JSMcGrew(at)aol.com Guest
Posted: Sat Apr 29, 2006 4:28 am Post subject: Torque Wrench Extension |
I just came across a great idea that I want to share with the group. There are a few times that a torque wrench won't fit on the nut/bolt (namely engine mounting bolts, prop nuts, supporting the starter/alternator wires on the engine case). Instead of purchasing expensive extensions or welding something up I found that if you take an ordinary combination wrench and put a bolt/nut with washers through the closed end you have a perfect extension. And you get to keep your wrench intact. See photo below.
You'll need to set your torque wrench to the appropriate setting when using an extension. If you don't trust yourself with a calculator here's a website that will do the math for you:
http://www.norbar.com/torquewrenchextensioncalculator.php
This is too easy, but I struggled with a few of these before I came across this idea, so I figure it's worth sharing.
Jim McGrew
#40134 - Fire Wall Forward
41.31 KB |
593 Time(s) |
Tim(at)MyRV10.com Guest
Posted: Sat Apr 29, 2006 4:57 am Post subject: Torque Wrench Extension |
Jim, that is a genius idea! I cobbled something together when
I did my prop bolts, and used an online torque calculator to
verify my own calculations on torque, but this wrench extension
is pure genius compared to what I did. I'm going to put this
directly into the tips section on my site for permanent viewing
and for those who only get the daily digest.
http://www.myrv10.com/tips/generaltips.html
JSMcGrew(at)aol.com wrote:
| Quote: | I just came across a great idea that I want to share with the group.
Jim McGrew
jesse(at)itecusa.org Guest
Posted: Sat Apr 29, 2006 5:39 am Post subject: Torque Wrench Extension |
That’s a great idea.
I have one issue with this website. It has you input the length of your existing torque wrench, then the length with the extension. I understand wanting to know the length from the center of the drive to the break-away point, but what in the world difference can the length of the handle mean? Does it really make a different torque value if you grab the handle at the end or “choke up” to the head? Am I really missing something huge here?
Also, I heard from an A&P school that if you put the extension at 90 degrees, then the torque value on the wrench is accurate, but then, of course, you can’t use the racheting feature of the torque wrench, or you will lose your 90 degrees.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JSMcGrew(at)aol.com
Sent: Saturday, April 29, 2006 7:27 AM
Subject: Torque Wrench Extension
Jim McGrew
41.31 KB |
478 Time(s) |
Kellym
Posted: Sat Apr 29, 2006 6:35 am Post subject: Torque Wrench Extension |
While it is an inventive way to do it, I wonder about the impact of the
angle on the wrench shown, and might point out that a set of crow's foot
wrenches from Sears isn't all that much money. The crow's foot works
fine on Hartzel props.
Tim Olson wrote:
KCHD |
Posted: Sat Apr 29, 2006 6:38 am Post subject: Torque Wrench Extension |
Jesse,
This falls in the category of waxing philosophical on a subject and that doesn't help get my plane in the air any faster BUT I'm totally with you. I struggled with that as well so here goes.
If you are working with a beam type torque wrench you must hold it on the handle and center the handle on its pivot in order to get an accurate reading, in this case it is easy to understand why the calculation needs the torque wrench length. With the micrometer or "click" type torque wrenches you don't necessarily have to hold it by the handle to get an accurate torque because the spring is set to the value you want - that is, unless you are using an extension.
Hang with me and please excuse the math, this is how I understand it. Consider the following 2 cases:
You are using a 20 inch long micrometer type torque wrench set at 100 in-lbs attached to a 10 inch extension.
1) If you hold the torque wrench by the handle you must apply 5 lbs of force to create 100 in-lbs of moment (torque) at the head and cause it to click (5 lbs x 20"). At the end of your 10" extension you are creating 150 in-lbs of torque (5 lbs x 30 inches).
2) If you "choke" up on the torque wrench and hold it, say, 10" from the head you must apply 10 lbs of force in order to get it to click at 100 in-lbs. Now at the end of your 10" extension you are applying 200 in-lbs of torque (10 lbs x 20 inches)
As far as using the extension other than straight - I'm not an A&P, but I am an engineer and the math tells me that bending the torque wrench does make a difference. Your moment arm now becomes the hypotenuse of the triangle created by the torque wrench and extension. The further you bend the extension the shorter your moment arm becomes and, thus, the less torque you have at the end of your extension. This is a minor correction until the angle starts getting beyond about 45 degrees. I will skip the geometry involved. Consider the case if you bent the extension all the way back toward you, aligned with the torque wrench... now the moment arm is equal to the length of the torque wrench MINUS the length of the extension.
Sorry for the dissertation. I had to prove this to myself before I torqued my prop bolts.
The bottom line: The website calculation works for a straight extension.
Jim
40134
In a message dated 4/29/2006 7:43:37 A.M. Mountain Daylight Time, jesse(at)itecusa.org writes:
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
Jim McGrew
Checked by AVG Free Edition.
Version: 7.1.385 / Virus Database: 268.5.1/327 - Release Date: 4/28/2006
No virus found in this outgoing message.
Jim "Scooter" McGrew
jsmcgrew(at)aol.com
Posted: Sat Apr 29, 2006 6:45 am Post subject: Torque Wrench Extension |
I had a few places where the crow's feet didn't work for me. I won't get into details... in my opinion the angle of the wrench doesn't make an appreciable difference.
Jim
In a message dated 4/29/2006 8:36:26 A.M. Mountain Daylight Time, kellym(at)aviating.com writes:
| Quote: | --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com>
Tim Olson wrote:
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
Tim Olson - RV-10 N104CD - ========================== es Day
--> ================================================== - NEW MATRONICS LIST WIKI -
_-= sp; -> =========================p; - List Contribution Web Site ==================================================
jsmcgrew(at)aol.com
flysrv10(at)gmail.com Guest
Posted: Sat Apr 29, 2006 6:56 am Post subject: Torque Wrench Extension |
Great Idea! I used a expensive Crows Foot but had to go and shop for
it. This would have done just fine.
do not archive.
On 4/29/06, JSMcGrew(at)aol.com <JSMcGrew(at)aol.com> wrote:
Jim McGrew
Posted: Sat Apr 29, 2006 7:18 am Post subject: Torque Wrench Extension |
A note about the crow's foot. I think I used one on my prop bolts,
but it was hard to get something that stuck out far enough away
from the prop hub to allow the wrench to fit in good too.
Ideally, you'd use an extended crows foot type arrangement, which
is a tool Hartzell sells. But, what he did with the bolt
and open end wrench essentially duplicates the extended crows foot,
and from what I can tell, I think that's probably the simplest
way to get those prop bolts tightened.
Rob Kermanj wrote:
do not archive.
> There
> wires on
> and put
> extension.
> using
> website
> across
> Jim McGrew
http://wiki.matronics.com
Posted: Sat Apr 29, 2006 4:31 pm Post subject: Torque Wrench Extension |
Not to argue with you (do not archive – ok, that’s out of the way), but isn’t the thing that matters how much torque there is at the head to make it click, not how much force you are putting on it. If it is the same torque wrench set at the same setting with the same extension, shouldn’t it give the exact same amount of torque no matter where on the wrench you grab it? It will require more force from the person, but the leverage from the hand to the click should be isolated form the amount of torque from the click to the nut, right? Well, maybe that’s why I am an accountant and not an engineer.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
Sent: Saturday, April 29, 2006 9:38 AM
Subject: Re: Torque Wrench Extension
Jesse,
Jim
40134
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
Jim McGrew
Version: 7.1.385 / Virus Database: 268.5.1/327 - Release Date: 4/28/2006 |
jsmcgrew(at)aol.com
Posted: Sat Apr 29, 2006 5:56 pm Post subject: Torque Wrench Extension |
Jesse Saint wrote:
| Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]-->
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
| Jesse, nobody argues on this list .... they just discusses things to death! You're 1/2 right in your statement.
Torque is measured in foot-pounds. Foot being the distance from the 'head' to where the force is applied, which is in pounds. If the torque wrench is 2 feet long, and you press with 2 pounds at the end of the torque wrench, you have 4 foot-pounds of torque. Now, if you grasp the torque wrench in the middle and apply the same pressure, that's only 2 foot-pounds. It's a leverage thingy. You hit it right when you said "It will require more force from the person" ..... and to give the bolt (or nut) the same torque you'd have to push 4 pounds.
Some folks get downright anal about it when you put a crows-foot on the end of the torque wrench, which adds (maybe) 1/2" to the length and HAVE to calculate the new foot-pounds!!! Sheesh. Well, grab your geometry book off the shelf if you put the crows foot 90 degrees from the side!!!
Well, as you can probably tell, I don't figure ..... I just do it. And I haven't had any failures (yet) from winging (highly technical term) it.
Linn
john(at)ballofshame.com Guest
Posted: Sat Apr 29, 2006 6:43 pm Post subject: Torque Wrench Extension |
You almost have to think about it as a bending moment thing. Here's
an argument that should convince you, though:
If it's true that it doesn't matter where on the handle you're pushing,
then as I reduce the length of the handle on the torque wrench it will
always break at the same point given X torque on the screw, right?
Now imagine that the handle gets shorter and shorter and shorter. You
can imagine that at some point the handle gets so short (say .01" long)
that it would require an ENOURMOUS torque to get that torque wrench
to break (given that you left the torque setting constant). At the limiting
case, the length of the handle is 0 and it will require infinite torque to
get the wrench to break.
In the case of no extension, it doesn't matter where you hold the
handle because the ratio of handle to extension is always the same ( =
0 ) and that's really what determines what your torque setting must be.
This isn't true for a beam style wrench. Once again, a beam style is a
bending moment thingy and you have to hold it in the right place.
Think of the beam style as zillions of little torque wrenches all hooked
up head to tail
I hope this helps and doesn't just confuse the issue more. Also, I've
been deburring ribs all day so take it with a grain of salt...it looks right
from here, though...
-John Coloccia
On 29 Apr 2006 at 19:30, Jesse Saint wrote:
Not to argue with you (do not archive “ok, that™s out of the way), but isn™t the thing that matters
it is the same torque wrench set at the same setting with the same extension, shouldn™t it give the
amount of torque from the click to the nut, right? Well, maybe that™s why I am an accountant and
not an engineer.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
Jesse,
handle on its pivotin order to get an accurate reading, in this case it is easy to understand whythe
calculation needs thetorque wrench length.With the micrometer or "click" type torque wrenches
you don't necessarily have to hold it by the handle to get an accuratetorque because the spring is
set to the value you want- that is, unless you are using an extension.
cases:
inch extension.
moment (torque) at the head and cause it to click (5 lbs x 20"). At the end of your10"extension
Jim
40134
That™s a great idea.
Does it really make a different torque value if you grab the handle at the end or śchoke upť to the
value on the wrench is accurate, but then, of course, you can™t use the racheting feature of the
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
welding something upI found that if you take an ordinary combination wrench and put a bolt/nut
with washersthrough the closed end you have a perfect extension. And you get to keep your
worth sharing.
Jim McGrew
jsmcgrew(at)aol.com
