engine mount plans rotax ring type
graeme(at)coletoolcentre.
PostPosted: Wed Oct 20, 2010 8:19 pm    Post subject: engine mount plans rotax ring type Reply with quote
does any one have a drawing for a rotax ring mount to fire wall with tube
diameter and thickness.
and the isolastic mount used.
I am going to fabricate one for my CH701
graemecns
ricklach
PostPosted: Thu Oct 21, 2010 6:37 am    Post subject: Re: engine mount plans rotax ring type Reply with quote
That is a very hard mount to make if your thinking of duplicating the factory mount. The clearances are very tight and the bending process is painful. I manufacture an exact copy of the Rotax mount at a much better price if you decide to buy rather than build.
Rick
rick(at)ravenaviation.us
701Driver
N35 26.700, W118 16.743
PostPosted: Thu Oct 21, 2010 2:07 pm    Post subject: engine mount plans rotax ring type Reply with quote
Hi Rick
I do have the rotax ring mount.
I am going to build the rotax ring to the firewall mount?
Thanks Graemecns
ricklach
PostPosted: Fri Oct 22, 2010 7:14 am    Post subject: Re: engine mount plans rotax ring type Reply with quote
Hi Graemecs,
I never got a drawing with my 701 plans for the ring mount to firewall mount. I haven't asked Zenith about it either, guess I should. But if you find out anything or track down a drawing please let me know as I need to build one too.
Rick
701Driver
PostPosted: Sat Oct 23, 2010 2:03 am    Post subject: engine mount plans rotax ring type Reply with quote
I haven't asked zenair recently but a year ago they didn't have one.
I will try them again.and post here if I get one.
Other wise I may have to become a pioneer and design and build my own not
the ideal solution
Graemecns
ricklach
PostPosted: Sat Oct 23, 2010 7:19 am    Post subject: Re: engine mount plans rotax ring type Reply with quote
The last time I spoke with Zenith there logic was that the Ring mount was a Rotax Item and the mount from the firewall to the ring mount was part of their firewall forward package. I would think it should be part of the drawing package for scratch builders. I wasn't ready for it so I never pushed the point.
Good Luck.
701Driver
craig(at)craigandjean.com
PostPosted: Sat Oct 23, 2010 8:25 am    Post subject: engine mount plans rotax ring type Reply with quote
FWIW the 601XL main plans include 4 different mounts: Jabiru 3300,
Continental O-200, Lycoming O-235 conical and dynafocal.
-- Craig
dougsnash
PostPosted: Sat Oct 23, 2010 6:39 pm    Post subject: engine mount plans rotax ring type Reply with quote
This might not be that answer anybody is looking for but...
Has anyone gotten a price from Zenith for their portion of the mount? I know that the Rotax portion is outrageous but it has been my experience that Zenith's prices for the parts they build are usually pretty reasonable.
Doug MacDonald
CH-701 C-GBQX
NW Ontario, Canada
<rick(at)ravenaviation.us>
Ring mount was a
mount was part of
part of the
so I never
pushed the point.
Good Luck.
701Driver
PostPosted: Sun Oct 24, 2010 12:49 am    Post subject: engine mount plans rotax ring type Reply with quote
Hi I have sent the question to zenair again so will see there latest
response.
Graemecns
ricklach
PostPosted: Sun Oct 24, 2010 7:16 am    Post subject: Re: engine mount plans rotax ring type Reply with quote
Your right Doug, the price for the Rotax portion is outrages at more than $1100. That is why I started making them for other guys and I only charge $500 for my mount. I just never got around to making the mount between the firewall and the engine. I'm now getting to that point so I need a drawing or something to make that mount.
Here is a picture of my Ring Mount.
Rick
 Filesize:  23.24 KB
 Viewed:  11848 Time(s)
701Driver
