Fwd: chinese decals
dougsappllc(at)gmail.com
PostPosted: Fri Oct 15, 2010 8:02 am    Post subject: Fwd: chinese decals Reply with quote
Anyone out there know who make the best Chinese decals for the side of the aircraft?  Please respond to Philip's email below.
Doug
---------- Forwarded message ----------
From: Philip Nicholson <pednicholson(at)gmail.com (pednicholson(at)gmail.com)>
Date: Fri, Oct 15, 2010 at 8:13 AM
Subject: chinese decals
To: dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)
Good morning Doug,
     I recently purchased a CJ6 which is currently at VAM in BC.  The paint is nasty but will have to wait.  I was wondering if you know where I could source some Chinese PLAF decals for the side of the aircraft.
Phil Nicholson
N13472(at)aol.com
PostPosted: Fri Oct 15, 2010 8:11 am    Post subject: Fwd: chinese decals Reply with quote
Get a good picture and take to a shop that does vehicle wraps. They can make what ever size, color, ect you want.
Tom Elliott
CJ-6A NX63727
702-595-2680
[quote] From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of doug sapp
Sent: Friday, October 15, 2010 9:00 AM
To: yak-list(at)matronics.com
Subject: Fwd: chinese decals
Doug
Good morning Doug,
Phil Nicholson
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
Pete Fowler
PostPosted: Sun Oct 17, 2010 8:40 am    Post subject: Updated insignia availability Reply with quote
Getting quite a few requests and I have both a Russian and Chinese insigna converted to a PDF that can be opened in Illustrator. The Chinese characters on Nanchangs I've seen (including mine) tend to be vague and innacurate. Even after I posted mine, I went back and did some more research and tightened them up so this is the newest most correct version.
If you use these, I'd appreciate a couple of bucks (they're my original artwork) but hopefully this helps folks who are looking for the right thing.
Note that a sign shop uses vector art (as opposed to bitmap), if you supply a JPEG, they have to redraw and re-interpret the JPEG and the generational and human losses can make the insignias come out vague and innacurate.
CHINESE insignia.pdf
 Filename:  CHINESE insignia.pdf
 Filesize:  55.57 KB
 Downloaded:  412 Time(s)
Russian Insignia.pdf
 Filename:  Russian Insignia.pdf
 Filesize:  217.61 KB
 Downloaded:  404 Time(s)
kurt(at)scitechsys.com
PostPosted: Sun Oct 17, 2010 9:34 am    Post subject: Fwd: chinese decals Reply with quote
I ran across a vector graphic of the PLAAF roundel. I post a link later today.
Kurt "I.T." Howerton
N923YK
530.312.1299
http://forums.matronics.com/viewtopic.php?p=316061#316061
http://forums.matronics.com//files/russian_insignia_103.pdf
http://forums.matronics.com//files/chinese_insignia_295.pdf
PostPosted: Sun Oct 17, 2010 9:35 am    Post subject: Fwd: chinese decals Reply with quote
Wikipedia:
en.m.wikipedia.org/wiki/File:Roundel_of_the_Peoples_Liberation_Army_Air_Force.svg
N923YK
530.312.1299
Pete Fowler
PostPosted: Sun Oct 17, 2010 9:56 am    Post subject: Re: Fwd: chinese decals Reply with quote
That wikipedia mess is a great example of a poorly researched and badly drawn insignia. Not only is the letting not correct, It's drawn with dozens of misalgned straight points rather than curves and looks like it was chiseled out of wood.
That's why I drew them cleanly for use on our aircraft.
 Filesize:  52.74 KB
 Viewed:  4651 Time(s)
PostPosted: Sun Oct 17, 2010 10:11 am    Post subject: Fwd: chinese decals Reply with quote
Isn't that the cool thing about wikipedia? You can fix it if it's wrong.
I'd love to see a better version posted for the benefit of the community.
N923YK
530.312.1299
http://forums.matronics.com/viewtopic.php?p=316072#316072
http://forums.matronics.com//files/picture_4_190.jpg
