tc1917(at)bellsouth.net Guest
Posted: Mon Oct 18, 2010 1:46 am Post subject: plugs |
It is a real shame that John had a problem with the V plug. I used them for
years and got over a hundred hours on them before I changed them just for
the hell of it. I also used the platnum and paladiums which were really,
really expensive. The old 447 and then the 582 I used them on started
easier and ran smoother than the crappy standard big electrode plugs that
they say have to be changed every 25 hours. I put a whole set of 8 plugs in
my car engine one time and 7 (seven) of the plugs were bad. Dont use that
brand again but never heard of anyone else having the trouble. Cant fault a
whole lot for one plug although if I would have had the failure, I probably
would not use them again but that dont mean much. I learned a long time ago
"just because something is new, dont mean it is any good'. Ted Cowan,
Slingshot, 912 ul, zoom zoom.
Posted: Mon Oct 18, 2010 9:05 am Post subject: plugs |
| Quote: | It is a real shame that John had a problem with the V plug. I used them
for years and got over a hundred hours on them before I changed them just
for the hell of it. Ted Cowan, Slingshot, 912 ul, zoom zoom.
Ted C/Gang:
Yep, I agree with you. It was a shame.
I paid big dollars for the BR8EV's, trying to make the FS and 447 as bullet
proof as possible. Back then, dollars were scarce as hen's teeth. Figured
I had a lot better chance of not fouling a plug with the BR8EV's than the
BR8E's.
What I did not realize was the tip of the electrode was fused on. I got a
bad one that separated and grounded that plug when it lodged between the
ground strap and the electrode. When you lose a cylinder on a 447 you are
only going one way, down.
I spent 4 or 5 days in Niagara Falls working on the FS to get it flyable
enough to make it back to Alabama. It wasn't pretty when we finished, but
it was flyable. I was really happy to take off from Niagara International
and head south.
A young man by the name of Mike Fehlin befriended me the day I tore up my
airplane. Mike heard a radio interview with me telling how I had crashed on
Grand Island and torn up my airplane. That I needed help to get it repaired
enough to get back to Alabama. Five minutes later he introduced himself to
me in that weed field on Grand Island. He went into Niagara and got a large
U-Haul truck, helped me take the wings off the FS and load the aircraft. He
knew this man at the airport that built experimental aircraft, contacted
him, and we took the FS to his hanger to repair. I would have been in
serious trouble without these two fine gentlemen. Mike was also responsible
for getting me a room in a local truck stop that did not cost an arm and a
leg. He also picked me up every morning, took me to the airport, and then
returned me to the truck stop each night. I could never repay him for all
he did.
BTW: It was 37F this morning at the Rock House. It will be in the mid-60's
soon. Beautiful weather and good friends are hard to beat.
Rock House, Oregon
_________________ John Hauck
Titus, Alabama |
russkinne(at)mac.com Guest
Posted: Mon Oct 18, 2010 2:36 pm Post subject: plugs |
Ted
Thanx for your input about plugs. Were the 7 bad ones massive-
electrode types?
Regards to ole zoom-zoom,
Russ K
On Oct 18, 2010, at 5:44 AM, Ted Cowan wrote:
them for years and got over a hundred hours on them before I
changed them just for the hell of it. I also used the platnum and
paladiums which were really, really expensive. The old 447 and
then the 582 I used them on started easier and ran smoother than
the crappy standard big electrode plugs that they say have to be
changed every 25 hours. I put a whole set of 8 plugs in my car
Cant fault a whole lot for one plug although if I would have had
the failure, I probably would not use them again but that dont mean
much. I learned a long time ago "just because something is new,
dont mean it is any good'. Ted Cowan, Slingshot, 912 ul, zoom zoom.
Posted: Tue Oct 19, 2010 2:16 am Post subject: plugs |
dont recall what type of plugs they were now. I usually buy AC now. I just
rebuilt a 440 and went to start it up and I guess I gas fowled them and they
never dried up. Bad when you are starting a new built engine of any type.
You dont know for sure what is wrong and dont suspect ALL the plugs went
bad. I have had a bunch of the big electrodies go bad on me until I changed
to V types, etc. I have had three bad plugs on my 912 so far in two
changes. That hurts at the price and you cant send them back. Got over
three hundred hours on the 912 and still purrs. Just still has that damned
rum rum. Hope to be at Evergreen this weekend. Just got back from Bimini
diving, been home for a week and ready to get away again -- this time by
air. Ted Cowan, Slingshot, 912ul, zoom, zoom.
