(at)matronics.com>
*Subject:* Re: Ray Allen Pushbutton Wiring Question
alternative.
Marty Santic
mrspudandcompany(at)veriz
PostPosted: Wed Oct 27, 2010 11:44 am    Post subject: Ray Allen Pushbutton Wiring Question Reply with quote
61899-1, $.21 each
899-1.html
Simon Ramirez
Simon,
Do these splices require a special crimping tool? At what
price?
Roger
winmail.dat
 Filename:  winmail.dat
 Filesize:  3.43 KB
 Downloaded:  651 Time(s)
PostPosted: Wed Oct 27, 2010 12:57 pm    Post subject: Ray Allen Pushbutton Wiring Question Reply with quote
Solder and heat-shrink. See:
http://aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html
