graeme bird
Posted: Thu Oct 21, 2010 12:36 am Post subject: Rotax fuel flow detection |
Just sorting the fuel system on my new build. I am considering including an RS type flow sensor for future use but what confuses me on the 912 install is that some of the fuel comes back which would make the reading useless unless a return sensor was also fitted. This is the reason my fuel calculator in my C42 is worse than useless. Any advice appreciated.
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
peter.rees01(at)tiscali.c Guest
Posted: Thu Oct 21, 2010 1:23 am Post subject: Rotax fuel flow detection |
Could be wrong but I don't think that the LAA allow the RS fuel flow
sensor to be used because of the danger of blockage. I think that the
Flowscan units are the suggested route (I think that Parts for Aircraft
is a good UK source - cheaper in the US if you can be bothered to save
a few quid) - quite a bit more money than the RS unit but not as much
as putting the aeroplane down in a field.
----Original Message----
Date: 21/10/2010 9:36
To: <europa-list(at)matronics.com>
Subj: Rotax fuel flow detection
appreciated.
Graeme Bird
http://forums.matronics.com/viewtopic.php?p=316546#316546
_-
Posted: Thu Oct 21, 2010 1:51 am Post subject: Rotax fuel flow detection |
Floscan is the best transducer, it uses an infra red sensor so is not susceptible to magnetic interference. Unlikely to block, the hole is larger than anything that would get throuhg your filter. Look for it on marine or automotive markets. Non certified units are the same but cheaper. My Grand Rapids monitor uses the Floscan and the do sell them separately.
Graham
From: "peter.rees01(at)tiscali.co.uk" <peter.rees01(at)tiscali.co.uk>
Sent: Thursday, 21 October, 2010 10:14:43
Subject: Re: Rotax fuel flow detection
--> Europa-List message posted by: "peter.rees01(at)tiscali.co.uk (peter.rees01(at)tiscali.co.uk)" <peter.rees01(at)tiscali.co.uk (peter.rees01(at)tiscali.co.uk)>
From: graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)
To: <europa-list(at)matronics.com (europa-list(at)matronics.com)>
--> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
appreciated.
Graeme Bird
_-
ref="http://www.matronics.com/Navigator?Europa-List" target="_blank">ht - sp; -Matt Dralle, List Adm========
milneab(at)btinternet.com Guest
Posted: Thu Oct 21, 2010 2:41 am Post subject: Rotax fuel flow detection |
The Europa Club have a standard LAA approved mod for the addition of a fuel
flow transducer that allows for the return flow including type of
transducer, schematic and installation requirements. See the Club website.
Alasdair Milne (Secy Europa Club)
air.guerner(at)orange.fr Guest
Posted: Fri Oct 22, 2010 3:27 am Post subject: Rotax fuel flow detection |
Hi Alasdair,
I cannot find this Mod on the Club website. Could you help please?
Remi Guerner
<<<<<<The Europa Club have a standard LAA approved mod for the
addition of a fuel
website.
Alasdair Milne (Secy Europa Club)>>>>>>>>
g-iani(at)ntlworld.com Guest
Posted: Fri Oct 22, 2010 4:51 am Post subject: Rotax fuel flow detection |
Remi
The mod is an LAA Standard Mod 12209 (on the LAA site). I have attached a
copy for you
It will be on the Europa Club site when we get it sorted out
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
 Download |
| Filename: |
12209_Fuel_Flow.pdf |
236.79 KB |
| Downloaded: |
1525 Time(s) |
Posted: Fri Oct 22, 2010 9:56 am Post subject: Rotax fuel flow detection |
Thank you Ian for posting the LAA mod.
I have not installed a fuel flow in my aircraft but if I had to, I
would use the attached schematic which allows measuring the flow to
the carbs with a single sensor, therefore improving accuracy and
reliability and reducing cost.
The same principle can be used for the 914. In that case the single
flow sensor would be installed between the pressure regulator and the
carbs.
Remi Guerner
F-PGKL
72.09 KB |
8719 Time(s) |
kheindl(at)msn.com Guest
Posted: Fri Oct 22, 2010 12:09 pm Post subject: Rotax fuel flow detection |
Remi,
I tried just that. It does not work. The fuel flow at that point is not smooth and you get very erratic readings. Only John Wigney managed to get it to work with a pulsation damper.
I tried that too, but with little improvement. So I will also have to buy another Floscan transducer. The price at ACS is as good or as bad as any.
Karl
| Quote: | From: air.guerner(at)orange.fr
Subject: Rotax fuel flow detection
Date: Fri, 22 Oct 2010 19:53:24 +0200
carbs.
Remi Guerner
F-PGKL
jan_de_jong(at)casema.nl Guest
Posted: Fri Oct 22, 2010 4:53 pm Post subject: Rotax fuel flow detection |
There is information in the total flow from the pump(s).
Jos O. once mentioned that one of his pre-flight checks was a total
forward flow of 120 l/h or so (Rotax 914). Anything less would be an
early sign of trouble.
Jan de Jong
Guerner Remi wrote:
carbs.
Remi Guerner
F-PGKL
Posted: Sat Oct 23, 2010 12:48 am Post subject: Rotax fuel flow detection |
Svein,
I basically agree with what you wrote. However my proposed schematic
is very close to the one recommanded (and optionally supplied) by
Rotax in the 912 Install Manual (see attached). This arrangement works
on most LSAs so I do not see why it would not work with the addition
of the fuel flow sensor as propsed.
Remi Guerner
<<<<<<At first sight, your proposal may look like the obvious
solution. With
respect, however, I think it is not to be recommended for 912ULS
installations (I do not know enough about 914 to comment on that
engine).
Contrary to what seems to be a common assumption, the return flow
through
the restrictor is not insignificant - it is roughly 10 litres per hour
(i.e.
roughly half of the net cruise consumption, or roughly 1/3 of the fuel
going
to the engine is flowing back to the tank). The reason for this
relatively
high surplus circulation is of course to reduce the time the fuel is
exposed
to heat before it reaches the carbs, by increasing the flow velocity
through
the fuel line. According to the build manual, the return line
branches off
at the point farthest from the pump, just before the left side carb
(assuming the fuel line goes from the pump to the right side of the
engine
with a short branch off to the right carb, and from there across the
back of
the engine to the left carb).
Moving the return line branch-off upstream (closer to the pump)
increases
the risk of vapour forming in the fuel lines downstream from this
branch-off
point. By how much, I do not know, but maybe it is critical under
unfavourable circumstances. "Maybe's" under the cowling are not nice
 Download |
| Filename: |
912_fuel_system_-_Rotax_IM.pdf |
78.31 KB |
| Downloaded: |
417 Time(s) |
europapa
Posted: Wed Oct 27, 2010 12:21 pm Post subject: Rotax fuel flow detection |
I will too install a fuel computer this winter to my 912s.
In the manual of my FC1 Flybox is a schematic I will post here
and I canīt see why it shoud not work.
Even measuring the fow of only one carb it should be no problem to find the right k-faktor setting.
[img]cid:part1.07050804.01050908(at)onlinehome.de[/img]
Am 23.10.2010 10:44, schrieb Guerner Remi: | Quote: | Svein,
I basically agree with what you wrote. However my proposed schematic is very close to the one recommanded (and optionally supplied) by Rotax in the 912 Install Manual (see attached). This arrangement works on most LSAs so I do not see why it would not work with the addition of the fuel flow sensor as propsed.
Remi Guerner
<<<<<<At first sight, your proposal may look like the obvious solution. With
installations (I do not know enough about 914 to comment on that engine).
Contrary to what seems to be a common assumption, the return flow through
the restrictor is not insignificant - it is roughly 10 litres per hour (i.e.
roughly half of the net cruise consumption, or roughly 1/3 of the fuel going
to the engine is flowing back to the tank). The reason for this relatively
high surplus circulation is of course to reduce the time the fuel is exposed
to heat before it reaches the carbs, by increasing the flow velocity through
the fuel line. According to the build manual, the return line branches off
(assuming the fuel line goes from the pump to the right side of the engine
with a short branch off to the right carb, and from there across the back of
Moving the return line branch-off upstream (closer to the pump) increases
the risk of vapour forming in the fuel lines downstream from this branch-off
unfavourable circumstances. "Maybe's" under the cowling are not nice - - -
27.32 KB |
8686 Time(s) |
